Forum sponsored by Allendale Dec 6th
steam brake cylinder
simon musson04/05/2012 10:58:21
1 forum posts
I have nearly completed the construction of the 5 inch gauge Princess of Wales to the LBSC design
The drawings show no method or indeed neccessity for the steam brake cylinder to be attached to any sort of anchor it seems to float about secured only by the steam brake feed pipe
Other loco drawings say Speedy show the cylinder bolted to a frame stretcher although there the cylinder is in a vertical position whereas mine is horizontal
In short does the brake cylinder need to be secured to the frames somehow?
fizzy04/05/2012 18:56:28
1641 forum posts
111 photos
it wont be working as a brake cylider for long unless it has an anchor point
PETER AYERS05/05/2012 17:51:10
25 forum posts
Hi Simon I think you will find the Princess of Wales was deseigned by Martin Evans but it is a lovely loco. As others have said the steam cylinder should be anchored to obtain purchase on the brake gear.
peter
John Baguley05/05/2012 18:47:39
441 forum posts
46 photos
The steam brake cylinder is supported by the brake gear linkages and is not fastened at all to the frames. This photo from Station Road Steam may help:
http://www.stationroadsteam.co.uk/stock%20pages/3442/pages/3442-k.htm
Tee London LMES 6th Dec
