Identyfy this lathe
Identyfy this lathe
Home Forums General Questions Identyfy this lathe
  • #148522
    Abdur-rehmaan Seba
      @abdur-rehmaanseba35366
      Can you help me identify this lathe, it looks like a Zyto but Iam not sure.
      Abdur-rehmaan Seba
        #148547
        Brian Wood
          @brianwood45127
          Hello Abdur,
          It would help us a lot if you could give a little more information, any markings might be useful and a picture or two would be invaluable; there were a number of models in the days when Zytos were popular that looked somewhat similar.
          #148550
          Les Jones 1
            @lesjones1
            Hi Brian,
            Has your crystal ball gone faulty again !
            Les.
            #148551
              Hello Abdur,
              It seems you tried to link a picture to your post, but we can't see it. Could you try again, please?
              Thanks
              nigel jones 5
                @nigeljones5
                Ah..Its a Myford ML10…definately!
                #148557
                Frank.N Storm
                  @frank-nstorm18349
                  Definitely!
                  Rgds, Frank
                  #148593
                  Brian Wood
                    @brianwood45127
                    Hello Les and others,
                    Clearly my crystal ball is shot, no pictures but others can see it so all is well!
                    #148594
                      Posted by Brian Wood on 01/04/2014 10:02:48:
                      On the contrary Brian … I think they are just being "witty"
                        Posted by Abdur-rehmaan Seba on 31/03/2014 10:55:15:
                        Welcome, Abdur
                        I've just looked at the code for the picture that you tried to post:
                        <img alt="" src="e:/DSCN8662">
                        This address is on your own machine.
                        For others to see it, you need to create an Album on this forum; post the picture there; then insert it using the little black camera icon [on the top bar of the post editing pane]
                        …Hope that helps
                        Abdur-rehmaan Seba
                          Posted by Neil Wyatt on 31/03/2014 18:46:27:
                          Hello Abdur,
                          Thanks
                          I'm not sure how to link it in but if you go to **LINK** and search 'small lathe' you should find it if it's not sold. sorry about the trouble
                          Image added by JasonB
                          Edited By JasonB on 04/04/2014 07:38:54
                          #148812
                          Abdur-rehmaan Seba
                            Posted by Michael Gilligan on 01/04/2014 10:24:05:
                            Welcome, Abdur
                            …Hope that helps
                            It helped alright !
                            #148815
                            Abdur-rehmaan Seba
                              Posted by fizzy on 31/03/2014 19:00:42:
                              It isn't cheekyYah.
                              #148824
                              Keith Long
                                @keithlong89920
                                Hello Abdur
                                There were a number of very similar lathes made around the time of your machine that all look very much alike. Possibly made up from a small range of standard parts or probably direct copies of each other.
                                One that looks very similar to your lathe was marketed by Gamages and appears on the well known lathes.co.uk website **LINK** have a look down towards the bottom of the page linked to. The distinctive feature would seem to be the pronounced cast in "bead" around the curves of the side of the bed. Other lathes show similar raised beads but nowhere near as noticeable.
                                Keith
                                #148855
                                Nicholas Farr
                                  @nicholasfarr14254
                                  Hi Abdur, I reckon it could be a Portass Junior **LINK**
                                  Regards Nick.
                                  P.S. I have a RandA one which is similar, but has the added benifit of screw cutting. http://www.model-engineer.co.uk/albums/member_photo.asp?a=12754&p=509767
                                  Edited By Nicholas Farr on 03/04/2014 23:12:19
                                  #149740
                                  Abdur-rehmaan Seba
                                    Posted by Keith Long on 03/04/2014 17:00:24:
                                    Hello Abdur
                                    Keith
                                    Thanks for that, sorry about not replying earlier, we had a powercut.
