Dennis WA | 19/04/2012 08:35:20 |
![]() 79 forum posts 5 photos | I have just acquired this from a friend. Does anyone know who made these? Thanks Dennis |
Ady1 | 19/04/2012 09:04:31 |
![]() 5169 forum posts 738 photos | I will have a wild stab at this
http://www.championcuttingtool.com/_index_home.html
Dennis WA | 19/04/2012 10:42:13 |
![]() 79 forum posts 5 photos | Champion Cutting Tool is a long-established American firm - my sensitive drill is UK-made, with a big 1950's style label "Champion No 1 Made in England" |
Terryd | 19/04/2012 10:45:52 |
![]() 1936 forum posts 179 photos | Hi Dennis, There was also a Champion machine tool company in the United Kingdom, although I have no information about them. I'm not sure if they were related to the US company of the same name or completely independant. Sorry not to be of more help. Regards Terry |
Dennis WA | 19/04/2012 10:51:59 |
![]() 79 forum posts 5 photos | Terry...Tony's http://www.lathes.co.uk/ lists Champion UK in his " incomplete list of Manufacturers and Brands" - there is no other information. Regards Dennis Edited By Dennis WA on 19/04/2012 10:56:03 |
Terryd | 19/04/2012 11:04:08 |
I came across this, not much but at least a picture Regards Terry |
IanT | 19/04/2012 12:15:22 |
2002 forum posts 212 photos | Modifications to the 'Champion' 1/4" drill were described by 'Duplex' (probably in ME but haven't found the issues) and I'm pretty sure it was a British product. I have the Duplex "In the Workshop" volumes (published in 1951) and (in volume 3) Duplex descibes the Champion as a machine "which has been widely used for many years past". The modifications by the way are to increase the speed range. They also describe a similar mod for the 3/8" Cowells drill - one of which I happen to own (but have not so far modified). Regards, IanT |
Terryd | 19/04/2012 17:00:18 |
Posted by IanT on 19/04/2012 12:15:22:
Modifications to the 'Champion' 1/4" drill were described by 'Duplex' (probably in ME but haven't found the issues) and I'm pretty sure it was a British product................ Regards, IanT Hi Ian T, The article which I think you are referring to is in issue 2508, p 548, 1949, vol. 100. Regards Terry |
Dennis WA | 19/04/2012 19:43:37 |
![]() 79 forum posts 5 photos | Thank you Terry and IanT for your feedback. The link to Champion (Machine Tools) in Graces Guide shows a picture of the drilling machine - it is identical to the one I have acquired, which, after removing some surface rust on the exposed steel column etc, is in very good condition. Fortunately I have old MEs from 1939 onwards ( bought cheaply many years ago) and following up on your leads there are the ME articles by "Duplex" in issue 2500 (pg 478) and 2502 (pg 548) of Vol 100 (January - June 1949) dealing with extending the speed range of a 3/8" Cowells and a 1/4" Champion drilling machine. As IanT quotes, they write on page 479, " ...the 1/4" capacity Champion drilling machine, which has been widely used for many years past, ...." I assume that these machines must date at least from the 1920's onwards? Back to my question - does anyone know where Champion (Machine Tools) had their factory? Many thanks Regards Dennis |
michael cole | 20/04/2012 10:05:17 |
165 forum posts | I have a nice one of these drills. I under stand it was home build from a set of castings.
Dennis WA | 20/04/2012 14:59:03 |
![]() 79 forum posts 5 photos | Looking at the 1949 Vol100 ME they were advertised by tool merchants for Eight Pounds Five Shillings (presumably without motor)! |
Terryd | 23/04/2012 10:23:28 |
![]() 1936 forum posts 179 photos | Hi Michael, are they the same Elliots who made the larger bench and pillar drilling machines? Best regards Terry |
Dennis WA | 23/04/2012 12:55:41 |
![]() 79 forum posts 5 photos | Hi Michael.. Thanks for your comprehensive answers! Which ME contained the review of the model 3? (As indicated in an earlier post above, I have bound volumes from 1939 onwards) Regards Dennis
Dennis WA | 23/04/2012 20:28:23 |
![]() 79 forum posts 5 photos | Hi Michael... Thank you for the prompt response! Regards Dennis
Harold Hall 1 | 04/11/2012 21:13:47 |
418 forum posts 4 photos | IanT and Dennis both mention the Cowells drilling machine, have a look here for a photo of one I made, complete with the speed range modification. This was supplied as three castings with the major machining already done. However, as a teenager I could not afford them so asked if I could purchase the raw castings, completing the task on a Myford ML4. Incidentally, Cowells still exist, and in the same premises in Watford as they did 61 years ago. Unfortunately, they no longer supply the casting kits that they did then, one of which was a very nice hand powered shaper, see here . Does anyone reading this still own one? This is not the same company who presently make small lathes and milling machines. Harold |
Mark C | 04/11/2012 21:21:42 |
707 forum posts 1 photos | That is a coincedence! I have one of these that I "rescued" from the local recycling center - I had no idea it was a little brother to the two Elliot mills I have. I will take some pictures and upload them when I get a moment. Mark |
Gone Away | 05/11/2012 01:13:07 |
829 forum posts 1 photos | There are hand operated shaper castings available from Martin Model in the US (I'm in Canada so it's not quite the shipping problem it would be in the UK). I've considered something like this a few times but wonder how much physical effort is required. Does anyone have any direct experience in that regard? |
Mark C | 05/11/2012 08:37:13 |
707 forum posts 1 photos | turns out mine is a number 2 - the motor is out of the arc, probably an old hoover washing machine or the like!
IanT | 05/11/2012 10:04:06 |
2002 forum posts 212 photos | Sid - wrt your question about hand shapers. I have an Adept No 2 hand shaper - and it's not really the physical effort (I only take small cuts anyway) but more the time it takes - it gets a bit boring. So it is a device that in some ways is better used for smaller items where the area you are machining isn't that large - not because you can't machine larger stuff - but because it simply takes more time. Very small slots/ways are also possible with simple tooling that's easy to sharpen. Having said that - if the mill is already set up for something else - then some jobs still get done on it and I can get a very fine finsh with very simple tools. I also intend to make some tooling for line engraving - both on dials and flat surfaces. Another use could be keyway slots in bores - I'd probably do this on the Adept shaper rather than make a dedicated slotting attachment - easier/quicker. So in summary a very useful device to have - especially for smaller items where my larger mill would be a bit too large, or where setting up on the vertical slide might be a bit of a pain (or I've got other stuff already in progress). I think it could also be used in a variety of other ways (with a little thought) where a controlled linear cutting motion is required. Regards,
Ian T |
Gone Away | 05/11/2012 17:16:25 |
829 forum posts 1 photos | Thanks, Ian that's useful info. The shaper who's casting set I was referring to is necessarily limited to small jobs (4" stroke, 4" traverse). My main problem is that health related issues over the last few years have left me a bit down on muscle mass in my arms so a manual machine is a bit of a query.
Truth be told though, I'm more interested in the making of the machine than the using of it |
