Copper pipe selection
for steam fittings
GaryM08/05/2014 15:12:35
314 forum posts
44 photos
Hi,
Simple question that I cannot find the answer to anywhere.
A while ago I bought some copper pipe for connecting to the S50 that I'm making (on hold at the moment).
The pipe I bought is 5/32" OD 0.014" wall thickness (28 SWG ?) from Reeves as here
Later I thought I might use 1/8" pipe instead so at last years Midlands show I bought some 1/8" OD from Blackgates. However this pipe has a much thicker wall (~1/32" and is coiled whereas the Reeves pipe is dead straight.
Which is the correct sort to use and does it matter?
Note this is for connecting pipe not a potential boiler.
Thanks for any replies.
Gary
Anthony08/05/2014 16:26:40
6 forum posts
I built the S50 last winter, and used car brake pipe for the inlet and exhaust, easily obtained and threads really good.
GaryM08/05/2014 16:43:49
314 forum posts
44 photos
Hi Anthony,
Thanks for the reply, but I don't want to thread it. I want to silver solder a union to it.
Gary
GaryM08/05/2014 16:48:32
314 forum posts
44 photos
Your S50 looks very nice by the way. I particularly like the main bearing caps and the cylinder cleading and banding.
Gary
Neil Wyatt08/05/2014 19:41:10
18404 forum posts
718 photos
78 articles
The cunifer pipe ought to silver solder easily (at least I hope so - I have several feet retained as future steam pipe!)
AndyP08/05/2014 20:37:36
189 forum posts
30 photos
Gary
Using the formula and data here I calculated a safe working pressure of 738 psi for the thin wall 5/32 tube and no doubt the 1/8 would be higher so your choice.
Incidentally if you want dead straight copper pipe in the smaller sizes like this then at the expense of the end couple of inches just clamp one end in the vice and grip t'other end with favourite grips and pull - at some point you will feel a 'give' and there you go - straight tube.
Andy
Neil Wyatt08/05/2014 21:14:29
18404 forum posts
718 photos
78 articles
Alternatively, for about 12" or so of tube, put it on a clean flat surface (e.g. a bit of worktop) and place something heavy, clean and flat on top. Rioll back and forth and the pipe will become very straight very quickly.
julian atkins08/05/2014 22:27:22
1235 forum posts
353 photos
if you pop into your local model shop you can get KS copper pipe 1/8"dia in thin wall section.
incidentally 3/16" dia thinwall stuff seems to be unobtainable these days unless someone knows of a source? ive very little of this size left.
cheers,
julian
John Baguley09/05/2014 02:40:29
475 forum posts
50 photos
Julian, the last lot of thin wall tubing I purchased was from Doug Hewson a couple of years back and he had 3/16".
Maidstone Engineering list 3/16" x 26swg as well.
I tend to use thin wall all the time as you can go down a size and still have the same bore as the thicker stuff.
GaryM09/05/2014 10:08:10
314 forum posts
44 photos
Thanks for the replies.
AndyP: I think I should be OK with 20psi then wink I might try your idea for straightening at some point, just out of curiosity.
Julian: Yes, I think the 5/32" was KS pipe, so I know you can get it.
John: "I tend to use thin wall all the time as you can go down a size and still have the same bore as the thicker stuff" Hadn't thought of that.
I just thought one sort might be easier to bend than the other and there seemed to be no guidance on any suppliers web sites. For that matter the whole subject of piping, unions, valves etc. never seems to get a mention in books or on web sites. Loads of build logs on engines and boilers but nothing on connecting them. Article Neil?
Off to Harrogate now. smiley
Gary
Neil Wyatt09/05/2014 10:30:43
18404 forum posts
718 photos
78 articles
I have a very old ME article on 'standard unions' for steam pipes. I used it to make unions for my 10V, but on later models I used flanged joints as closer to scale.
If I can find it again, I'll put it up on this website.
If anyone wants to write up this subject afresh, it's probably an ME article rather than MEW.
EngineDIY
