My EMMA under construction
I intend to add pics of my progress.
HobbyNut12/03/2013 22:22:14
113 forum posts
93 photos
HobbyNut12/03/2013 22:22:43
113 forum posts
93 photos
HobbyNut12/03/2013 22:26:05
113 forum posts
93 photos
I am going to machine the guides onto the valve chest.
I messed up with the cylider barrels, and I now have 1 3/16" bore and not 1 1/4". i doubt it will make much difference to me.
Ian S C13/03/2013 09:01:56
7468 forum posts
230 photos
When you said you'd messed up, I thought perhaps you'd gone over, now that might have been a problem, but under all OK, done that myself. Nice work so far. Ian S C
HobbyNut14/03/2013 03:02:42
113 forum posts
93 photos
Thank You. I made the OD of the barrel too small. the wall would have been less than 1/16" at 1.25 bore.
HobbyNut25/03/2013 21:19:07
113 forum posts
93 photos
The cylinders are coming along.
HobbyNut26/03/2013 15:27:47
113 forum posts
93 photos
Last night I made up all the rod guides and fitted them. I thought that I may paint it green, so I tried out a bit. I don't like it much, it is too light, needs a darker shade I think.
Edited By HobbyNut on 26/03/2013 15:28:33
john kennedy 126/03/2013 16:56:42
214 forum posts
24 photos
You're really pulling trees up now.Looks like you're level with the series.
I'm chewing the cylinders out of some cast iron weights,given to me by a farmer.
Does anybody know if the insulation recesses are necessary,or will they be ok left solid.Most people will use insulation but I wonder if that is because the recesses are already cast in,so they do it ?
I understand that the cols cylinders will take longer to warm up,but is that a big problem???
Hope someone can advise please. John
HobbyNut26/03/2013 19:16:41
113 forum posts
93 photos
I am almost up to it. I have to make the slide valves and pistons yet. I will try the pistons tonight.
The slide valves will take a night or two. I only have a "FIRST" Mill drill that is 100% digit operated. My digits get a bit weary at times! The only electronic digital equip. in my shop are the calipers.
My lathe is a 30 y.o Hercus 9" swing x 40" centers.
HobbyNut27/03/2013 16:02:20
113 forum posts
93 photos
I did make 2 pistons last night. I was only able to fit the rod to 1, and fit it to the cylinder. lots of lapping etc. More than I imagined.
HobbyNut02/04/2013 15:36:30
113 forum posts
93 photos
Made the slide valves and fitted them. The pistons and seals are also fitted.
HobbyNut08/04/2013 15:56:51
113 forum posts
93 photos
Back to making things from the latest installment.
The Cyl drain cocks under construction.
HobbyNut11/04/2013 16:31:31
113 forum posts
93 photos
The drain cocks are now assembled and mounted on the cylinders. I made the connecting link and all the other little bits last night. No pics yet. I will take them tonight.
HobbyNut03/05/2013 16:49:12
113 forum posts
93 photos
I am still working away. I used the 65000psi drill and file to make the motion pieces from the last installment.
James Sutton22/07/2013 00:38:53
18 forum posts
7 photos
Wish I had access to a water jet cutter like that. Would certainly speed up the plate work. I found a local machine shop with one but haven't made any contacts there to see if I can get some small run items done.
HobbyNut07/08/2013 15:24:39
113 forum posts
93 photos
James, it is easier on them if you can give them a digital file of the pieces that you want. either a .dwg or .dxf.
EngineDIY
