Lister cast piston
HobbyNut31/08/2013 00:35:09
113 forum posts
93 photos
I was sent a casting for a Lister piston by Ennech. He also emailed me the machining details.
I set it in the lathe and made the internal bore to size, so that I could set it on a mandrel.
I then took a piece of Alum bar and machined a mandrel
HobbyNut31/08/2013 00:37:23
113 forum posts
93 photos
The piston was then locktited onto the mandrel
Then a cut was taken, and machined down to 28mm dia.
HobbyNut31/08/2013 00:38:59
113 forum posts
93 photos
The ring grooves were then machined, and the OD polished with some 240 W&D.
HobbyNut31/08/2013 00:44:03
113 forum posts
93 photos
Unfortunately this did not end well. When I heated the skirt with my pencil torch to break it free, the piston and skirt parted ways at the lower ring groove. On inspection, I had gone 1 mm too deep on the id from the base of the piston, making that area too thin.
The casting was not at fault, I was, and the piston was a joy to machine, with only a few very small pinhole air pockets in the casting.
Oh well, I tried.
HobbyNut31/08/2013 01:49:02
113 forum posts
93 photos
The final pics.
MichaelR31/08/2013 08:48:42
370 forum posts
75 photos
After all that good work on the piston, why not have the only Lister fitted with a Slipper Piston.wink
Stick.
Ian S C31/08/2013 13:36:02
7468 forum posts
230 photos
Been there, done that, with the labyrinth grooves on a hot air engine piston, made the grooves .020" deep, instead of .010", I make the skirts of my pistons usually no thicker than .040", and if possible a little thinner. Just part of the job! Ian S C
HobbyNut31/08/2013 16:00:19
113 forum posts
93 photos
I am sure that the piston would work still being shorter and all. it is still long enough that it wont turn over in the bore, the only thing missing is the oil ring. I am going to try it "one of these days".
I have seen plenty of Ford and Chevy V8 racing pistons that are very short for the bore size.
Stub Mandrel31/08/2013 16:47:49
4307 forum posts
291 photos
You must be a biker! - Piston broke!
HobbyNut31/08/2013 21:18:52
113 forum posts
93 photos
Posted by Stub Mandrel on 31/08/2013 16:47:49:
Thats true....I am all of that!!!
Stub Mandrel01/09/2013 11:25:41
4307 forum posts
291 photos
Bear in mind the phrase may have a somewhat different meaning in your side of the Atlantic - p****d means drunk, not angry, in the UK!
Gordon Wass01/09/2013 11:34:29
57 forum posts
If it helps I've run a real full size lister with a piston like that, a bit of slap and a bit of oil burning but otherwise ok.
HobbyNut01/09/2013 16:02:18
113 forum posts
93 photos
Neil, I am an Aussie....nerd
Gordon, I have the Lister all apart at the moment, and I intend to fit that piston, just to see what happens.
Stub Mandrel01/09/2013 18:09:58
4307 forum posts
291 photos
Well that explains anything!
HobbyNut03/09/2013 02:11:09
113 forum posts
93 photos
That piston is in the engine. It seems like it is working OK, there is lots of compression now. Still wont run sad
Ennech07/09/2013 11:46:19
152 forum posts
135 photos
If there is more compression you may have to increase the injector pressure as this must always be greater than the cylinder pressure at injection point.
HobbyNut09/09/2013 07:09:30
113 forum posts
93 photos
Well, I am in the process of building a new head from steel, and a new injector, ala DUX. It does not have a moveable plunger. The pump needs a seal, and I will build a new piston for it also. I will then hook everything up, before fitting the head to check if/what the spray pattern looks like.
JasonB09/09/2013 07:42:27
17862 forum posts
1954 photos
How are you seeing what the spray pattern is like as you need to see whats comming out at the pressure inside the combustion chamber. Pumping into open air will not show how the injector works inside the engine.
J
Ennech09/09/2013 11:08:13
152 forum posts
135 photos
Picture from Gardner LW Instruction Manual (don't do this at home)
JasonB09/09/2013 11:12:07
17862 forum posts
1954 photos
That really only shows that there is no blockage in the lines.
Without testing the injector under pressure you won't know if the pump is producing more pressure than the engine compression or what the spray pattern is like.
J
