Forum sponsored by Allendale Until July 27th
Jason's Firefly .46 Build
JasonB24/06/2012 19:51:29
15536 forum posts
1594 photos
1 articles
Well seeing as David has given us this new topic heading I guess that we should make use of it and as a few people have asked for some more details of my build of the Firefly thats currently being covered in ME here goes.
Before I get going these photos are the way that I have gone about things with what I have, there are many other options for those with more or less equipment, please feel free to ask about other methods if you don't have the tooling.
Crankcase
I had a lump of 2"x4" HE30 that was not used on another project so decided to use this, it was marked out somewhat oversize and one of my woodworking bandsaws made quick work of reducing to size.
Firefly1
The rough sawn block was then held in the milling vice and a flycutter used to cut the four edges to 0.5mm oversize.
Firefly2
The centre was then marked and punched on the end of the embrio crankcase and then clocked true in the 4-jaw using a sprung centre and dti
Firefly3
The majority of the waste was drilled out right through starting with a spot drill then 1/4", 1/2" and 9/16". In hindsight I would suggest drilling 3/4 of the way through only - see later.
Firefly4
A boring bar was then used to open the end out to 28.2mm dia and a little longer than needed.
Firefly5
A depth gauge was then used to check the depth of the 28.2mm hole and the end faced back until finished size was reached. The edge of the hole was then given a slight chamfer to break the edge.
Firefly6
I then set about boring the 16.6mm hole, as you can see this needs quite an overhang on the bar and even at 1/2" dia I was not getting the type of finish that I wanted so opted to flip the work end for end and use a shorter bar from the other end. If doing it again I would clock the work in and drill 9/16 from the front end before boring to 16.6mm as the 28.2 and 16.6 holes do not have to be perfectly concentric this is not an issue.
Firefly7
Here the end has been faced back to get the correct overall length and again the edge of the hole tidied with a small chamferFirefly8
Cont'd
JasonB24/06/2012 20:15:12
15536 forum posts
1594 photos
1 articles
The position for the cylinder was marked on the top of the crankcase, punched and then again clocked true in the 4-jaw, not packing under the two jaws bearing on the finished ends.
Firefly9
The hole was opened out to 5/8" by drilling and then I swapped to a boring bar to cut the 25mm hole and 34mm counterbore, as usual edges broken with a chamfer.
Firefly10
With the turning done it wa sback to the mill to macine the faces down to finished size. The micrometer was zeroed on a steel ball, then opened up until it read 4.65mm and zeroed again, this made it easy to measure how much needed to come off with the flycutter. A blob of grease stops teh ball going AWOL
Firefly11
The crankcase was then held back end up and the centre of the 28.2mm bore located with the aid of an electronic edge finder.
Firefly12
The four bolt holes were then heavily started with a spot drill, this has the advantage of giving a clean CSk edge and a start for the drill all at the same time and the CSK is easier to start that trying to do it into a threaded hole after tapping.
firefly13
Holes were then drilled 2.5mm and tapped M3 using a light grip in the chuck to keep the tap vertical.
Firefly15
Job done
Firefly15
The same procedure was then used to complete the four barrel mounting holes
Firefly16
Firefly17
As I mostly work in imperial I did not have a sharp enough 12mm milling cutter so used a boring head to cut the two transfer ports.
Firefly18
And there we have the crankcase ready to recieve the bearing.
Firefly19
Cont'd
JasonB24/06/2012 20:27:24
15536 forum posts
1594 photos
1 articles
Bearing
Talking of Bearings I started out with a stick of 3/4" nominal bar and took a light skim along it which gave a dia of 19.6mm, this will be close enough to the required 20mm. The end sawn end was then faced.
Firefly20
The outside was then reduced to to give a good press fit into the crankcase, measure from job. Inside was drilled then bored out to 12mm, check the outside dia again after boring as the bearing may have grown.
Firefly21
The length was then faced back to finished size
Firefly22
And as usual edges broken with the chamfering tool.
Firefly23
Part off a little overlength
Firefly24
Reverse in the chuck and lightly grip while the flange if faced to size and finish with more chamfers.
Firefly25
Firefly26
Cont'd
Jeff Dayman24/06/2012 20:54:33
1526 forum posts
37 photos
Looks great so far Jason, JD
JasonB25/06/2012 19:28:14
15536 forum posts
1594 photos
1 articles
Thanks Jeff.
The completed bearing was then pressed into the crankcase using a vice, put a washer or similar on the end as the bearing needs to protrude slightly beyong the end of the case, I used part of a ballrace.
Firefly28
The next job was machining the chamfer on the top of the crankcase, start by marking a line 23.45mm from the front face.
Firefly 29
Then mount the work in the milling vice at 20deg not the 20.1 that the photo shows, the right one wa sout of focus. The bit of steel flat gives the magnet of teh angle box something to stick to.
Firefly30
Flycut away the waste until the new face meets the previously marked line.
Firefly31
Pick up the junction of the two faces with a centre finder and then crank back 8mm to locate the carb hole.
Firefly32
Form carb hole, I went spotdrill, 1/4" & 3/8" drills followed by 10mm FC-3 cutter. Lock the quill and feed down the head or up with the knee so the tools won't snatch as they break through the bronze at an angle. Then use a CSk to just tidy the edge.
Firefly33
Mark out the two carb retaining screw holes and lightly punch
Firefly34
Back in the mill locate the dot punch mark with a center finder, spot drill, drill 3mm and counterbore with FC-3 cutter, I used 1/4" . Repeate for other side
Firefly35
Con't
JasonB25/06/2012 19:37:20
15536 forum posts
1594 photos
1 articles
Flycut the remaining three chamfers, I went for a slightly different length on teh sides to that shown on the drawing. The angle is not shown on the drawing but should be 17deg and the length of the slope stops 22mm back from the front of the crankcase.
Firefly36
I decided on a turned nose so mounted the part back in the 4-jaw, use some packing to save marking the finished faces and clock the bore to run true.
Firefly37
Set the topslide and turn a taper thats pleasing to the eye, mine was about 27deg by the time I had adjusted it a couple of times to get the turned section to run out where I wanted.
Firefly 38
Finally back to the mill for the two 45deg chamfers along the bottom edges, mine are a bit smaller than the drawing as I wanted the edge to meet one of the facets on the front cone.
Firefly39
And thats the crankcase complete. I may do a bit of blending of the faces later and once all is complete a final clean up of all surfaces will be done.
Firely40
Firefly41
Firefly42
Firefly43
Cont'd
AndyB25/06/2012 20:17:17
167 forum posts
7 photos
Crikey Jason! What did you do after breakfast?wink
I fancied having a go at this one as a first foray into I/C and now, as usual, I have a fantastic build log to follow...eventually!
Really good work and well presented, thank you very much.
Andy
JasonB25/06/2012 20:30:06
15536 forum posts
1594 photos
1 articles
Oh I've done more than that, have a look at my photos they are upto date.
Its not a bad little engine certainly worth having a go, I did say elsewhere that its actually my first glow engine though I have done several other I/Cs but they were sparkplug/ignitor based.
J
Edited By JasonB on 25/06/2012 20:30:57
JasonB28/06/2012 20:07:33
15536 forum posts
1594 photos
1 articles
Barrel
I cut another piece of the lump that I used for teh crankcase and machined it up on 4 sides to 44x41 to give 0.5mm each face to play with and plenty of length to go in the chuck.
Firefly44
The centre was marked on one end and then dot punched
Firefly45
The piece was then set up in the 4 jaw using a dti to get the centre to run true while also making sure it was square to teh lathe axis
Firefly46
Firefly47
The end was then faced and deeply centre drilled and the tailstock centre brought up for support. A parting tool was then used to establish the top of the mounting flange and underside of the exhause block.
Firefly48
Then the same tool used to cut the top face of the exhaust block
Firefly49
And then most of the material between this cut and the chuck removes, I used a series of plunge cuts and then traversed with the parting tool to remove the last 0.2mm
Firefly50
The tailstock centre was then withdrawn and the flange machined to thickness and , the spigot was machined to fit the cranckcase testing to get the right fit.
Firefly51
Firefly52
And with the dia correct the spigot was trimmed back to 2mm long
Firefly53
With the tailstock back in place the grove and chamfer around the top of teh barrel were machined
Firefly54
Cont'd
JasonB28/06/2012 20:20:21
15536 forum posts
1594 photos
1 articles
With all the external turning done the inside was drilled out in steps to 5/8" and then bored to 25mm.
Firefly55
The edge of teh hole & spigot were chamfered and then the whole thing parted off a bit overlength, I parted most of the way through then completed with a saw rather than have the finished part drop.
Firefly56
With the top facing out the barrel was clocked true in the chuck
Firefly57
Then faced back to finished length and the edges chamfered
Firefly58
Its was then over to the mill and the centre of the bottom of the bore clocked in
Firefly59
The 4 mounting holes were then spotted and drilled
Firefly60
Next the two sides of teh mounting flange were machined back to size checking against the crankcase
Firefly61
Followed by the front & back
Firefly62
A 12mm cutter was zeroed in on the flange using "fag paper" to gauge th eposition
Firefly63
The two transfer ports were then formed by plunge cutting with the 12mm cutter, note the two blobs of marker to make sure the transfer ports go where they are meant to.
Firefly64
The two side faces of teh exhaust block were then machined to finish size, note the slight burrs from the blunt cutter.
Firefly65
Cont'd
JasonB28/06/2012 20:50:04
15536 forum posts
1594 photos
1 articles
With the burrs removed the centre of the surface was located and then the two silencer mounting holes spotted, drilled and counterbored with a 1/4" FC-3 cutter. As they are quite deep holes I drilled half way from this side and then the rest from the silencer mounting face.
Firefly66
The barrel was then set to 45deg using the angle box and with a sharp cutter this time the chamfer machined to a premarked line just like the carb face was done, repeat for the other chamfer
Firefly67
Flip teh part over, machine back to finished width, complete drilling and then mill out the exhaust port. I went as far as I could with a standard length cutter and then changed to a long series one to complete the passage.
Firefly68
The final job was to drill and tap the four head fixing holes, just like the crankcase was done.
Firefly69
And to finish off tonight here are a few quick snapps of teh finished part, save for a bit of final cleaning up.
Firefly70
Firefly71
Firefly72
J
Edited By JasonB on 28/06/2012 20:50:37
JasonB01/07/2012 20:14:14
15536 forum posts
1594 photos
1 articles
Cylinder Head
Before starting I should point out that I have deviated from the drawings slightly, nothing major only cosmetic changes.
A length of 1 5/8" bar was chucked, faced, center drilled and then the outside skimmed to just remove enough metal to get a clean surface, this became my finished OD - 41.1mm slightly up on the drawings 40mm.
Firefly89
The spigot was machined to size and then the tailstock centre brought up to give support while the cooling fins/grooves were cut. I went for a different pattern of 0.050" fin, 0.050" groove, etc as this suited my 50thou parting tool and gave me room to get an extra groove. Due to the larger diameter I also increased groove depth from 1.8mm to 2.5mm
Firefly90
The edges of the fins were tidied up with a small cut from the usual chamfer tool.
Firefly91
A form tool for the "hemi" head was ground up from a 3/8" HSS blank with plenty of clearance to stop it rubbing on the bottom of the cut, did not bother with any top rake and it gave a good chatter free cut over its whole width at about 250rpm.
Firefly92
The head was then parted off over length, reversed in the chuck, faced, bored and the chamfer around the plug hole added with a small boring bar. I made the head 1mm taller than drawing.
Firefly93
I picked up the centre of the plug recess in the mill and then set the four holes from there, drilled 3.1 (3.5mm on the drawings seemed a bit excessive clearance for M3) and counterbored with a FC-3 cutter followed by a quick touch with the CSK.
Firefly94
The reason for making the head that extra 1mm long was so I could have a bit of fun with a slitting saw. The head was set square in the rotary table chuck by using a tri-square against two drill bits pushed into the bolt holes and then the saw set to centre of the head. I worked out a suitable spacing and then took a series of 1/8" deep cuts across the head. Note the M5 nut in the plug hole, this is screwed to a rod that passes through the rotary table with a nut and washer on the other end to hold the head into the chuck, I was worried the saw may pull it out of the chuck as the spigot is quite short to grip.
Firefly95
After a bit of de-burring with a needle file this is what the finished head looks like
Firefly96
Cont'd
Edited By JasonB on 01/07/2012 20:14:41
JasonB01/07/2012 20:37:54
15536 forum posts
1594 photos
1 articles
Just before starting the next bit I should have said that the UNEF tap required for the glow plug can be obtained from Model Fixings who will also have the socket head screws needed for the engine if you don't have any to hand. Usual disclaimer.
Backplate
A 1" slice of 2 1/2" HE30 was mounted in the 4 jaw as that was on the lathe at the time and faced & turned to the 57mm dia.
Firefly73
The majority of the waste was roughed off and then the part left to cool.
Firefly74
Once cool there was no risk of the spigot contracting so it wa smachined to a push fit in the 28.2mm crankshaft, test the fit in the hole rather than measuring. Notice the fine whispy swarf, how said you can't take half a thou off with carbide tooling.
Firefly75
The spigot can then be faced back to the finished 15.5mm and the edge lightly chamfered.
Firefly76
The larger camfer on the backplate can now be done by swinging teh topslide over to 45deg
Firefly77
With the finished surface protected by paper the flange can be faced back to 5.7mm finished thickness.
Firefly78
Work up through the drill sizes as before to take out some of teh waste from the recess and to allow a decent thickness boring bar to enter.
Firefly79
Bore out to dia and depth and finish with a chamfer to all edges
Firefly80
Hold the work, locate centre and then spot the seven hole positions
Firefly82
Open out to M3 clearance and 4mm as required on the drawings and clean the edges with a CSk if you did not deep spotdrill.
Firefly82
While the holes are all aligned with the mill axis cut the shallow flat on the top of the spigot
Firefly83
Turn the backplate over and CSk tehe four holes, clean the other 3.
Firefly84
Cont'd
JasonB01/07/2012 20:44:34
15536 forum posts
1594 photos
1 articles
Set the backplate square in the rotary table chuck using the two drills and tri-square method.
Firefly85
Then wind it 35deg each way, spot and drill though 1/8" to suit your pipes. There is no front to back dimension given for these two holes but I set mine 2.5mm in from the back of the plate.
Firefly86
And this is the finished backplate
Firefly87
Firefly87
Add a couple of screws and this is where we are upto at the moment. I'm going to do a bit on my Domestic Hit & miss engine so may not add anymore for a week or so.
Firefly97
Firefly 98
Jeff Dayman01/07/2012 20:46:04
1526 forum posts
37 photos
Hi Jason,
The head and rear spigot look great, except for that one fin on the head that is .00018" too wide....
(I'm joking of course, the whole engine to date is a fine job!)
JD
Glenn Royds04/07/2012 23:51:21
4 forum posts
Hi Jason
I was just surfing on Google and spotted your build photographs so had to join the forum, I would like to thank for your excellent conrtibution to the Firefly 46 build.
To introduce myself I'm Glenn Royds the CAD monkey who produced the 3D Firefly drawings for Alex Whittaker. We have had several engines created from the drawing set so hopefully you should have little difficulty creating a working engine.
If you are unsure about any dimensions please shout out however the 3D PDF is to scale and can be relied upon to verify a dimension although my intention in created it was to make it easy to visualise the component parts.
I have not created the engine myself I basically reverse engineered as a virtual 3D model from Alex's prototype and added a few tweaks to loose some lard and make it look pretty
Please Note I cannot help out with engineering method/problems this is the proving groups domain.
I do like the addition fin work/cylinder head mod.
Keep up the good work
Cheers Glenn
JasonB05/07/2012 17:31:00
15536 forum posts
1594 photos
1 articles
Thanks Glenn, they are indeed a nice set of drawings. The 3D pictures should be a great help to any beginners as its often hard to visualise a part in 2D and this is certainly the way forward. I must get myself a decent programme and sit down to learn it, I'm still a pencil & paper man myself.
J
JasonB08/07/2012 18:00:22
15536 forum posts
1594 photos
1 articles
Well I could not stay away from the engine for long! I have deviated from the drawing number sequence as I wanted to make the piston to fit the liner rather than the other way round.
Cylinder Liner
A length of 30mm EN8 - cheaper than 1 1/8" -  was roughed out with about 0.020" to come off all faces.
Firefly105
The outside was then turned to a firm push fit into the barrel and the inside bored to 21mm
Firfly106
I made up a plug to go into the end of the liner so the rotary table tailstock could be used, this let me support the work away from the R/T chuck without the collet holder hitting the jaws and proceded to mill out the ports with a 3mm FC-3 cutter.
Firefly107
While in the R/t chuck I also used a 1/16" endmill to put a locating slot into the flange rather than a vee.
Firefly108
Back to the lathe and the liner was parted off a little over length, reversed, lightly held and the flange faced back to 0.75mm and all edges chamfered.
Firefly109
Firefly110
And this is the finished liner ready to have the inside lapped.
Firefly111
Edited By JasonB on 08/07/2012 18:02:13
Glenn Royds08/07/2012 21:42:14
4 forum posts
Wow excellent work Jason you are a glutten for punishment.
For everybody's info there is a lot of meat in the liner this was deliberate move to avoid distorsion when milling the ports.
If you compare this with mass produced japanese engines the liner thickness on the Firefly is way over the top, commercial liners are wafer thin in comparison and appear to be pressed then honed to size unfortunately we don't have this luxury.
Maybe we could have gone bigger in the bore get more capacity but at the risk of some folk scrapping their liners depending upon the quality of their machinery and tooling.
Keep up the good work.
Glenn
JasonB15/07/2012 13:37:45
15536 forum posts
1594 photos
1 articles
With the machining complete on teh cylinder liner it was now time to lap the bore for a good finish. I can't take any credit for the lap design, its based on one Ramon used for his ETA & Supertiger builds, basically a tapered rod with a nut on the end to drive the taper bored lup up the taper to expand it.
Firefly118
The lap was charged with a mix of 320g powder and oil and then the cylinder worked up and down while the lathe ran quite slowly. You can see the matt fionish produced.
Firefly119
After a thorough clean the process was repeated with 600gmix
Firefly120
Cleaned again and finally done with 1000g mix with a lot of oil.
Firefly121
Firefly122
With the lapping done the liner could be used to gauge the finished size of the piston.
Cont'd
Ausee.com.au
Meridienne Sept 2019
TRANSWAVE Converters
