Seed thread to start things off.
Neil Wyatt | 23/05/2014 14:02:22 |
![]() Moderator 19040 forum posts 734 photos 80 articles | Following some discussion off-forum, it's apparent that large proportion of model engineers also dabble in electronics. Indeed, I know some of you are doing some very advanced stuff. Some of these discussions (e.g. tachometers, inverters, DROs and CNC) have homes elsewhere on the forum, but this topic is intended for those who would like to discuss technical issues, without clogging up other topics for those who would rather be metal mangling It can also be a home for build or development threads on electronic accessories, or for postings on techniques and tools - and naturally plenty of scope for questions. We'll set the 'scope' for this topic according to people's interests, but I hope it's more about driving stepper motors than programming TV remote controls. So. What are you up to with your soldering iron? Neil
Nick_G | 23/05/2014 14:59:21 |
![]() 1808 forum posts 744 photos | . Making a microphone pre amp at some point this weekend for use with my HF transceiver.
Nick (G7GPL) Edited By Nick_G on 23/05/2014 14:59:47 |
FMES | 23/05/2014 15:16:49 |
608 forum posts 2 photos | Not truly electronics per se, but spent an hour removing the alarm from my motorcycle which had died due to a long term storage situation. It would appear that the alarms internal battery is only good for about ten years and even less when you remove the bike battery for storage. The solution from the alarm company? 'we can supply a replacement unit programmed to your key fobs for around £350'. Don't you just love technology? |
jason udall | 23/05/2014 16:15:18 |
2031 forum posts 41 photos | Lofty..in fairness ..ten years?... OK a new alarm for ?350 seems steep but they were willing to programme it to your key( yeah right..most learn the first key they hear)....... When the fobs for cars are about ?50..for a fivers worth of gubbins...but then how long will pulling the alarm apart .changing the backup battery..resealing it to suit...you have ten hours starting now. |
Ady1 | 23/05/2014 17:08:06 |
![]() 5092 forum posts 736 photos | I got a handy meter from xxbay which was very handy when I dabbled, only 25 quid including postage A vichy vc99 |
DerryUK | 23/05/2014 17:11:44 |
125 forum posts | I am building an Arduino ECU for my '69 T100. It has several clever and unique features. Derry. PS well I hope it does by the time I finish it, I've been at it long enough! |
Les Jones 1 | 23/05/2014 18:17:53 |
2257 forum posts 156 photos | I have two projects on at the moment. The first one is to add a tacho input to my Attiny4313 based interface for "Yuriy's Android tablet DRO" I have decided that using a separate microcontroller to handle the tacho function is the easiest way to do it. I plan to use a modified version of my 1 to 99 pulses per rev tachometer that I submitted to MEW several years ago. This will pass the data to the ATtiny which will then format it and pass it on to the Android tablet. The other project is a stepper motor controller to rotate one of the Wixey type angle gauges about 455 times. This is to check my theory that the reading will be incorrect after this number of revolutions. This controller will probably finish up driving a rotary table in a similar way to Tony Jeffree's Divisionmaster. Les. |
Oompa Lumpa | 23/05/2014 18:57:46 |
888 forum posts 36 photos | I have assembled most of the bits to create a DRO setup based on Yuri's Android DRO, but the bits are all in one of my "future project" boxes. First I am going to build an X axis variable speed drive for the Mill. But I have seen some rather trick full speed return circuits for this which enable the table to quickly return after cutting ready to advance for the next cut. I am still agonising over this as it introduces yet more things to go wrong. But it would be nice though. graham. |
David Jupp | 23/05/2014 19:07:03 |
836 forum posts 17 photos | Part way through a very basic interface (more of a connector really, or mainly) to control Denford Novamill stepper and spindle from PC parallel port without having to replace stepper drivers or DC spindle drive. |
FMES | 23/05/2014 19:28:21 |
608 forum posts 2 photos | Posted by jason udall on 23/05/2014 16:15:18:
Lofty..in fairness ..ten years?... Sorry Jason, the bike is four years old, it was the point that if you remove the main battery for a few weeks the alarm 'dies' which is not mentioned in the manual. You can reprogramme it IF you can get the led to flash and input the code manually. But as the battery was off for six months there was no way the alarm was going to talk to anyone. The unit is a Thatcham alarm and I was advised that all the internals were potted and it was not possible to replace the internal battery.
Alex du Pre | 23/05/2014 20:46:51 |
![]() 21 forum posts 31 photos | I'm trying to get to grips with the Arduino. Hoping to use it as a basis for some control functions for my MkII Fifth scale model car: http://www.amdengineer.com/mk-2-15-scale-rc-car/ possibly for an automatic gearbox, to control the lights, or even as an ECU for the engine! Endless possibilities! Regards, Alex |
Neil Wyatt | 23/05/2014 20:54:14 |
![]() Moderator 19040 forum posts 734 photos 80 articles | > The unit is a Thatcham alarm and I was advised that all the internals were potted and it was not possible to replace the internal battery. They just means it's more bother to them than it's worth. The link below contains some adult language but is otherwise OK. |
John Stevenson | 23/05/2014 21:02:32 |
![]() Moderator 5068 forum posts 3 photos | Posted by DerryUK on 23/05/2014 17:11:44:
I am building an Arduino ECU for my '69 T100. It has several clever and unique features. Derry. PS well I hope it does by the time I finish it, I've been at it long enough! .
My God, this guy deserves a medal as big as a dustbin lid. Programming an Arduino to leak oil has gotta be a first ? |
Steve Withnell | 23/05/2014 21:21:23 |
![]() 843 forum posts 222 photos | Don't do electronics once workshop weather arrives When winter arrives, I have some radio's to repair / refurb Kenwood TS00G (blown PSU) Heathkit HW101, sideband oscillator crystals need setting correctly in the filter passband and then what to do with that old Pye basestation....
Steve G0AIN |
john fletcher 1 | 23/05/2014 21:40:46 |
794 forum posts | Not in the summer, but make my own battery powered loco speed controllers during the cold winter months. I would like to link up with others who do the same, to possible exchange ideas. |
WALLACE | 23/05/2014 21:49:03 |
304 forum posts 17 photos | Fitting a Leak Troughline tuner chassis into a new case with a stereo decoder, new power supply, regulated heaters, extra choke for HT smoothing...etc etc... Bit of a waste as sooner or later, FM radio's going to be pulled but it's giving me something to do ! W. |
Andrew Johnston | 23/05/2014 23:00:45 |
![]() 6603 forum posts 701 photos | Hmmmm, not sure if I should reply to this thread as I don't 'dabble' in electronics, but do it professionally. I have a couple of spare time projects on the go: 1) An electronic ignition system based around a M0 core ARM processor and an avalanche MOSFET. The aim is to eliminate the shortcomings of the simple Darlington transistor ignition systems and, most importantly, use an ignition coil that has a 10:1 winding ratio between secondary and primary. A home designed spark plug is also part of the equation. 2) A simple processor circuit with 'constant current' drives for white and red LEDs in lamps for my traction engines while simulating the intensity variations of an oil lamp. Professionally I have at least half a dozen circuits in progress as well as mechanical design and 3D printing, but of course I am not at liberty to say what they are specifically. But I can pick out a few general sub-areas: 1) Isolated power supply 48V to 7.4V, at 2A, with isolated measurement of output voltage and current. 2) Circuit for accurate measurement of low currents, ie, a few nanoamps 3) Digitally controlled power supply from 0 to 10V at 500mA and which will follow a 1kHz control signal - current design uses less than half a square inch of PCB, just as well since there are eight PSUs per PCB 4) Several processor designs using a M4 ARM core processor with RMII interface to WiFi, SDcard, USB2.0, GPS and other interfaces 5) Lots of precision, better than 0.1%, digitally controlled analogue AC drive and sensing circuits 6) Lots of bogstandard switch-mode power supplies 7) And all the PCB layouts for the above - an interesting mix of switch-mode power supplies, digital signals in the tens to hundreds of MHz and precision low level analogue electronics all within an inch or two of each other. The biggest problem with electronics today is that I can't see the darn components. Everything I do is surface mount and the components just keep getting smaller. That's why I am building 4" scale traction engines, at least I can see the parts. Regards, Andrew |
Another JohnS | 23/05/2014 23:09:20 |
832 forum posts 56 photos | Just received an Arduino Leonardo, as it can emulate a USB keyboard. Just so that I can turn on myLinuxCNC powered CNC mill, and have a couple of buttons for homing, zeroing DRO, doing the spindle speed adjustments, etc. I do have an MPG hand controller, but when doing things by manual methods, I find my keyboard/mouse setup inconvenient. There are other ways of putting inputs into LinuxCNC, but this is one way, and I'll see how it goes. (although I have a few Arduinos kicking around (make Lenz DCC controllers with them, amongst other things) the Leonardo allows me to mimic a USB keyboard) JohnS. |
Danny M2Z | 24/05/2014 01:02:28 |
![]() 963 forum posts 2 photos | G'day. Redesigning my (over 30 years old) glowplug driver for more modern components such as a switchmode IC and FET output. With that in mind I downloaded LtSpice to model the circuit design, it's available from **LINK** - very good. Also making an ignition coil winder to suit a small lathe, using an ex-baitcaster fishing reel level wind mechanism to distribute the turns. Regards * Danny M * |
Les Jones 1 | 24/05/2014 09:38:26 |
2257 forum posts 156 photos | Hi Andrew, Les |
