What's the best way to finish them?
Scott | 03/09/2014 09:18:02 |
52 forum posts 10 photos | Hello all
Just wondering if anyone has any tips for getting a good finish on crank pins and journals for I/C engines?
Thanks Scott |
JasonB | 03/09/2014 11:14:52 |
![]() Moderator 22555 forum posts 2634 photos 1 articles | Fine Emery cloth or wet n dry on a flat stick will give that final finish and take them down to size. Cover the lathe up well, I tend to lay a piece of board or card on the bed so there is no risk of things getting caught in the chuck. |
Bill Pudney | 03/09/2014 13:12:12 |
606 forum posts 24 photos | Or press in a needle roller...... cheers Bill |
Scott | 05/09/2014 14:16:52 |
52 forum posts 10 photos | Thanks chaps! |
Scott | 10/09/2014 19:56:19 |
52 forum posts 10 photos | Just a quickie Jason - what grit would you go down to? Cheers Scott |
JasonB | 10/09/2014 20:03:20 |
![]() Moderator 22555 forum posts 2634 photos 1 articles | about 600g W&D if they are running agains a metal bearing ec aluminium conrod with or without bronze bearing, bit less say 400g if using ballraces.
J |
