Lathe dilema
Lathe dilema
Home Forums Workshop Tools and Tooling Lathe dilema
Viewing 25 posts - 1 through 25 (of 43 total)
  • #300403
    Lee Goulding
      @leegoulding74917
      Hi All im looking at the Warco WM290VF and the Toolco 1130G lathe but my dilema is that toolco who have responded well by email have advised waiting around 6 weeks to get the brushless motor version which must be the WEISS WBL290F
      The problem is I'm in the middle of doing up my workshop and could do with getting one quick to build around it as I have left putting the door on to get the lathe in so my question is is the brushless motor version worth the wait? Thanks
      Also would like to add that warco said they would send me a quote and never have.. guess they don't want the business
      Edited By Lee Goulding on 30/05/2017 23:43:26
      Edited By Lee Goulding on 30/05/2017 23:45:17
      Lee Goulding
        @leegoulding74917
        Which lathe
        #300413
        Niels Abildgaard
          @nielsabildgaard33719
          The brushless DC version is not worth to wait for .An inverter system 3 phase AC is the way.My lathe has a VFD and I can cut thread in direct drive.My milling machine from Weiss has brushless DC and cannot cut anything really slow.
          #300414
          Thor 🇳🇴
            @thor
            Hi Lee,
            If you buy the Warco WM 290V you get a lathe with a 3-phase motor and inverter. I have a similar lathe (different paintwork) and I do like the inverter drive. A brushless DC motor seems to have more torque at lower speeds than a brushed DC motor, so if you don't want an inverter drive a brushless DC motor would be my choice.
            Thor
            #300422
            John Rudd
              @johnrudd16576
              Toolco's current offering is the 1130 GV which is a 3 phase motor driven lathe with inverter….
              I bought the dc brushed version from SPG ( SP2129) and added my own motor and vfd and still came in cheaper than Toolco, plus the SPG lathe came with a stand not as an extra.
              #300425
              Lee Goulding
                @leegoulding74917
                Hi
                Thanks for all the input guys and still a mixed bag of opinions with brushless or VFD.
                Not sure still 😀
                #300426
                Lee Goulding
                  @leegoulding74917
                  I contacted SPG about the SP2129 and they said August/September until they have anymorein stock.
                  Would you consider buying direct from WEISS or have you any idea where to get a similar spec lathe from.. thanks
                  Edited By Lee Goulding on 31/05/2017 09:39:06
                  #300427
                  mark smith 20
                    @marksmith20
                    GM tools had two of these in with one left , probably a better lathe.Can`t vouch for the condition though.Says gap bed but i cant see the gap strange!
                    http://www.gandmtools.co.uk/shop/warco-gh-1330-gap-bed-centre-lathe-tooling-3ph-80204263/
                    Edited By mark smith 20 on 31/05/2017 09:42:00
                    Edited By mark smith 20 on 31/05/2017 09:47:02
                    #300430
                    Lee Goulding
                      @leegoulding74917
                      Hi Mark
                      I saw that and does look a good lathe but not really sure cos I'm new to lathes and not sure how much more I would have to do to get it to single phase and variable speed and I would need to collect it which is a big headache for me
                      What you think?
                      #300432
                      mechman48
                        @mechman48
                        Posted by mark smith 20 on 31/05/2017 09:41:09:
                        ​There is a gap there, click on the 4th pic down, move cursor to main pic which then magnifies the pic, there is a joint there.
                        George.
                        #300435
                          One thing to look at is what are the speed ranges for the various motors. Will the VFD one require more frequent belt swapping due to less overlap between the two ratios. I run my 280 DC brushed in the slower range all the time which gives me 50-1100rpm. which I find more usefull than 100-2000,
                          If I'm remember rightly the VFD ones run something like 30-400 and 150-2000 so you may find you are swapping belts a lot more as there is less overlap between the two.
                          Another point to look at is what chuck mount do they use, nutted from behind, keyhole plate or D1-3 with the D1-3 being the most desirable.
                          #300437
                          mark smith 20
                            @marksmith20
                            Posted by mechman48 on 31/05/2017 10:14:16:
                            George.
                            Hi George, yes your right ,im used to seeing a wider gap so couldnt see it..smiley
                            #300438
                            mark smith 20
                              @marksmith20
                              Posted by Lee Goulding on 31/05/2017 10:01:16:
                              Hi Mark
                              What you think?
                              Hi Lee, i dont really have experience of whats inside the warcos. I dont know if you can just purchase an invertor and the motor present is already inverter friendly or not. Or if fitting an inverter would cause the lathe to be underpowered due to converting to 1PH
                              So others may advise.
                              It is a bigger heavier lathe at around 600 kg, which isnt really that heavy but may be a problem for you and your workshop.
                              Mark
                              Edited By mark smith 20 on 31/05/2017 10:34:33
                              #300439
                              Lee Goulding
                                @leegoulding74917
                                Ok thanks for that info I think I follow what you mean 😀
                                #300440
                                Lee Goulding
                                  @leegoulding74917
                                  Hi Mark
                                  The lathe is going to be used mainly for brass and accurate wood boring and turning but do require a lathe with a 38mm spindle bore
                                  What would be your preferred lathe for that?
                                  Thanks
                                  #300444
                                  mark smith 20
                                    @marksmith20
                                    Hi Lee, if your making cues , which you mentioned in a previous thread , i think any half decent metal lathe will be accurate enough and more accurate than a wood lathe .
                                    A 38mm or 1 1/2 bore headstock is useful for some clearance and a longish bed . If that is the only work your planning on doing i think you have a lot of choice and honestly don`t see the need to speed so much on the machine.
                                    A good used machine would be sufficient .
                                    Also with wood ease of cleaning is something to think about as the dust gets everywhere. Inverters also dont like dust which is also something to think about.
                                    #300449
                                    John Rudd
                                      @johnrudd16576
                                      Jason,
                                      My SPG lathe uses the D1-4 method for chucks-faceplate attachment.
                                      Also, fitting a 3 phase motor and vfd in lieu of a dc motor is more advantageous. It is more efficient and far more reliable. Just read through the various topics on the issues folk have had with lathes fitted with dc motor drive trains, from the humble little mini lathe right through to the 280 series offered by other vendors.
                                      #300455
                                      Nik G
                                        @nikg
                                        I received my Warco WM290VF two weeks ago, this was approx. 2 weeks after initial order. Communication was non existent from them, with me chasing for delivery timescales etc.
                                        On arrival I had issues with the cross feed, carriage feed which I believe was due to a knock during transportation. Warco were easily contactable and helpful in suggested possible fixes to be tried prior to return. Disassembly resolved the issue for me.
                                        Yet to really use in anger but all seems good so far.
                                        Would of preferred a D1-3 Chuck as the undoing of bolts on the chucks can be a pain and I also wish it came with a quick change toolpost. But about to modify the carriage myself to accept one. Warco is out off stock and has been for sometime
                                        Edited By Nik G on 31/05/2017 12:03:29
                                        #300457
                                          Thanks for the chuck mount info John I was not 100% sure if it was D1-3 or D1-4 that SPG did and would be nice to have. The last Warco 290 that I saw at Ally Pally earlier this year had the keyhole plate which would be a half way house but still better than the loose nuts.
                                          When I bought my 280 about 8 years ago the electrics were regarded as more of an issue and I said at the time if they played up I would go for a VFD setup but as I've not had issues with it have just left alone.
                                          #300459
                                          MW
                                            @mw27036
                                            Has anyone tried to convert a belted lathe to a gearbox style start with quick change speeds/ratios?
                                            Michael W
                                            #300472
                                            Lee Goulding
                                              @leegoulding74917
                                              Hi All and thanks for the replays most useful information
                                              #300473
                                              Lee Goulding
                                                @leegoulding74917
                                                Mark Smith 20
                                                So would you say wait for the Toolco brushless motor of the 1139GV or just get the delta drive one that's currently available
                                                Thanks
                                                #300497
                                                mark smith 20
                                                  @marksmith20
                                                  Lee its your money, but as i said if you are only planning on making cues and not doing any fancy metal turning,i personally wouldnt spend so much. I dont really know much about these warco lathes and myself only use a 1960`s southbend 9a with a miserable3/4" bore. Im also of the 240v 3phmotor/ inverter camp and dont really like dc motor that much for lathes.
                                                  #300499
                                                  John Rudd
                                                    @johnrudd16576
                                                    Toolco dont do a brushless version……..
                                                    These lathes either have a dc brushed motor or they have a 3 phase inverter driven motor…..
                                                    Ensure the seller knows what you want, and you know what you want….
                                                    It could turn out to be a costly mistake…
                                                    Edited By John Rudd on 31/05/2017 18:39:45
                                                    #300502
                                                      The WEISS WBL290F Lee mentioned does seem to be fitted with a 2HP DC Brushless motor. DC Brushless motors have moderate control and torque advantages compared with a 3-phase / VFD combination but I wouldn't wait 6 weeks for one if I was in a hurry. I'd say Lee won't be disappointed if he buys a VFD lathe.
                                                      Depends rather on what you're doing but my hobbyist order of preference for powering a lathe would be:
                                                      1. DC Brushless
                                                      2. VFD 3-phase
                                                      3. 3-phase (assuming supply available)
                                                      4. DC Brushed
                                                      5. Single-Phase AC
                                                      6. Treadle
                                                      Options 5 and 6 are the only ones I'd avoid. Other opinions may be expressed!
