Brittania superheater
Home Forums General Questions Brittania superheater
  • #289400
    Mark P.
      @markp
      Brian, could you not make up your own dummy pipe work and valves etc?I have made quite a few in the past, they were fairly straight forward to do especially if working from photos.
      Sorry to hear about Doug.
      Mark P.
      Boiler Bri
        @boilerbri
        Mark, It's the white metal castings that I really need. The parts that were on the model are very semi scale.
        Time is another issue.
        #297858
        Boiler Bri
          @boilerbri
          I was looking at a Brittania at the show in Doncaster. It had steam operated cylinder drains fitted. Does anyone have plans or information that would help me make them?
          #302295
          Boiler Bri
            @boilerbri
            Ok. So the engine is all back together and now has a boiler cert. I have only run it once and I sure am looking forward to running again. The first run showed I need a few small changes and modifications.
            It is basically the same as original supply from Winson, so now I can look at making changes to details and mechanical parts. The first thing I would like to sort out is the bacon slicer forward and backward mechanism. I have no way of telling what position the valve timing is when running. The Hewson one is fairly expensive so I would like to make my own, by fabrication. The one fitted is a big chunk of brass. When I looked at one at Doncaster on a 5" brit the other week it was smaller and had graduation marks on the smaller wheel so you knew where the gear was set.
            Does anyone have drawings or know where I can buy them from?
