Mach3
Primer appeal
Rod Ashton27/09/2012 07:52:16
334 forum posts
12 photos
For the record I am a model admirer and not a model maker. I subscribed to MEW on the back of the excellent Mach 3 primer articles. While I am not at all dissapointed with MEW generally. No similar articles have appeared since. - May I put in an appeal for another series please. Lazyturn + Wizards perhaps?
David Clark 127/09/2012 10:34:14
3357 forum posts
112 photos
10 articles
Hi There
When were the MACH3 articles published?
regards David
dcosta27/09/2012 11:09:24
494 forum posts
207 photos
Hello David. Good morning!
Year 2008, MEW issues 138, 139, 141, 142, 147. Article title is CNC Milling with Mach 3.
Found using free MEW_Index **LINK**.
Best regards
Dias Costa
P.S.: There are new versions of ME and EiM Indexes applications.
Please check the date included in the file names before download to be sure it's newer than the one you have installed.
Edited By dcosta on 27/09/2012 11:10:03
David Clark 127/09/2012 12:11:10
3357 forum posts
112 photos
10 articles
Hi Dia
I thought so.
I started those articles but got so many complaints I stopped doing them.
I don't have a CNC mill now.
I will talk to Mick Knights.
He has one and writes articles.
regards David
Versaboss27/09/2012 12:36:26
468 forum posts
51 photos
Oh no, not another Mick K. please!!! crying 2 crying 2 crying 2
Greetings, Hansrudolf
David Clark 127/09/2012 12:53:36
3357 forum posts
112 photos
10 articles
Hi Hansrudolf
Whjat is wrong with Mick Knights articles?
regards David
Michael Cox 127/09/2012 13:05:37
540 forum posts
27 photos
David,
The US Homeshopmachinist website is split into various sections. There is on for general machining, one for welding , one for digital machining (i.e. CNC) and others.
I suspect that the US readership of Home Shop Machinist is very similar to MEW here. It is interesting to compare the numbers that view the general machining section with those that view the digital machinist section. In my experience there are typically less than 10 persons viewing the digital machinist section compared with typically 300+ persons viewing the general machining section. This means that there is at least thirty more times the interest in general machining compared with digital machining.
Whilst I am not against the odd article appearing in MEW on CNC I would not want to see long series of articles, especially if they contain pages of code, appearing. Most amateurs do not have CNC machines (yet) and such articles are bound to be of limited interest. I think most people would appreciate the occaisional article explaining the potential and capabilities of CNC machining in order to keep abreast of current technology but without getting into long detailed explanations on programming.
With time I am sure that more and more CNC machines will become available to amateurs and then perhaps the content of MEW can change to reflect this but at the moment it is too early.
What about a poll on this website to determine interest? If you did this I suggest you ask two questions. Firstly " Do you want short articles on developments in CNC machining" and secondly "Do you want detailed articles on CNC machining and programming".
Paul Boscott27/09/2012 13:29:56
99 forum posts
21 photos
Because of those articles I an now running Mach3 on my mill and am very pleased with the result
Rod Ashton27/09/2012 14:08:51
334 forum posts
12 photos
Thanks Paul. Looks like this needs support from us "screengazers"?
I too initiated my CNC machining through those articles.
There are many published MEW articles that are not of specific interest to me. I dont need the "back to basics" series. But applaud it`s inclusion.
I would not dream of condeming an article because it did not fit into my personal profile. I am sure there is term for this, but I am reluctant to type it.
Clive Hartland27/09/2012 14:30:51
2671 forum posts
40 photos
I would think the best way to do this is as a supplement to the magazine, if you dont want to read it bung it, but those that need the support will no doubt keep it.
A few pages will not break the Bank but please those who want it.
John Alexander Stewart27/09/2012 14:35:31
803 forum posts
53 photos
Interesting.
I am really not in favour of long articles with screen shots of specific commercial applications, whether CNC or not.
I guess that I personally like to read things that make me think, so that I can apply the meaning of the article to my own goals.
Yes, I now have CNC capabilities in my own shop. Yes, I have found that "rapid moves" always seem to take a trajectory such that the tool catches on clamps or the work, breaking said tool and/or damaging the material in the vice.
But, I'm one who learns by putting my hands to it, I realize that fortunately, there are many types who make up this world.
Another JohnS.
John McNamara27/09/2012 14:55:21
1314 forum posts
113 photos
Hi All
This weekend I will be showing a CNC router made from Laser cut 5mm steel with almost no welding, at the Melbourne Model Engineering Exhibition. The machine will be driven by Mach 3 when it is completed.
It was designed using Autocad a commercial program however there are many free CAD packages that can generate DXF files to give to a laser cutting service.
Almost No Welding? The design uses a joint of my own (well I have never seen it before) A design that is effectively (two) mortise and tenon pairs together with standard fasteners between the pairs, to make each connection) ; in this case M5 high tensile nuts and bolts, to join the various members together. Using this method there are zero sheer forces on the fastenings only tension forces. I believe it could easily be scaled up to at least 12mm plate. Laser cutting has very little undercut; however there is some..... to counter this make sure the attached plates are interlocked in sets of 3 opposed at 90 degrees. Buy doing this using my best More and Wright square to test the joints I could see no light. bolt holes aligned so perfectly that there was no eye observable misalignment. There are no tapped holes in the plates. The bolts and nuts fit in slots you can see the slots in the views.
If you are wondering the only welds are the end plates of the 75mm sq tube rail supports, We are going to make a new machine with joined 5mm plate instead of these tubes. It will be more accurate and lessen the packing we needed to set the rails true on the RHS (we used a surface plate).
Laser cutting is now a fairly competitive area and the group was able to negotiate a reasonable cost for the work roughly steel cost plus steel cost x 2 for labour. The parts came back accurate to .01mm accuracy. we allowed on top of that .1mm (point one) clearance for the joints and no allowance for holes.
When the parts came back form the cutting service there were small (tiny) dags here and there. about 2 hours work total with small file to clean all the joints and it went together like a clock. No welding distortion...... We redrilled all the round 5mm holes to clean them out as they were already laser cut it only took a few seconds per hole. the holes were positioned far better than I can do with a centre punch. Yes the machine could have been made by hand methods but have a look at the parts photo. how many hundred man hours. I have spent a fair number of hours just turning all the rotating parts .
The machine also uses Chinese round shaft linear rails and a z axis ball screw. You will be amazed how the cost of these have fallen on EBay and the like. X and y drives are 5mm timing belt.
All the rotating parts use flanged ball bearings 8mm and 12mm again the internet provided a source VXB Bearings were very helpful and are a good starting point. The flange is clamped between the frame and a laser cut plate with 4 M4 bolts
I have uploaded five CAD file images into an album at this site: 2 examples below.
The carriage is now completed and next week a stand will be constructed. Next week I will upload a set of photos.
The design is a collaboration with a great friend Leo S and The Bright Men's shed group, Bright is a central Victorian country town. A Men's Shed is a community supported building equipped with various metalworking, welding and wood working machinery; members pay a nominal fee to pay for tea and coffee. and are free to use the equipment (after doing OH&S induction and training).
New technology to me definitely has a part in model engineering.
Cheers
Edited By John McNamara on 27/09/2012 15:17:14
John Stevenson27/09/2012 16:09:06
5068 forum posts
Posted by Michael Cox 1 on 27/09/2012 13:05:37:
David,
Thats just one forum, but lets put it in perspective.
On CNC Zone, todays stats state there have been 387 posts so for in the last 24 hours.
They have 225,961 members who have started 148,112 different threads containing 1,137,711 different posts.
John S.
KWIL27/09/2012 17:01:28
3395 forum posts
66 photos
Then surely that (ie CNC Zone) is where the detailed articles should be?
John Stevenson27/09/2012 17:16:10
5068 forum posts
They probably are but the site is a mine field, there are that many groups and sub groups you just get lost.
In some ways it's become a victim of it's own sucess but I feel that because of the vastness it drives people away. better laid out [ don't ask me how ] it would probably attract far more users than it does at present.
Whatever way you look at it CNC has probably got a far greater following than the current crop of model engineers and home shop machinists.
John S.
Michael Cox 127/09/2012 17:16:56
540 forum posts
27 photos
John,
I accept that there are some sites with a bias toward CNC machining such as CNC zone. They have many posts because there are relatively few sites with a CNC bias. But even on CNC zone a great many of the posts are not actually about CNC and few post relate to programming as such. Indeed many of the most read articles, like those relating to epoxy granite concrete and climate change, have nothing to do with CNC machining at all.
However, I believe MEW, like Home Shop Machinist in the US, is largely read by amateur machinists making one off components for their projects and that very few of them have CNC machines. I am not saying no CNC articles, but don't go overboard and just keep the magazine content in line wiith the readers interests.
mike mcdermid27/09/2012 17:20:30
97 forum posts
Posted by John McNamara on 27/09/2012 14:55:21:
Hi All
Cheers
John I see this method of construction every day, Rolls Royce use it for very accurate very repeatable (read 1 to 5 micron) jigs and fixtures for turbine blades ,both grown and forged machined ,laser cut on a machine which even I couldnt believe would repeatably cut to the tolerances they claimed,Turns out MAZAK made the machine an example for their demonstrations and it does hold what it says on the tin
Unfortunately despite the claims of PATENTS etc in the way things are done etc it was recently pointed out to them that a company in halifax in the UK have been putting huge industrial fans together this way for the best part of 20 years
John Stevenson27/09/2012 17:41:22
5068 forum posts
Michael, not saying more articles or less just that you can't take one site, then say it's a 30:1 ratio.
We have given talks in the past at exhibitions on CNC. at Ascot we filled the lecture theatre, twice a day for 2 1/2 days, and they were standing outside, The only other person to fill a theatre was the "how not to paint a loco " guy, sorry forgot his name.
We didn't drag them in, they came because they were interested. That much so that for some people building as opposed to using CNC's is now their hobby, see John Mc's interesting post above.
John S.
blowlamp27/09/2012 17:52:38
1487 forum posts
97 photos
Why do some people want to single out CNC and split it off from everything else?
It's just an alternative way of machining, that not only might be more feasible and easier to do than on a conventional machine, but quite possibly more enjoyable too.
Martin.
Michael Horner27/09/2012 17:53:32
218 forum posts
61 photos
Some of the machines I service the frames are put together this way. Probably for at least 10 years.
Cheers Michael
walker midge
JD Metals
