New Warco 290 Lathe
petro1head09/09/2013 13:36:57
749 forum posts
143 photos
Following on from my "Time for a new lathe" thread **LINK**
My lathe arived today
There were a futher two boxes on top of this, they were the stand. Nice supprise as I got the delux stand with draws
The stand alone probably weighs 50KG
Next task was to remove the packaging around the lathe, plenty firewood for a bonfire.
Once removed I knew that lathe would be heavy so decided to remove as much as possible from it.
The lathe stripped ready for some strong friend to come round and help move into the workshop which is in the back garden.
I will take some photos when I get it installed
JasonB09/09/2013 13:47:55
21431 forum posts
2448 photos
Put a bit of silicon sealer under the feet so any oil or coolant won't leak down through the bolt holes in the tray and cover the draw contents in oil.
Would like to see a couple of close-ups of teh cross slide scale as it looks like it will be hard to get to the lock and gib adjusters not to mention having to extend the tailstock a lot moreface 8
Russell Eberhardt09/09/2013 13:59:58
2703 forum posts
86 photos
Be careful of your back when moving it! Back problems never go away. Don't ask how I knowsad
It might be worth seeing if you can remove the motor as well. It's a heavy lump.
Russell.
JasonB09/09/2013 14:04:34
21431 forum posts
2448 photos
The motors come off easy enough
If you are using an engine hoist make sure the strap goes inside the lead/feed screw and glass scale as neither bend well
Edited By JasonB on 09/09/2013 14:05:03
petro1head09/09/2013 19:21:41
749 forum posts
143 photos
Well it was a heavy bugger, especially the motor end!
Anyway finally got it into the workshop and used an engine hoise to lift it on the stand
Threaded straps behind the lead screw etc
Glass scale????
However I can't get it to work! Plugged in, guard down, emergency stop checked. Plug fuse and lathe fuse checked.
Am I missing something?
JasonB09/09/2013 19:28:51
21431 forum posts
2448 photos
Have you got the end cover fitted as there is a micro switch just below the motor activated by a bit of metal on the cover. Switch to forwards, press the green button.
Glass scale = DRO scale along the back of the machine
petro1head09/09/2013 19:52:45
749 forum posts
143 photos
Yes, school boy error, had not fitted the end cover. Dooohembarrassed Just had a cuppa and thought about it logically. enlightened No way should I be able to run the lathe with the gears showing, Soon as I liooked again found the micro switch
Yes the web wa away from the scales
petro1head10/09/2013 09:37:17
749 forum posts
143 photos
Got lathe into its new home
Got a big throat
Here we go Jason
Indeed, its going to be a pitta to adjust but not the end of the word, not sure how else they could have done it
I have probably lost about 3" of movement of the tailstock but again workable. What is a pittly is the saddle buts up against the splashguard before hitting the headstock end
JasonB10/09/2013 13:08:20
21431 forum posts
2448 photos
The biggest problem with that loss of travel will be when working on small slender parts that need tailstock support. Its limited me several times and thats without a DRO scale in the way. The usual method is to mound the scale off the back of the cross slide so it does not foul the gibs & tailstock..
Have you got a pic of the saddle hitting the splashguard, I can't see why its does it on yours as my 280 will touch the headstock. The chuck guard and lead screw cover are what usually get in the way.
petro1head10/09/2013 15:43:10
749 forum posts
143 photos
To be honest I thing the scale is far too big, they must be able to produce something smaller
Photo of the saddle hitting the splash guard
Just a thought, if I do need to get the tailsock close to the work I could always mount it in front of the saddle if I did not need to use the saddle tooling
Edited By petro1head on 10/09/2013 15:45:13
Thor 🇳🇴10/09/2013 17:50:59
1409 forum posts
41 photos
Hi, your lathe looks nice in its new home. I have a similar lathe (HBM 290F), and as on yours the saddle hits the splash guard. With the splash guard removed I can move the saddle slighly closer to the headstock, but not much. The leadscrew cover is almost fully compressed when the saddle on my lathe hits the splash guard.
Thor
Bazyle10/09/2013 18:01:53
6036 forum posts
220 photos
Since you have found out how the interlocks work to stop the motor you could fit a microswitch to the cover for the saddle to contact just before the power feed crunch. If you look closely at the wiring diagram you might even find a pair of terminals in series with the interlocks that are just bridged with a wire - obviously provided for yet another safety gizmo that they decided to leave off.
JasonB10/09/2013 18:35:09
21431 forum posts
2448 photos
Just had a look at mine and the reason I can get upto the head is that I don't have the diagonal bump to the splash guard behind the motor. Also mine did not come with a leadscrew cover
It also seems like the new ones come a lot cleaner than mineembarrassed
Thor 🇳🇴10/09/2013 18:58:14
1409 forum posts
41 photos
Eh, well Jason, my lathe too is beginning to look like yours. Turned some cast iron, so mine is more gray now.
Thor
petro1head10/09/2013 21:08:26
749 forum posts
143 photos
I notice you max speed is 1950rpm Jason, on full chat does it show 1950 on the digital readout. Mine goes to 1800 but so far max is only 1650
Edited By petro1head on 10/09/2013 21:08:49
JasonB11/09/2013 07:27:51
21431 forum posts
2448 photos
I only bothered to use the higher ratio once when I first had the lathe. I tend to keep it in the lower range which is supposed to be 50-950 but I can get 48 - 1050 on a warm day. Check your belt is not too tight and it may want a while to bed in.
I have used a hand held tach against the chuck and the read outs are accurate.
walker midge
BOLDON
rapid Direct
JD Metals
