Bernard Byers | 17/07/2012 02:02:50 |
3 forum posts 1 photos | Hi I am new toi this forum, my question is how do add a picture to my post Thanks B.Byers |
Gray62 | 17/07/2012 11:33:49 |
1046 forum posts 13 photos | Hi, you first need to create a photo album, click on the 'My Photos' link in your account area top left, then click 'Create a Photo Album'. Once you have created the album, you can upload jpg format images to it.
CB
Russell Eberhardt | 17/07/2012 13:41:21 |
![]() 2648 forum posts 85 photos | To put a picture in your post, as opposed to an album, you can post it to a hosting site such as Photobucket, Flickr, or Dropbox. You can then include a link to it in your post by clicking the "Image" button in the reply editor. Russell. |
Chris Heapy | 28/04/2013 11:39:39 |
209 forum posts 144 photos | Is there some trick I'm unaware of in getting the forum to correctly re-size a photo inserted using 'Image' button? I have mine hosted on PhotoBucket, and it seems no matter what setting I choose (in terms of locking the aspect ratio or resizing) I end up with an elongated picture. I then have to manually drag the box to approximate the correct ratio. |
Stub Mandrel | 28/04/2013 11:54:27 |
![]() 4311 forum posts 291 photos 1 articles | Yes Chris, In the insert dialogue set the width to (typically) 300. The aspect ratio should be locked by default, you may be unlocking it! Neil |
Les Jones 1 | 28/04/2013 12:01:11 |
2225 forum posts 153 photos |
Hi Chris, Les. |
Four stroke Fred | 28/10/2013 11:12:36 |
![]() 171 forum posts 168 photos | I have a problem when adding photographs to my albums -they always end up side down. I have tried turn the photo upside down in my computer folder photo album but when transferred it stays upside down! Help. |
Ady1 | 28/10/2013 12:26:11 |
![]() 4292 forum posts 641 photos | A bit here |
NJH | 28/10/2013 13:16:19 |
![]() 2314 forum posts 139 photos | Fred - that's really strange! ( but I do note that you are in Australia......... Norman |
Bob Perkins | 28/10/2013 13:23:27 |
249 forum posts 60 photos | I've had some upside down issues when posting from my iPad. Images look ok, but when posted the appear the wrong way up. I Flip and save them on the iPad it makes no difference. The orientation of the iPad seems to make a difference when taking the original photo. Bob.. |
JasonB | 28/10/2013 13:32:37 |
![]() Moderator 20283 forum posts 2218 photos 1 articles | Its quite possible the image you are turning up the right way is only being displayed correctly on your screen and the uploaded version is the original which may still be inverted. Regarding sizing from photobucket once you have pasted the link into the url box tab twice which will bring you down to teh width box and enter 450, the height should automatically change then OK. I have all my PB images at 700 wide which suits most other forums so just do the above when I'm using an image on here |
Four stroke Fred | 28/10/2013 22:52:07 |
![]() 171 forum posts 168 photos | The problem with the upside down photographs has been solved. I used the "old" computer as the mini I pad was the cause of the problem. I now have photographs that can be seen up the correct way at last! Thanks for the help. |
ANDY CAWLEY | 26/03/2014 07:12:27 |
175 forum posts 47 photos | I created my album successfully on my PC. How do I add photographs to it from my iPad? When I go to the add photographs bit the "choose file" button is "greyed out" What am I doing wrong? Edited By ANDY CAWLEY on 26/03/2014 07:16:35 |
Rick Kirkland 1 | 26/03/2014 11:52:34 |
![]() 175 forum posts | I've given up before I start trying to post from ipad. It seems the pads preffered orientation is the one which is awkward to use if you're not standing on your head. Might give it another go when the mood takes me. It won't beat me. Rick |
Bazyle | 26/03/2014 12:11:51 |
![]() 5834 forum posts 217 photos | If you are taking the photos with the ipad why not turn it upside down before taking the picture. That'll teach it. |
Rick Kirkland 1 | 26/03/2014 12:41:02 |
![]() 175 forum posts | Oooh, I do love a cunning plan like that. Now, where've I left me ipad? Rick |
NJH | 26/03/2014 12:46:22 |
![]() 2314 forum posts 139 photos | I would try this on my ( our) iPad but I can't prise it away from my wife! Norman |
Gone Away | 26/03/2014 13:50:27 |
829 forum posts 1 photos | Or you could stand on your head while taking the picture (at least you only have to do it once that way - not every time you look at the picture). |
Michael Gilligan | 26/03/2014 20:32:35 |
![]() 17658 forum posts 811 photos | Posted by ANDY CAWLEY on 26/03/2014 07:12:27:
When I go to the add photographs bit the "choose file" button is "greyed out" . Andy, Which iOS version are you using ? The "choose file" option certainly doesn't work with iOS 5 MichaelG. . P.S. ... For rotating photos [and other simple editing] I had intended to recommend an App called PhotoForge2, but this seems to have disappeared from the AppStore Edit: Yahoo! bought it and killed it ... see here Edited By Michael Gilligan on 26/03/2014 20:42:45 Edited By Michael Gilligan on 26/03/2014 20:50:29 |
Neil Wyatt | 26/03/2014 20:39:18 |
![]() Moderator 18558 forum posts 723 photos 78 articles | Some operating sytems don't actually rotate the file, they just store a note to display it rotated. To rotate for real use some form of full function editor. Neil |
