Stuart 'Victoria' : a beginners tale..
GarryC03/08/2013 16:26:39
740 forum posts
1043 photos
Well here goes. My main aim is just to complete the project and learn as much as possible along the way - ready for the next one..
Advice and comments (good or bad) are very very welcome - all the way through..
Day1.
Have machined, drilled and tapped the base..
Please excuse the photo quality, am using a very old iphone..
Edited By JasonB on 31/12/2014 10:14:28
Edited By JasonB on 31/12/2014 10:17:13
Russell Eberhardt03/08/2013 16:37:12
2607 forum posts
85 photos
You've made a good start Allan. Well done.
Russell.
BERT ASHTON04/08/2013 14:19:07
73 forum posts
47 photos
Hi Allan, I have sent you a e-mail via this site.Bert.
GarryC04/08/2013 16:40:03
740 forum posts
1043 photos
Thanks both.
Bert - I have replied...
GarryC04/08/2013 16:53:50
740 forum posts
1043 photos
Day 2.
The pedestal machined, drilled and tapped.
Not sure about very slightly counterboring the lower 'floor' holes. The holes are 6mm but for some reason my 6mm counterbore wont fit (I,ve not used a counterbore before, I thought the size referered to the hole size but maybe not?) - as it happens i've tried some bolt heads and they seem to sit nicely flush...
Bearings next..
Allan.
Edited By JasonB on 31/12/2014 10:18:03
JasonB04/08/2013 17:02:37
19538 forum posts
2136 photos
The guide on commercial counterbores are often sized to suit generous clearance holes so you would need something like a 6.6mm for it to fit.
The other option of you have a long enough slot drill or center cutting endmill is to use that to spot face around the hole.
I personally would also do a bit more fettling to remove the mould split lines which will also allow the washer and nut to sit better
J
Edited By JasonB on 04/08/2013 17:04:36
GarryC05/08/2013 17:34:47
740 forum posts
1043 photos
Thanks for the info Jason and yes I agree the lines need to be sorted...
Allan
GarryC05/08/2013 18:09:57
740 forum posts
1043 photos
Day 3.
I have struggled a bit with the bearings but they are now ready for drilling the fixing holes and final cleaning..
The first one I did was the most difficult, I made the mistake of not leaving enough protruding from the chuck to turn down the 1/8 'flange' on the bearing (is that the right word?). The result I had to remove and relocate in the chuck and this has I think resulted in a slight taper in the bearing, about 2 thou from one end to the other. Also I could not get my head around how to measure down to the flange. The result on the first bearing was I did not turn it down enough or was unable to repeat the same on the other side. The second one I made a much better job of by turning down to the top of the rounded section of the casting and repeating exactly on each cut. I'm sure there must be a way to have measured exactly. on Bearing no 2 I could not detect any difference (taper) from end to end of the bore and was much happier with this one. I am happy that both bores are at 90 degrees to the base and I have tried an 11mm bar through them and it fits nicely with no detectable slop, to my eye anyway. The crankshaft was supposed to be 11.1mm but I will have to make to 11mm now.
They will not look too bad on the model though when assembled (for a first project attempt anyway..)
I struggle with the dti each time and it takes ages to get runout right but hope this will get easier with practice..
Some pics -
The center of the bore marked out. I used this to bring the tailstock center to the punchmark for initial centering.
Resetting the bore to run true after facing and turning the other side.
Ready for drilling the fixing holes and final cleaning up.
Not the best looking I know but I have learned a lot, which is what this project is all about for me..
I would love to know though how I should have measured the turn down distance to the 'flanges'..
Allan
Edited By JasonB on 31/12/2014 10:20:42
JasonB05/08/2013 19:54:54
19538 forum posts
2136 photos
There are a couple of ways to get the measurement
The easiest is once you have made the initial cut across the whole face is to zero the top slide dial and then use this to put on the cuts, I'm not sure of the distance but it looks to be 1/8" or 3.2mm so take say 4 cuts of 0.031" or 0.75mm.
If you don't want to do the dials or just want to check the measurement I assume you have a set of digital callipers in which case the rod that sticks out the end as you open them can be used as a depth scale.
Regarding your tapered bore, when you get towards the final cuts with the boring bar run it through the hole several times without putting on any more cut as this will allow the " spring" in the tool to work its way out. You will also find setting the 4-jaw becomes easier, yo get to know how much to turn the key to get the movement you want.
Edited By JasonB on 05/08/2013 20:11:34
NJH05/08/2013 20:14:29
2314 forum posts
139 photos
Hi Allan
I think the Victoria is a lovely looking engine and will run slowly and majestically when completed. I am tempted myself and am drawn to the "Double" version - but it's a bit expensive! I don't know if you are aware but a very good book has been written on the construction of Victoria by Andrew Smith. Out of print now I think but still available S/H from Amazon ( at a price I'm afraid!). Without wishing to put a damper on the proceedings to date it is usual on these models to split the bearings. The bearing is cut horizontally across the centre of the cast hole, the edges cleaned up, and the two parts soft soldered back together. The hole is then bored , a tapping drill put through the caps and the two parts reheated to separate them. The bottom part is tapped and studs fitted whilst clearance holes are made in the top caps. As well as authenticity it also makes assembly much easier!
Cheers
Norman
GarryC05/08/2013 21:22:11
740 forum posts
1043 photos
Hi Jason
Thanks, it is the diameter of the 'flange' that I found difficult, I may be misunderstanding but are you refferring to it's width, which I was ok with..
I could not understand from where to zero the scale or how to get the distance from the corner of the flat base in the chuck to the ouside diamer of the flange ie. the start point of the cut to turn down the diameter. Hope that makes sense (I have my doubts!).
I used a 11mm reamer for the bore as the hole was so small.
Cheers
Allan
GarryC05/08/2013 21:30:27
740 forum posts
1043 photos
Hi Norman
Yes I wondered about this. The book I have 'building the Victoria' describes this but suggests that each bearing is supplied already in the two half's. The book is several years though...
I think that for me at the moment I will not complicate things and leave them as one piece! I agree with your comments though.
Something I will look to do on future projects...
Allan.
GarryC06/08/2013 16:32:50
740 forum posts
1043 photos
Day 4.
A little more progress..
Drilled the 'bearing' fixing holes, drilled and tapped the oil holes, removed the split lines at the pedestal base..
Tapping the oil holes.
Oil cups and test fitting the 'bearings' on the base..
Not beautiful but a few lessons learned..
Allan
Edited By JasonB on 31/12/2014 10:22:08
roy entwistle06/08/2013 18:25:17
1300 forum posts
I hope you are going to use studs and nuts on the finished engine rather than hex bolts
I built Victoria many years ago when it first came out
Roy
Stub Mandrel06/08/2013 20:31:59
4311 forum posts
291 photos
HI Allan,
Every part for your first engine will be a learning experience, all rewarded in full when it finally runs under its own power!
If you look for 'one size smaller hexagon' nuts and screws, you will find they look more in proportion They can be obtained from many of the usual ME suppliers.
GarryC07/08/2013 08:44:35
740 forum posts
1043 photos
Hi Roy and Neil
Thanks, I had not thought of doing that - but yes that sounds good, I will see what I can find..
Allan
Niloch07/08/2013 09:09:52
371 forum posts
Posted by NJH on 05/08/2013 20:14:29:
I too am attracted to the twin/double Victoria but the cost of the castings is prohibitive. Does anyone know of a design for a similarly sized horizontal twin which relies mostly on fabrication?
JasonB07/08/2013 09:15:41
19538 forum posts
2136 photos
If you had the drawings I would say it can all be fabricated, maybe buy just the cylinders and flywheel castings for an easy life.
Tubal Cain did do a series in ME about building a slightly different version which used a lot of scratch built parts.
Anthony Mount's Sir William can also be done by fabrication, drawings were in ME
GarryC07/08/2013 16:33:42
740 forum posts
1043 photos
Day 5.
The crankshaft next. It is supplied in 3 parts, the shaft, crankweb and crankpin.
The components as supplied.
The Crankweb casting as supplied.
After some cleaning up 1.
After some cleaning up 2.
Hope to get it on the lathe tomorrow...
Allan
Edited By JasonB on 31/12/2014 10:24:52
Edited By JasonB on 31/12/2014 15:05:23
GarryC08/08/2013 16:34:35
740 forum posts
1043 photos
Day 6.
The holes put through the crankweb and machined to size. I really struggled with how to mark out the 1 inch hole centres. No square edges to help and the holes at different heights (I drilled through and marked out from the boss side, was I wrong to do that?) - anyway it gave me a real headache. I would love to know how I should have gone about this.
Next have to drill the through hole for the crosspin to attach to the shaft..
Allan
Edited By JasonB on 31/12/2014 15:06:18
EngineDIY
