Micro Vice idea
Stub Mandrel28/10/2013 20:31:18
4311 forum posts
291 photos
I saw a really neat idea in a 1996 ME article by H D Bickley
He needed a very small vice so he could bend up a small bracket that would have fouled the vice jaws, it wasn't worth making a block to shape it round for a 1-off.
His idea was to grip a pliers in the vice, pointing upwards, so that the vice jaws held it shut.
Very neat and I can think of several times in the past when this would have saved me much grief - probably worth making a small pair of 'slave jaws' that work in the same way.
Stackerjack28/10/2013 21:54:24
14 forum posts
Neil,
Another good idea for extending the possibilities of a vise, is when cutting sheet metal.
Clamp one arm of the tinsnips in the vise, horizontally, and operate the other arm with you free hand.
Jack
John Stevenson28/10/2013 22:11:52
5068 forum posts
Neil,
I use these quick clamps from ARC a lot.
They are one of those tools that don't really have one specific purpose and you will find that different people use them different ways.
Very handy when milling using them in a vice with a work stop. It means you can take them out for measurement or try on a job and then put back if another cut is needed.
Usual not associated bumph other than the fact I'm still trying to get me two quid back.
Russell Eberhardt29/10/2013 08:08:11
2726 forum posts
86 photos
I have a collection of mostly homemade toolmakers clamps which I find ideal for that purpose.
Russell.
Stackerjack29/10/2013 08:51:44
14 forum posts
Another method I use for holding parts is to grip a small pair of forceps in my bench vise.
This is extremely useful for tinning electronic components prior to soldering in place on the P.C.B. as the forceps soak up the heat, preventing the component from overheating..
I also sometimes grip the soldering iron in the vise, tip uppermost, for pre-soldering cables etc..
Jack
Ian S C29/10/2013 10:26:37
7468 forum posts
230 photos
I find a fly tying vice is handy for holding small parts, I also use it to hold small circuit boards while soldering the bits into them, a great extra set of fingers. Ian S C
Grizzly bear29/10/2013 15:15:04
293 forum posts
8 photos
Hi Everyone,
A Third hand tool is very useful, two small alligator clips mit magnifying glass.
Regards, Bear..
P.S. I like the new forum set-up.
Stub Mandrel30/10/2013 19:08:08
4311 forum posts
291 photos
My brother bought me one of those many years ago. I used to look at it and wonder what to use it for, and then I discovered how it helps with soldering and small siver soldering jobs -a total godsend!
John - now I understand what the 'quick clamp' is for.
David Clark 130/10/2013 19:11:57
3357 forum posts
112 photos
10 articles
Third hand tool in Lidl at the moment, I bought one today.
Under £6 includes I think a couple of crock clips, a soldering iron stand and a large magnifying glass.
Very heavy and very useful.
regards David
Michael Gilligan30/10/2013 19:33:50
19601 forum posts
997 photos
Posted by Stub Mandrel on 30/10/2013 19:08:08:
Variations on the theme, here
Ian S C31/10/2013 10:44:50
7468 forum posts
230 photos
Neil, gave one of those third hand tools to my Nephew, he's into War Gaming in a big way, and it gets a fair bit of use building his models. Ian S C
IanT31/10/2013 11:18:05
1946 forum posts
194 photos
Nothing to do with work holding - but I agree with David about the Lidl magnifier.
It's got a small battery operated LED light under it and is mounted on a vertical post held in a small (cast?) base. I've taken the soldering iron holder and spring clips off and just use the magnifier on my cutting mat to look at stuff more closely. My eyesight isn't quite so good these days and I've found it very handy.
They are £4.99 at my local Lidl's and I've been thinking of investing in another one to mount on a post on the boring table of the EW and similar applications.
IanT
rapid Direct
MIDLNDS GARDEN RAIL Jan 2022
JD Metals
