Forum sponsored by House Ad
Tools
Sort by:
Graduating to Quicker Scales
Jim Whetren scribes his own lines
A milling head vertical alignment guide for the Unimat 3 lathe
Maurice Rhodes improves his Unimat 3 vertical head
Living with the Worden
Jim Whetren improves the Worden Mk. III Tool & Cutter Grinder
A Unimat 3 Mandrel Handle
A Miniature Pin Type Precision Vice
Jim Whetren holds tight
Tailstock barrel depth measurement
Dave Fenner adds demountable accuracy to the Super 7 tailstock
A quick change hand turning rest
Jim Whetren tries his hand at turning
A profile copier for the Unimat 3
Maurice Rhodes shapes up
Fine angle adjustment for the Unimat 3 topslide
Maurice Rhodes modifies his topslide
Unimat 3 milling head depth stop
Maurice Rhodes comes to a stop
The Super Glue Chuck
The Superglue Chuck, a replacement for the old wax chuck.
A faceplate for uncle George.
Eric Clark describes how he fitted a readily available faceplate to a Hobbymat MD65 lathe.
Top 5 Tools
A Toothed Belt Drive for the Unimat 3
Maurice Rhodes gets into gear
A Look at number stamping
Jim Whetren finishes off his engraved dials
A Poor Mans Linisher
Jim Whetren belts up
Free Plan: A Clutch for the ML7 Lathe
This design by Alan Buttulph addresses the construction of a clutch for ML7 lathes. Ingeniously, by fitting the clutch to the countershaft, construction is relatively straight forward. The article, in Issue 5 of Model Engineers' Workshop that accompanies these plans is available in the archive on this website*.
Dreweatts
Rapid RC
