ChrisH | 15/05/2014 19:28:08 |
1018 forum posts 30 photos | Could someone tell me how the "Ignore Member" option works please? If someone has been 'ignored', is that forever or can the ignore command be removed? Chris Edited By ChrisH on 15/05/2014 19:28:31 |
JasonB | 15/05/2014 19:35:02 |
![]() Moderator 22747 forum posts 2653 photos 1 articles | If you go to My Posts along the green bar and click that the page that comes up has a link to your list of ignored members where you can reinstate them by clicking the X
J Edited By JasonB on 15/05/2014 19:38:23 |
NJH | 15/05/2014 19:57:29 |
![]() 2314 forum posts 139 photos | The problem with the " ignore member" option is that you will put " holes" into the thread you are following. So you will not see the posts from the " ignored" member but you will, of course, see replies to that member's posts by other members. I've only ignored one member in all the time I've been here and in the end I found it easier to leave them in and just mutter under my breath. Hope this is of some use to you which it may be - if it's not ME that you want to ignore! ( in which case of course you will not have seen this) Norman Edited By NJH on 15/05/2014 19:59:38 |
ChrisH | 15/05/2014 20:02:53 |
1018 forum posts 30 photos | Many thanks to you both, I knew it had to be an easy answer! And no Norman, it was not you I was ignoring! I had inadvertently ignored someone I didn't want to ignore and wanted to reinstate - have no ignored members now Chris |
Involute Curve | 16/05/2014 09:17:20 |
![]() 337 forum posts 107 photos | who answering Chris |
