I need accurate 1/8" steel plate
ken king, King Design | 29/07/2013 10:58:15 |
![]() 144 forum posts 239 photos | Can anyone please suggest a source of accurate 1/8" steel plate (not 3mm), either G.F.S. (expensive) or some other description which fits the bill. I'm looking for enough to make four bolting plates, each about 21/2" x 31/2" . Slightly thicker plate capable of being surface ground to thickness would also be acceptable. |
Alan Reed 1 | 29/07/2013 11:14:36 |
10 forum posts |
This Ebay item may fit the bill
http://www.ebay.co.uk/itm/STARRETT-FLAT-STOCK-1-8-X4-X8-/321170392197?pt=UK_Trains_Railway_Models&hash=item4ac73f4485
JasonB | 29/07/2013 11:28:49 |
![]() Moderator 22560 forum posts 2634 photos 1 articles | You won't easily find 1/8" plate but Bright Mild steel flat bar is still readily available in imperial so you could use 2 1/2" x 1/8" this is likely to be withing a thou or so if thats good enough. Failing that most of the ME suppliers will have gauge plate (GFS) M-machine have both |
ken king, King Design | 29/07/2013 17:52:15 |
![]() 144 forum posts 239 photos | Thanks for responses. M-machine now live in my Bookmarks bar. |
mike mcdermid | 01/08/2013 23:01:47 |
97 forum posts | Ken M machines prices are quite ..er shall i put it politely expensive sheffield gauge plate sell entire 18 inch lengths for the same price as the 9 inches m machine are asking |
David Colwill | 02/08/2013 07:46:59 |
774 forum posts 40 photos | I use RS, as they are cheaper than cromwell and have it in stock (at head office). |
ken king, King Design | 02/08/2013 12:41:22 |
![]() 144 forum posts 239 photos | Thanks for further tips guys. All good helpful stuff and appreciated, Ken. |
David Littlewood | 02/08/2013 13:53:16 |
533 forum posts |
Posted by mike mcdermid on 01/08/2013 23:01:47:
Ken M machines prices are quite ..er shall i put it politely expensive sheffield gauge plate sell entire 18 inch lengths for the same price as the 9 inches m machine are asking Indeed - and I would be quite uneasy about buying from anyone who seems to think that 1/2 sq ft is the same as 6x6"! David |
