3 -Phase Conversion of a Mini-Lathe
A new online article
Articles
3-Phase Conversion and Other Alternative Methods of Powering a Mini-Lathe
After much experimentation with different ways of powering my mini-lathe on a keep it going basis, I finally decided to go the whole hog and install an inverter and 3-phase motor to give me variable frequency drive. This is the whole story.
XD 35130/12/2018 08:05:20
1392 forum posts
118 photos
Just a quick update and photo of the enclosure , the rest of the upgrade is now just a put it back together affair so I won't bore you with that . I may be back later on with the tumbler gear modification once i work out how to do it ! a2a1cb15-a590-43c3-ad19-cbee11118ccd.jpeg
Neil Wyatt30/12/2018 10:20:01
17090 forum posts
690 photos
76 articles
Neat woodwork!
Niels Abildgaard30/12/2018 12:30:01
260 forum posts
89 photos
Posted by XD 351 on 30/12/2018 08:05:20:
Cooling air for motor?
XD 35130/12/2018 23:17:20
1392 forum posts
118 photos
Cooling is via 12v automotive fan mounted inside the cabinet and the air is ducted up to the fan shroud of the motor , it then exits through a vent on the end of the motor enclosure. The fan is pwm controlled so i can set the airflow and this also keeps the fan a bit quieter as it doesn't run flat out . The vfd is also mounted inside the cabinet and the fan also gives some airflow for that as well .
XD 35119/01/2019 09:54:20
1392 forum posts
118 photos
c242c83f-bafe-473e-9c7b-b64f99ea2188.jpegb4a8b6a2-20b8-49ff-bd9e-c92d66254805.jpeg34ad223e-1e3e-4d94-a5de-e14a800578db.jpegdfda5381-2e18-4f34-8652-5e1138af6f46.jpegb64abb06-617f-4db3-9bbb-110630eab2e5.jpeg0882045c-0d76-4faf-b4c9-893361c594f5.jpegHere is the mod for the tumbler gear - nothing spectacular but it works although neutral is a problem for some reason - maybe because the tumbler gears are odd sizes I don't know . There is so little clearance to work with so even though i have extended the linkage of the tumbler bracket ot still bunches up towards one side of the movement .
Ausee.com.au
