Forum sponsored by Allendale Dec 6th
3 1/2 inch small boilered TICH
Construction of TICH according to the words and music by LBSC
Ryan Norton18/12/2018 09:10:16
190 forum posts
774 photos
This weekend the treads were rough cut with a square profile slightly oversize.
Ryan Norton02/01/2019 08:24:04
190 forum posts
774 photos
Seasons Greetings to Everyone! I hope you all had a great December break!
During my time off I got a little bit ore done on the first driving car bogie.
First the treads were cut and using a gauge confirmed to be OK.
With the wheels finally complete, they still looked like they needed something more. So I made a recess in the front side of each wheel and painted them. This is what they needed!
The Axles were then turned to their final sizes and the wheel and bearing seats turned to within their press fit tolerance. I did the final sanding with water paper to give a good finish. A lead taper of 1 degree was also turned on the end to guide the wheel during pressing.
Finally, all the parts are complete.
I will paint the axles and then press the wheels and bearings on to complete the assembly.
Weary02/01/2019 09:09:11
295 forum posts
Excellent results!
Can I ask where you got the wheel-gauge from? Or is it home-machined?
Phil
Ryan Norton02/01/2019 09:13:12
190 forum posts
774 photos
Thanks Phil.
The wheel gauge was designed by a friend of mine and laser cut from stainless steel.
It has 3 1/2 inch. 5 inch and 7 1/4 inch tread profiles as well as engraved marks for the chamfer and thickness of wheel.
Very useful.
Ryan Norton06/01/2019 19:09:45
190 forum posts
774 photos
The axles were first masked and then coated with etch primer.
Following the etch primer, they were sprayed with four coats of gloss black QD enamel.
A wheel press was then made from some angle and threaded rod to press the wheels onto the axles.
Following the wheels, the bearings were pressed to the axles.
Finally the bogie was assembled.
All it needs now is a coat of paint on the side frames, bearing covers and stretcher and it is good to go!
..... and then I need to make another one cheeky
Jon Lawes06/01/2019 20:03:27
333 forum posts
What a lovely job, well done.
Ausee.com.au
