Myford Super 7 tailstock barrel key
MattK11/05/2014 16:17:37
39 forum posts
7 photos
Hi,
I hope one of you very knowledgeable chaps can help. The tailstock barrel on my Mk.1 Super 7 has started to rotate. When I took a look on mine the key lock is a two piece affair which appears to be inserted from the outside and wedges together and looks like it has worked its way out a bit. It does not look particularly worn. Would I be right in just tapping it back into the hole (aligned with the barrel of course)?
I also remember buying a replacement bit to make an order up once but this looks like it is inserted from inside the barrel. Is this a later modification in how this works?
Apologies if my explanation is not very clear.
Matt
daveb11/05/2014 17:39:03
623 forum posts
10 photos
If viewed from the side, the barrel lock is T shaped. If it's lost the 'ears' you will need a new one. Fairly easy to make.
Sorry, not clear. The item is one piece, yours is broken.
Edited By daveb on 11/05/2014 17:40:44
Jon Gibbs11/05/2014 17:41:58
739 forum posts
Does this help?...
Jon
Swarf, Mostly!11/05/2014 17:50:50
534 forum posts
47 photos
Hi there, MattK,
The Mytholmroyd Myford web-site shows that the tailstock keys for the Super 7 and the ML7 are different. In fact, they give two separate part numbers for the ML7 key.
I suggest that caution is needed here!
Best regards,
Swarf, Mostly!
MattK11/05/2014 18:35:57
39 forum posts
7 photos
Thanks for the replies. Very helpful. Interestingly the spare that I have (which I managed to find) is one piece and has the 'ears' as described. The one that is in there though was clearly designed as two pieces and is not a broken version of the spare I have. It is similar to the replacement without the ears but the whole thing cut diagonally so as it is tapped in it would tighten in the hole. I wish I had taken a picture now but I tapped it back in and the barrel won't rotate now. If it works loose again I will see if my spare fits.
Matt
EngineDIY
