supercharged V12 2 stroke
Methanol burning beast!!
dean clarke 222/04/2014 07:25:49
155 forum posts
330 photos
Hey thanks for the info, yea i was wondering about the exact same thing but thought i'd just try the homebuilt option first as i need to fiddle around with the drive speeds. Once the drive speed/ratio has been finalised i will probably do just what you have suggested and go to a toothed belt drive.
cheers
dean
Doubletop22/04/2014 11:13:32
417 forum posts
4 photos
Dean
Try these guys **LINK** plenty to choose from in stock, good prices and they'll ship here. It's where I got my belts and pulleys for the Lynx
Pete
dean clarke 224/04/2014 08:32:49
155 forum posts
330 photos
Cheers mate thanks, I'll check them out
cheers
dean
dean clarke 225/04/2014 06:55:30
155 forum posts
330 photos
Well got a bit sidetracked on the v12 project, (well kind of). Thought i'd start on the engine mounting system for a bit of a change from engine parts and wanted to set this engine up on an aircraft style of engine mount. These will be mounted onto a firewall looking stand which will have a fuel tank and ignition system installed as part of the display mount. here's a couple of photos of the mounts at the first stage, ready for cleaning up and painting.
cheers
dean
dean clarke 229/04/2014 11:04:47
155 forum posts
330 photos
Well been rather productive over the last few days and have managed to complete the engine mounts and lugs. These are now ready to be fitted to the red mahogany stand and photos will follow as soon as i have the stand finished. Then onto the tank assembly and then back to making engine parts.
cheers
Should look reasonably good when its all done, here's hoping anyway.
Dean
Edited By dean clarke 2 on 29/04/2014 11:05:19
Danny M2Z29/04/2014 13:43:02
803 forum posts
282 photos
G'day Dean.
A true labour of love. What sort of prop are you going to set it off with and what size?
A carved laminated mahogany job with brass protectors would maybe do it justice?
Regards * Danny M *
dean clarke 209/05/2014 10:51:40
155 forum posts
330 photos
Yea maybee i'll laminate a walnut and white ash or red mahogany and white ash with nice brass protectors, that would look great. I think i'll concentrate on getting it running first though. Couldn't resist a couple of display stand progress shots so here they are. Working on the tank at the moment.
cheers
dean
dean clarke 210/05/2014 15:33:11
155 forum posts
330 photos
Ok so got a bit of time in the shed today and made a start on the fuel tank assembly.I decided that a tear drop shape for the tank would look quite nice so went ahead and started making this. Below are some progress shots and i think it will look very nice mounted on top of the brass side panels, these will end up machine turned to give that nice swirl effect on the side panels. The tank and all fittings will be bright polished.
thanks
dean
The two small holes in this last shot are for the fittings of the sight glass fuel level gauge. Fuel feed line and vent pipe still need to be added and also the mounting brackets.
dean
dean clarke 224/05/2014 02:14:48
155 forum posts
330 photos
Yay a bit more time in the shed and a bit more completed on the v12 project. I have managed to complete the tank assembly and have got a good way towards getting the finish put on the whole mount/tank assembly. A friend of mine made the suggestion that engine turning would look rather nice on the two brass sides of the tank mount, turns out he was right ( i reckon anyway) As this was my first foray into this kind of finishing a bit of time on the net and a few experiments later i found that a piece of dowl turned to the required dia and fitted to the mill worked well enough. I couldn't resist assembling the engine and mounting it with the tank etc to see what it looked like. Below are a couple of photos of the test assembly.
cheers for now
dean
Now it really is onto the rods and pistons.
Dean
dean clarke 215/06/2014 08:28:34
155 forum posts
330 photos
Well it's been insanely busy round here lately so not much time has been allowed in the shed but i have never the less been able to make a start on the conrods. photos below show the progress to date.
next step is to deburr them and radius the big end, drill and tap the bolt holes, seperate the big and cap and ream to final size. then its onto seperating the conrods from their partners and radiusing the little ends. then onto the pistons and carbs, fuel rail and ignition rails, plug inserts and then the breathing of life into the beast.
cheers for now
Dean
dean clarke 211/07/2014 13:08:39
155 forum posts
330 photos
Well as it's been some time since i posted any sort of update so i figured it was probably about time i got to it. Soooo, here's the latest development on my blown V12 2 stroke engine build. After a great deal of sidetracking and slaving i finally slipped the collar long enough to sneak into the shed and finish the set of conrods and gudgeons, photos below. Next its laps for the liners and pistons, then make and fit the pistons.
Cheers for now
Dean
Edited By dean clarke 2 on 11/07/2014 13:12:21
David Colwill11/07/2014 16:48:33
609 forum posts
33 photos
Good to see things happening again. I've been watching this from the start and am looking forward to seeing the finished engine!
David.
dean clarke 212/07/2014 01:32:33
155 forum posts
330 photos
You and me both. Gets quite frustrating not being able to spend the time working on it. Life just gets in the way too much sometimes, oh well keep plodding along.
Dean
Edited By dean clarke 2 on 12/07/2014 01:33:55
dean clarke 209/08/2014 06:36:47
155 forum posts
330 photos
Well i managed a small amount of time in the shed to work on the v12 project this last week and have managed to make the cylinder liner lap and am now making the piston lap. then i will start on the actuall pistons themselves, will update with photos in the next couple of days.
cheers for now
dean
Russ B05/09/2014 13:49:55
564 forum posts
21 photos
Dean,
Your "couple of days" time scale is about the same as mine!
No rush or anything, I'm only on the edge of my seat cheeky
Looking absolutely superb so far!
David Tweddle 107/09/2014 09:27:40
3 forum posts
Lucky you Russ I keep falling off mine.
Love it Dean, just loving it.
Thanks from David
dean clarke 219/09/2014 11:00:58
155 forum posts
330 photos
Well, Ok, so its been a little more than a few days since I last updated this thread and so I will start with apoligies to those of you who are suffering posteria pain from prolonged perching on the edge of chairs and also to those who have had the misfortune of having lost their balance from said procarious perch and fallen to the floor in waiting. Life does tend to get in the way of such fun things as shed time but then we all must suffer the trials and tribulations that deprive us of model building in some form or other, LOL. Well i have been able to finish making the cylinder lap and the piston lap as the photo below will show.
I have also test fitted the conrods to the crank to make sure they turn freely on the shaft and also don't foul the case in any places. guess what? i have to modify the case just slightly to avoid the rods collecting it on one side of the revolution circle. Oh well.
The other thing that s has been a major consumer of spare time over these last few weeks has been the total revamp of the workshop! basiclly i just got sick of spending more time looking for a tool than i spent using by about 600 percent........ usually the fastest way to find it was buy another, funny how that works aye!!!. well i haven't quite finished but I think we are mostly there, YAY now its back to making some swarf, should have achieved a bit more on the engine build this coming week. Here's a couple of photos of the workshop.
cheers for now
bye
dean
Edited By dean clarke 2 on 19/09/2014 11:02:31
dean clarke 220/09/2014 06:16:20
155 forum posts
330 photos
Just thought I'd put up this photo of all the parts made so far for the v12. I have stripped the engine and am now carrying out the mods to the crankcase to accomodate the rods . The next task after that will be to hone and lap all the liners and then make and fit the pistons to each of the rods and their mated liners. After that will be cutting the slots in the supercharger rotor and making and fitting the vane blades. Then the carbs will be finished off complete with the fuel feed rail. The last task I think will be making the ignition rail for the glo plugs then fingers crossed to the start up time.
cheers for now
dean clarke 222/09/2014 10:04:43
155 forum posts
330 photos
hey guess what? ................................ It's only been a couple of days since my last update ha ha ha...... So i have done the crankcase mods required to let the conrods rotate full circle without collecting anything on their way round, and it didn't even take me weeks to get there, YAY !!!!!!!!! so now i am honing the liners and lapping to final polished finish. this will be to a mirror finish.
So I relieved the top portion of the crankcase bore and also both side angles to give the extra room required. Turned out to be an easy fix and very straight forward. Now quickly quickly back into the shed before i'm noticed inside and get absconded into something else.
bye for now
dean
dean clarke 209/10/2014 01:01:20
155 forum posts
330 photos
OK so i have a fairly decent excuse for the delay in updating this thread this time, called a burst appendix!!! which as it turns out was nearly responsible for me checking out of life way too early!!!!! Thankfully i have learned to listen to my wife in times of crisis and let her take me to the docs who immediately put me in an ambulance and sent me on my way to hospital. Surgery on the same afternoon saw me alive but stuck in hospital for the next week, but alive none the less. so just before i went to hospital i had started to make an engine assembly stand so i didn't need four pairs of hands to put these engines together. Below are some photos of said stand with the V12 fitted and undergoing final assembly. hope to have this engine finished and running by the end of November, here's hoping anyway.
cheers for now
dean
The brass gear looking thing is just a fitting to enable turning the engine over by hand without having the prop fitted. Makes life a bit easier when assembling the engine.
dean
Edited By dean clarke 2 on 09/10/2014 01:03:00
Ausee.com.au
