ronan walsh | 02/08/2012 23:48:52 |
546 forum posts 32 photos | The x-axis power feed on my tom senior universal mill is powered by an electric motor rather than mechanical means. I ideally want to power this motor from the usual inverter/vfd, can anyone help me identify what type of motor i have ? it can be seen in the pictures in my album. The main motor has been disconnected from the electrical board in the base and connected temporarily to the vfd i use for my lathe so the machine is operable, but i would like to get the table feed sorted. p.s its the one with the "kemo" nameplate. thanks. Edited By ronan walsh on 02/08/2012 23:50:14 |
Andrew Johnston | 03/08/2012 01:03:04 |
![]() 6609 forum posts 701 photos | Hmmm, I suspect that the A and F on the nameplate stand for armature and field, which implies it's a DC motor. The fact that the armature and field list different voltages and currents may mean that it's a shunt wound DC motor. Therefore driving it with a VFD will not work. It's not uncommon to use DC motors for table drives; certainly a lot of Bridgeport mills do so. Regards, Andrew |
ronan walsh | 03/08/2012 01:24:23 |
546 forum posts 32 photos | Thanks for your reply andrew, I may replace this motor with a ac type and drive it with a vfd so. Is there any other method of operating this motor from a single phase supply ? There is quiet a lot of electronics in the board in the base to operate this motor, but i don't have a three phase supply and don't intend to get it. |
Michael Gilligan | 03/08/2012 07:59:46 |
![]() 20216 forum posts 1053 photos | Ronan, If you are reworking the electrics; this seems a good time to replace that motor with a Stepper. MichaelG. |
Les Jones 1 | 03/08/2012 09:14:01 |
2257 forum posts 156 photos |
Hi Ronan, Les. |
Versaboss | 03/08/2012 09:33:52 |
490 forum posts 69 photos | Fully clear that this is a DC motor; look at the == sign after the voltage values! Greetings, Hansrudolf |
Andrew Johnston | 03/08/2012 13:50:18 |
![]() 6609 forum posts 701 photos | A recent thread discussed driving a 230V DC motor, **LINK** I can't see any reason for changing to a stepper motor, a lot of mechanical work, as well as changing the drive electronics, and fitting a hefty power supply. Regards, Andrew |
mgnbuk | 03/08/2012 14:48:18 |
1188 forum posts 71 photos | Does the original motor/drive not work ? One of your photos shows what appears to be a basic DC drive - if the motor & drive are working I would leave them be for the moment & use the machine "as is". FWIW I would not look to replacing the current arrangement with a 3 phase motor / VFD combination. Unless you fitted an external fan to cool the motor, I suspect it would overheat at low speeds. Should the motor die (replacement drives are easy enough to source for small dc motors if the drive dies), I would be looking for a small dc or ac servomotor & drive, as these are designed to supply their rated torque down to a standstill & would be quite happy running at low speeds for extended periods. Regards, Nigel B. |
ronan walsh | 03/08/2012 15:10:39 |
546 forum posts 32 photos | Firstly , thanks to all for replying to this thread , i didn't know i could power this motor from single phase power. This is a relief as it saves me altering the machine and also the cost of a vfd. Heading to the shed now to investigate this.
Thanks. |
ronan walsh | 03/08/2012 16:21:10 |
546 forum posts 32 photos | I have upped more photos of the electrical board. if i were to change the transformer in the top left hand side of the board to a 240v -24v out would that work ? the components on the two boards seem to be 12 and 24 volt pieces. |
Michael Gilligan | 03/08/2012 16:51:17 |
Posted by Andrew Johnston on 03/08/2012 13:50:18:
Andrew, That's strange ... I can see several However; I did qualify my post with "If you are reworking the electrics". Since it now appears that the original motor is useable, I agree with your recommendation. MichaelG. |
Michael Gilligan | 03/08/2012 17:27:01 |
Posted by ronan walsh on 03/08/2012 16:21:10:
I have upped more photos of the electrical board. if i were to change the transformer in the top left hand side of the board to a 240v -24v out would that work ? the components on the two boards seem to be 12 and 24 volt pieces. Ronan, Do you mean this one ?
... if so, it's already 240V input. (confused) MichaelG. |
ronan walsh | 03/08/2012 18:18:51 |
546 forum posts 32 photos | Yes michael ,thats the one, can i simply connect the live and neutral single phase to this ? , there is a contactor block immediately below this which has three phases connected to it , can this be isolated ? Surely its for the main drive motor which is now not connected to this board as its connected to a vfd. |
Les Jones 1 | 03/08/2012 18:50:41 |
Hi Ronan, Les. Edited By Les Jones 1 on 03/08/2012 18:55:17 Edited By Les Jones 1 on 03/08/2012 19:02:46 |
Michael Gilligan | 03/08/2012 19:03:12 |
![]() 20216 forum posts 1053 photos | Ronan, Subject to every caveat in the book ... It looks like you can isolate this lot from the 3-phase and simply wire into 240V BUT... we need to see a bit more of the wiring ... this is a only a small transformer and certainly isn't powering the Motor! Do you have any idea whether this is a standard Tom Senior, or a Special ? MichaelG.
ronan walsh | 03/08/2012 19:04:49 |
546 forum posts 32 photos | Thanks les, i should have said that this machine came from a community college and is covered in safety switches , one on nearly every door or hatch and a massive emergency stop foot operated button on the base. There is a lot of wiring from these switches to the board. I may remove them as they don't serve any real purpose. if anyone can steer me on how to get this table motor running with the original buttons and controls i'd be very happy. |
Les Jones 1 | 03/08/2012 20:33:20 |
Hi Ronan, Les.
ronan walsh | 03/08/2012 22:34:48 |
546 forum posts 32 photos | thanks les , i'll contact denfords for a wiring diagram, they do have some drawings because they bought tom senior's in the early 80's and i will also ask over on the yahoo group for senior millers. |
ronan walsh | 04/08/2012 16:59:35 |
546 forum posts 32 photos | I finally got the power feed working , i have upped two photos showing how, one of the three lives ran from L3 to L on the connections at the bottom. i disconnected this and connected a single phase live to the L connection on the right (beige coloured block) the neutrals are common as are the earths so these were connected also. With power applied the motor worked but only after the contactor in the second last picture was pushed in manually. The motor isn't that fast running , even with the rapid feed button held down , but hey it works and the limit switch mounted on the front of the table works perfectly too. So if anyone can tell me how do i get around having to push in the contactor manually ? can i do away with this component completely ? Thanks all .
john swift 1 | 04/08/2012 20:05:40 |
![]() 318 forum posts 183 photos | Hi Ronan , assuming the contactor has a 240V coil you should find the neutral is connected to one end of the coil and when you press the normally open green start button the live supply is connected to the coil via the now closed start switch , the normally closed stop switch and the overload switch once the contactor pulls in , a normally open pair of contacts wired in parallel with the start switch closes and maintain the power to the coil until the stop switch is pressed you need to trace the three wires from the start and stop switches to see how they are connected to the contactor hopefully my diagram will help John
Edited By john swift 1 on 04/08/2012 20:30:16 |
