'Quick' advice on knurling tool :)
capnahab23/04/2012 20:58:15
182 forum posts
64 photos
I have scored a quick LA/KF knurling tool from the bay.
http://www.brw.ch/shop/produkte/index.html
here it is at enormous cost. I need some rollers. Can anyone direct me to the type for a bog standard diamond knurl. I may be doing titanium so I thought
these
http://www.brw.ch/shop/produkte/detail/index.html?t_ProduktNr=475240
not sure about the division or the version tho.
Tips on how to use it would be good too.
quick LA/KF
Ian S C24/04/2012 02:43:21
7468 forum posts
230 photos
Just been looking on google,quite a bit there, had a look through a catalogue, very interesting. The rolls are made from poweder metalurgical high speed steel, they require special bushes and side cheeks, and that tool of yours will knurl fron 1.5 to 12 mm dia, the pitches are; 0.3/ 0.4/ 0.5/ 0.6/ 0.8/ 1 mm. The rollers are 8.9 mm dia. Ian S C
capnahab24/04/2012 06:42:43
182 forum posts
64 photos
Thanks Ian. yes, other than finding it needs a decent flow of coolant to wash the cut material away I am not sure how to use it. It seemed an attractive alternative to form knurling. it was a lot less than €880 !.
I wonder if the bushes and side cheeks come with the rollers.
JasonB24/04/2012 07:25:34
19125 forum posts
2104 photos
John Stevo on here has a couple of the quick tools worth contacting him.
There was a thread about 2-3 weeks ago about a similar knurl bit of info there.
 http://www.model-engineer.co.uk/forums/postings.asp?th=67267
J
Edited By JasonB on 24/04/2012 07:28:27
Terryd24/04/2012 08:23:27
1935 forum posts
179 photos
From your photograph the side cheeks and rollers appear to be there. The 'Knurl Rollers' on the site appear to be priced each (I presume you have clicked on to the English translation of the page) without any additional parts.
BTW the prices are in Swiss Francs not Euros and as Switzerland is non EU, UK VAT would have to be added to the prices. So a pair of knurls from the manufacturer would be around £46 +VAT.
T
capnahab24/04/2012 08:56:42
182 forum posts
64 photos
So , in laymens terms the pitch is going to determine how far apart the high points of the knurl are ?.
What about the angle ?, - they seem to be 90 degrees or 15 or 30 left and right. Is this something to do with the set up angle on the lathe ?. If so , how will it affect the knurl ?.
Ian S C24/04/2012 12:02:07
7468 forum posts
230 photos
The angles are 15* L&R, one of each required, or straight two required. Ian S C
capnahab25/11/2012 19:52:54
182 forum posts
64 photos
At last I have sourced the knurling wheels. In putting them on I have upset the (very complicated) set up for adjusting the wheels.
the instructions for use are here
http://industrieprodukte.swarovskioptik.com/en/gb2_infos-news-information
But there are no isntructions for setting it up.
I have two problems , the screw in the side of the main body (arrowed) is stuck and has a narrow shallow slot.
once I get it out I am not sure how to reassemble it so the rotating the adjuster nut works with the cams on the knurling wheel sleeve.voila_capture708.jpg
AndyB25/11/2012 20:40:32
167 forum posts
7 photos
Hi,
As Switzerland is not in the EU there is no VAT but you will have to pay import duty which is usually sorted out by the courier and you once it arrives in the UK.
Royal Mail has a very good online system for payments when I have stuff come from the USA.
Andy
Versaboss25/11/2012 23:31:36
458 forum posts
51 photos
Capnahab, if you need a setup description you can find one here for the similar Ifanger tool.
A bit fiddly with the size of the tool I have; maybe yours is somewhat bigger.
Greetings, Hansrudolf
John Stevenson26/11/2012 00:31:11
5068 forum posts
Why did you strip it ?
The wheels just fit on the ends of the axles.
It's a bitch of a job to get these back together and timed up, as you feed the worm shaft in it rotated the axles so you have to set them 5 teeth advanced to start with.
capnahab26/11/2012 16:02:51
182 forum posts
64 photos
Thanks John , I know
I didn't purposefully strip it , - the adjustment was jammed .
EngineDIY
