JC Uknz 1 | 02/01/2014 07:44:32 |
![]() 54 forum posts | Been using metric for years but always fould up when calculating a volume. Currently have a boiler 50mm diam and 150mm long 25x25x3.142 x150 gives me 2904562.5 Now the bit that trips me .... converting the cubic mm to litres Is it 1000x1000x1000? That gives me 0.0029045 which seems awefully small. Judging from my one litre milk bottle it could be about a quarter to a third litre Boiler for Mamod modification accourding to Aussie boiler regs must not be bigger than one litre. Side note ... I know Manods go well as they are but this is a Mamod Garrett Your help much appreciared.
David Jupp | 02/01/2014 08:06:05 |
835 forum posts 17 photos | 1 ltr = 1000 cc = 10cm x10cm x10cm = 100mm x 100mm x100mm.
Answer should be 0.29 ltr or so. |
clivel | 02/01/2014 08:07:05 |
343 forum posts 17 photos | Hi JC, 25x25x3.142 x 150 is 294562.5 mm3 not 2904562.5 somehow an extra zero crept in there. 1 litre=1000000 mm3 so your boiler should be 0.2945625 litres Clive |
Steamgeek | 02/01/2014 08:10:34 |
45 forum posts 4 photos | I make the calculation 0.294 litres, you appear to have an extra 0 in your calculation ( after the 9 ) The conversion from cubic mm to litres is 10E-6 ( move the decimal point six places to the left )
JasonB | 02/01/2014 08:10:43 |
![]() Moderator 22751 forum posts 2653 photos 1 articles | If you work on the fact that 1 litre takes up a space 100mm x100mmx100mm you can work it out a s 0.25 x 0.25x 3.142 x 1.5 =0.295lts or do it as you have in mm then divide by 1,000,000 (100x100x100) |
Gary Wooding | 02/01/2014 08:15:49 |
983 forum posts 254 photos | Posted by JC Uknz 1 on 02/01/2014 07:44:32:
Now the bit that trips me .... converting the cubic mm to litres Is it 1000x1000x1000? Not quite. You're 1000 times too small - (and you inserted a zero between the 9 and the 4). 1 ltr = 1000cc 1cc = 1000 cubic mm, so 1ltr = 1000 x 1000 cubic mm. So your boiler = 0.2945625ltrs. For volume measurement its much easier to work in cm rather than mm. In which case your calculation would be 2.5x2.5x3.142 x15 = 294.5625cc = 0.2945625ltrs. |
John Haine | 02/01/2014 09:09:51 |
4675 forum posts 273 photos | Er, that would be 1E-6... |
Ady1 | 02/01/2014 09:45:55 |
![]() 5091 forum posts 736 photos | 1000cc = 1 litre, like a car So keep things as cubic cm 2.5 *2.5 *3.14= 19.63 cubic cm *15cm = 294.52 cubic cm, about 0.3 of a litre simples! |
speelwerk | 02/01/2014 10:28:33 |
443 forum posts 2 photos | 1 litre=1 cubic dm, so if you start the caculation with all the dimensions in dm (decimetre) then your answer is in cubic dm which is equal to litres, 25mm=2.5cm=0.25dm. Niko. Edited By speelwerk on 02/01/2014 10:29:53 |
Michael Gilligan | 02/01/2014 11:06:53 |
![]() 20183 forum posts 1053 photos | JC U, It'sprobably obvious by now; but I think it worth noting that your original division by (1000x1000x1000) gives the volume in cubic metres ... and one cubic metre is roughly the size of those one tonne bags of sand that they crane off the delivery waggon. Incidentally, for the purposes of boiler volume, I wouldn't worry about expressing litres to the seventh decimal place. [just think what a tiny volume that last place represents]. !! As MikeW suggests [and you already knew from your Milk bottle] ... Domestic containers are very useful for the "sanity check". MichaelG. |
S.D.L. | 02/01/2014 13:11:50 |
236 forum posts 37 photos | Posted by JC Uknz 1 on 02/01/2014 07:44:32:
The easy way is to remember 1000 litres = 1 cubic meter = 1 tonne of water =1000kg This makes sizing tanks very easy So if working by dimensions work in meters and multiple by a 1000
eg 0.025 x 0.025 x 3.142 * 0.150 = 0.000294562m^3 multiply by 1000 gives 0.294 liters this saves worrying about no SI units or units that you don't use much. The easy way is to weigh boiler empty fill then weigh again difference is weight of water 1 litre = 1kg = 1000 grms so if the difference was 294g would be 0.294lts
Steve
Russ B | 02/01/2014 13:38:12 |
615 forum posts 26 photos | And the winner of the quickest combined mistake spotting and volume calculations goes to .....
jason udall | 02/01/2014 17:35:40 |
2031 forum posts 41 photos | 50 mm * 150 mm.....about a drinks can...300 ml 0.3 l Btw 200 l " forty gallon drum"..seems much more than a cubic meter let alone a fifth. . |
jason udall | 02/01/2014 17:40:43 |
2031 forum posts 41 photos | Just checked ( my own disbelief) 44 gal imp 55 gal us 210 l 24 " dia 36" high... Funny seem much bigger..but there goes |
Stub Mandrel | 02/01/2014 19:02:45 |
![]() 4315 forum posts 291 photos 1 articles | It cheers my Imperial sensitivities to see so many 'up to date' metric head advocating the long-deprecated cubic centimetre! Neil |
JC Uknz 1 | 02/01/2014 19:29:48 |
![]() 54 forum posts | Thankyou all for rushing to solve my problem .. the thing to remember apart from the obvious decanting and filling up a known container ... would work except I have only got as far as cutting the tube and one end .... .. thanks again Jason that doesn't relate to me as I drink from glass stubbies The extra zero comes from my fingers inaccuracy and my brain not checking what they had done I will remember what Steam Geek wrote "The conversion from cubic mm to litres is 10E-6 ( move the decimal point six places to the left )" ... the first bit is above me but the bracketted makes sense |
JC Uknz 1 | 02/01/2014 19:40:28 |
![]() 54 forum posts | Just realised I could seal one end of he tube with gladwrap and do the decanting in to my 300ml jug. I remember my first use of metrics was at school during WWII in Mech Drwg when I 'thought' the millimeter markings a much easier way of measuring drawings than the imperial on the other side ... I guess it relates to I still have ten fingers and ten toes despite my activities of the following years. I wonder if it was a metrician's plot that the imperial side of theschool ruler was beveled and flopped around whereas the metric side sat flat on the paper
Falco | 02/01/2014 20:58:05 |
65 forum posts 7 photos | The following was given to me as an explanation of how the metric system ties together in the practical world. It may help anyone not using to it to visualise the connection between length , volume and weight in the metric system. The weight measurement is correct only if the contents are water. A little cube box with sides 1 x1 x1cm. will hold 1ml. of water. The water contents, (excluding the weight of the actual box), will weigh 1 gram. (Think sugar lump) A cube with sides of 10x10x10cm. will hold 1000 ml. (1 litre), and will weigh 1000 grams or 1 kilogram.(kg). (Think milk carton) A cube with sides of 100x100x100cm, (ie. 1x1x1metre) will hold 1,000,000ml, or 1000 litres and the water contained will weigh 1,000,000 grams, or 1000kg or 1 tonne, (Think of the builders sand bags mentioned by MichaelG ) John
stevetee | 03/01/2014 00:00:51 |
145 forum posts 14 photos | This is my problem with the metric system, the calculation is easy as all ( well most then) of the units are related to one another . No poundals or degrees f or calories to struggle with. Making sense of the answer is where the problems begin. I think that any system that uses the same unit to measure the height of a kitchen work top (900mm) as is used to measure the thickness of a piece of paper (0.01mm) is bound to suffer from problems of where does the decimal point lie, how many zero's?. In the case of this boiler it's not 2.9 litres ( half a gallon) or 0.029 litres ( half a teaspoon) so it must be .29 litres., but you do have to jump the decimal point 5, 6 or 7 places to get an answer that makes sense. I actually rang up the BBC one morning because there was a government minister and a presenter on the news discussing keeping a jerry can of petrol holding 201 litres in your garage( remember the tanker drivers strike). Some idiot had written 20 litres down as 20l , read out on the radio as 201 litres and neither of them realised they were talking about a volume of around 40 gallons, try picking that up. We used to have a system with measurements like 'An inch and seventeen thirtytwos, plus or minus five thou'. I mean where could that go wrong Edited By stevetee on 03/01/2014 00:01:43 |
speelwerk | 03/01/2014 00:23:46 |
443 forum posts 2 photos | The person writing 20litres as 20l is doing it correct, the same goes for grams, it is 20g not 20grms. Niko. Edited By speelwerk on 03/01/2014 00:24:33 |
