myford change gear spacer
dw dw09/06/2014 18:57:25
18 forum posts
5 photos
back gear spacer 003.jpgback gear spacer 002.jpgHave just acquired a myford super 7 & back gear spacer 001.jpgin box there was the change gear bush, change gear stud, spacer with cut out for woodruff key etc. Does anyone know which is the correct order in which these are set on the gear stud. I have att' a pic showing the bits I have. Does the spacer with cut out go at the end of the train before the lock nut/washer or between the bush & the sleeve? Thanks in anticipation DW.
Nick Hughes09/06/2014 20:24:49
233 forum posts
133 photos
Hi DW,
Put a gear on first, then the spacer, then another gear.
Nick
Roderick Jenkins09/06/2014 20:25:21
1951 forum posts
503 photos
I had to look this up since I've never actually used the spacer. According to my manual, the spacer separates the 2 gears on the stud. Thanks for the prompt, one lives and learns - although it doesn't seem to be terribly important.
Cheers,
Rod
edit - too slow again
Edited By Roderick Jenkins on 09/06/2014 20:26:22
Martin Kyte10/06/2014 08:30:19
2067 forum posts
37 photos
As indicated above it goes between two change wheels (gears) on the stud. The purpose is to create a clearance between the outer wheel and the inner wheel on the next stud in the chain.
regards Martin
dw dw 110/06/2014 10:24:28
40 forum posts
15 photos
Thank you all for your time, makes sense as when I look closely the woodruff key has a taper at either end so if put at the ends it would not contact the key. Off now to carry on cleaning setting it up. Regards Dave
Jon Gibbs10/06/2014 14:11:17
739 forum posts
This is very interesting as it is a Super 7-only spacer.
The ML7 which uses the same gears and studs doesn't benefit from the spacer - the edges of the gears do occassionally rub together.
So, Rod's observation that it isn't terribly important seems fairly accurate.
Jon
EngineDIY
