Quick question
pcb1962 | 06/09/2012 11:34:27 |
65 forum posts | I just bought some drill bits that were advertised as Dormer. All my Dormer bits have either the silver band on the posh ones, or the name etched on the shank on the cheaper ones. Is it safe to say if it doesn't say Dormer on it it isn't a Dormer? Thanks |
Andrew Johnston | 06/09/2012 11:45:41 |
![]() 6574 forum posts 701 photos | I wouldn't have thought that one could categorically say no name means it's not by Dormer. However, I've just had a look at all my Dormer drill sets, and all drills above about 4mm, or imperial equivalent, have 'Dormer' stamped or etched into the shank. What size are the drills? Regards, Andrew |
Keith Long | 06/09/2012 11:48:18 |
877 forum posts 11 photos | Have to agree with Andrew, I've found exactly the same with the Dormer drill sets that I have, 4mm and above, Dormer stamped on the shank, below 4mm no markings at all. Keith |
pcb1962 | 06/09/2012 12:03:58 |
65 forum posts | Thanks for your replies, they're all 10mm+ so no reason for them not to be marked, they are just stamped '10.0mm HSS' just like my Chinese ones. |
_Paul_ | 06/09/2012 12:18:19 |
![]() 543 forum posts 31 photos | All my Dormer brand drills are marked either with the name in a silver band or on the shank. Paul |
mgj | 06/09/2012 17:02:16 |
1017 forum posts 14 photos | Possible best to ring Dormer and get a definitive answer? |
Mike Poole | 06/09/2012 19:43:51 |
![]() Moderator 3305 forum posts 73 photos | I have Dormer drills marked SKF from some years ago when they were SKF Dormer. They are now part of Sandvik and I think no longer manufactured in the UK Mike |
Ron Ryan | 08/09/2012 09:08:55 |
2 forum posts |
looking to buy a good drill
Hey friend, |
Ron Ryan | 11/09/2012 09:22:59 |
2 forum posts |
Posted by Ron Ryan on 08/09/2012 09:08:55:
Hey friend,
Edited By Ron Ryan on 11/09/2012 09:24:49 |
KWIL | 11/09/2012 11:51:46 |
3549 forum posts 70 photos | Etched DORMER BRAZIL A002 4.0. Yes only 4mm and above. A002 is the drill series number. |
Robonthemoor | 01/10/2013 16:35:54 |
![]() 211 forum posts 45 photos | Hi guys, just in need of some 2.5 mm drill bits to thread a 3mm hole, what's the best to buy when it comes down to it? And who to buy from, chronos/ RDG tools. Ho and also type for mild steel. Rob. |
JasonB | 01/10/2013 16:41:30 |
![]() Moderator 22574 forum posts 2634 photos 1 articles | I like the Dormer A002 split points and the similar A 022 stub length ones, get them from J&L/MSC Have a look back through the classifieds, one of the Chris's was selling HSCo cobalt stub drills in 2.5mm by Dormer at a good price and may have some left. J |
Thor 🇳🇴 | 01/10/2013 17:49:57 |
![]() 1602 forum posts 45 photos | I have checked my Dormer drills, and those from 4mm or larger in dia. are marked Dormer (either Dormer Brazil and a few Dormer England). Thor |
Robonthemoor | 02/10/2013 04:50:38 |
![]() 211 forum posts 45 photos | Just checked he has non at 2.5mm rob |
Old School | 02/10/2013 08:53:25 |
406 forum posts 39 photos | Kirjeng supplies Dormer drills all the ones I have had from Terry have been marked Dormer
Olly |
OuBallie | 02/10/2013 14:24:00 |
![]() 1164 forum posts 662 photos | I've bought some off of eBay in the past, but NEVER EVER AGAIN! Edit/ Not Dormer I should add /Edit I went through packs of 4mm when I did the shelves between the BH600G stand towers. They just snapped at the least provocation. You only get bit once. Geoff - Back from hospital, X-Ray and Cystoscopy Edited By OuBallie on 02/10/2013 14:25:23 |
Stub Mandrel | 02/10/2013 19:52:31 |
![]() 4315 forum posts 291 photos 1 articles | > Geoff - Back from hospital, X-Ray and Cystoscopy That's a bit extreme for just a snapped drill! Seriously, hope it's all going in the right direction for you Geoff (i.e. getting better!) Neil |
