Drawing Projections
KWIL06/11/2016 10:44:34
3215 forum posts
63 photos
Micheal,
I note with interest the Pi Tape is 1/2" wide and 0.25mm thick.
JasonB06/11/2016 13:05:38
17835 forum posts
1951 photos
1 articles
Posted by Ajohnw on 05/11/2016 23:17:48:
The answer to about 666mm problem is to always follow it with a tolerance. About 67cm isn't much better.About 6 1/2 of the units I can't remember is probably the best one. I chose 666 as it's the number of the devil. It's also about 2ft.
I hope you are not basing your kitchen on 666mm being "about 2ft" you may get away with thinking 600mm is 2ft but 666mm is just over 26"
Bandersnatch06/11/2016 18:57:13
1592 forum posts
55 photos
Posted by Chris Evans 6 on 06/11/2016 08:32:41:
We had a draughtsman who regularly used both on the same drawing and could not see his errors.
Then he wasn't a draughtsman (though he may have been masquerading as one). No more than a toolroom person who uses his micrometer as a c-clamp can be called a toolmaker (yes, I've seen it and yes it was lightly clamped and quite temporary, but nonetheless ....).
Ausee.com.au
