Forum sponsored by Allendale Nov 29
Marine Steam Engine mentioned in Harris's book
Drawing required
John Burridge19/06/2014 20:19:27
54 forum posts
I have recently re-read The Harris book on steam engines and at the last chapter he mentions a full size marine steam engine which he says was in the Engineer magazine and he give numbers of the issue 20-6-13 which I presume is the date issue.
It is a twin two cylinder Non-condensing and uses Stuart Turners cylinders.
It mainly seem to be made of mild steel plate and bars for the base plates and the columns, the crank can either be machined from the solid or made up and pinned together,It also mentions pumps for the feed and lubrication.
Has anyone either made this engine or have the drawings for it as yet I can not seem to trace it anywhere
JasonB19/06/2014 20:30:32
15039 forum posts
1533 photos
A quick flick through teh 20th June issue did not show anything obvious but if you want to have a better look its here
JasonB19/06/2014 20:47:41
15039 forum posts
1533 photos
Actually I think its just the Dendy- Marshall valve gear that gets a mention and its the drawings of the valve gear Harris refers to not the drawing of his engine. See top left of first page in link above
J
julian atkins20/06/2014 00:00:04
1196 forum posts
353 photos
thanks Jason for the fascinating link!
completely off topic but from your link black vein seam coal which is underneath my cottage 17s 6d per ton in 1913!
cheers,
julian
TRANSWAVE Converters
