Chronos
stephen. | 22/04/2014 19:45:50 |
24 forum posts 12 photos | I was just wondering if any of you have had good or bad experience with the quality of drills and milling cutters suplied by Chronos as they look to be good value. Or would i regret it after. I have had bad experience with taps and dies from somewhere else. Your advise is much appreciate Kind regards Stephen |
NJH | 22/04/2014 20:13:23 |
![]() 2314 forum posts 139 photos | I've not had a problem with Chronos in the past however only you can judge what you find to be a quality product. Just choose one or two items to start with and, if you find the quality acceptable, then make them one of your preferred sources. Regards Norman |
Phil Whitley | 23/04/2014 21:53:35 |
![]() 1438 forum posts 147 photos | No experience with Chronos, but I bought a set of tin coated drills in a metal hinged box from LIDL Phil |
GarryC | 23/04/2014 22:04:03 |
![]() 740 forum posts 1043 photos | Hi Steve Have sent you a PM. Cheers. Allan. |
