Three Jaw Independent Chuck
Doug Bauld12/08/2013 02:37:37
11 forum posts
26 photos
Looking for any information on the use and and avantage of the a Three jaw chuck.it's purpose.
I have one.
any coment appreciated.
Doug in Canada.
jason udall12/08/2013 09:12:03
2026 forum posts
41 photos
Its a chuck with three jaws..probably what is called self centering. .which answers to its purpose of holding round stuff for futher work...
The benefit of self centering means stuff is held with the center of the material in a defined place....
Michael Gilligan12/08/2013 09:33:28
16360 forum posts
712 photos
Doug,
Somewhat confused:
Chucks are typically either independent or self-centering
.... and three-jaws are usually [as Jason indicates] the self-centering type.
Do you really have a three-jaw independent ?
If so; could you please post details or a photo.
Edited By Michael Gilligan on 12/08/2013 09:34:06
NJH12/08/2013 10:47:26
2314 forum posts
139 photos
Michael
He doesn't say that it is a 3-jaw independant just that it's a 3-jaw. If it is a self centering then, its use is as Jason states. The only variation of that I know of is the Grip Tru which is commonly ( although not exclusively) a 3- jaw chuck.. So Doug - is this a 3-jaw self centring chuck which which has an additional adjuster next to each jaw? If so what you have is a chuck to be cherished!
Here is a pic.
You will see that, alongside the normal hole for the chuck key is socket for a hexagon key. This allows the micro adjustment.. If this is like your chuck just reply here and I will post the adjustment instructions.
Norman
112/08/2013 10:56:46
65 forum posts
Norman
The title of the thread mentions "independant".
Jim
JasonB12/08/2013 12:07:11
18868 forum posts
2069 photos
Could possibly be a 3-jaw combination chuck where each jaw can be adjusted separately and then a single key will move all three. Used for repetition of holding a round object off centre eg if you were making loads of eccentrics.
J
Michael Gilligan12/08/2013 12:16:58
16360 forum posts
712 photos
Posted by NJH on 12/08/2013 10:47:26:
Michael
Norman,
As per Jim's comment
NJH12/08/2013 12:38:16
2314 forum posts
139 photos
OK Michael - I'm in error here - I've never come across the combination chuck referenced by Jason so the only one to fit the bill, to my knowledge, was the Griptru. Hopefull we will be enlightened eventually. ( Although I've spent much of my life, fruitlessly, awaiting enlightenmentsad)
Norman
Edited By NJH on 12/08/2013 12:38:50
Michael Gilligan12/08/2013 15:34:16
16360 forum posts
712 photos
Hi Norman,
By way of some enlightenment ... whilst we wait for details from Doug
You might like this.
Doug Bauld12/08/2013 19:13:57
11 forum posts
26 photos
3 Jaw Ind Ckimgp0863.jpg3 Jaw Ind Ck3 Jaw Ind CkThank's Gentleman for your interest.
Some old very experianced Machinist have observed this Chuck with their Jew on the floor, one said that he feels that he had seen one while in the Navy but only vague about it.
This I beleave to be American and may possibly be associated with a Rotary Indexer for possibly Ecentric and Cam Grinding/Cutting??
Hear are the Photo,s as requested.
Steve Withnell12/08/2013 19:16:35
815 forum posts
217 photos
The only reason I use a three jaw chuck is for holding hex bar... I use a four jaw self centering for round and square bar and a four jaw independent for placing the workpiece where I want it rather than where the chuck wants it
Steve
Jo12/08/2013 19:46:31
198 forum posts
I also use my four jaw self centering for holding hex. The only advantage my three jaw has is the larger hole in the centre for allowing larger diameter work to be held further inside the body of the chuck, rather than having to stick out.
Jo
Doug Bauld12/08/2013 19:59:18
11 forum posts
26 photos
Gentleman I have mostly every chuck avaible, this one is close to being an odball.
My interest is in the Practical Theory and purpose design of this Chuck and it's purpose use.
Your technical theries and history of this chuck is required and appreciated.
Doug in Canada
Doug Bauld12/08/2013 21:14:08
11 forum posts
26 photos
My Mistery is Solved.
Many Thanks to those gentleman that responded professionly and constructivly, I particuly apreciate the input of discussion from both Michael and JasonB eith a high 5 to Michael for the look at This, that forced me to disect the Chuck and solved the mistery.
Thanks to all from Doug in Canada.
My
Michael Gilligan12/08/2013 21:43:30
16360 forum posts
712 photos
A fabulous find, Doug ... and thanks for the great photos.
We've all learned something today ... which is why we are here !
Michael Gilligan12/08/2013 22:07:11
16360 forum posts
712 photos
Doug,
Here is the icing on the cake ... Horton's Patent.
speelwerk12/08/2013 23:13:31
375 forum posts
You have to ask questions about its work holding accuracy, it is not only depended of the accuracy of the thread of each jaw, but also of the gearing, In a normal scroll chuck the accuracy of the gearing has no part ín the centering of the workpiece. Niko.
Michael Gilligan13/08/2013 05:35:27
16360 forum posts
712 photos
Doug,
Here is an intriguing PostScript
Michael Gilligan13/08/2013 06:08:34
16360 forum posts
712 photos
Doug,
One more gem for you.
Scientific American
JasonB13/08/2013 07:34:48
18868 forum posts
2069 photos
Of course it would have been easier to turn the key to see how it worked rather than pull it all apartblush
EngineDIY
