Stub Mandrel | 10/12/2011 20:49:46 |
![]() 4315 forum posts 291 photos 1 articles | Excellent coarse engineering Les! Neil |
Les Jones 1 | 11/12/2011 09:17:15 |
2255 forum posts 156 photos | Hi Neil, Thanks for the comment but I do not think it is in the same league as a "Quorn" It just seemed a cheap and lazy way to make a support to use Harold Halls end mill and four facet drill sharpening jigs. Before anyone comments on the wheel coming off when the motor is running in reverse (As it needs to be sharpening the end mill.) the hub is keyed onto the shaft. By the way Neil, how did you insert the picture before the post ? Les Edited By Les Jones 1 on 11/12/2011 09:18:52 |
Harold Hall 1 | 11/12/2011 18:21:22 |
418 forum posts 4 photos | I like the idea Les, makes me wonder why I designed my grinding rests. What is the studding for, bottom right, is it an adjustable stop. I think perhaps that David would like it as an article for MEW. Glad you find the end mill sharpening and four facit drill sharpening jigs useful! Harold |
Les Jones 1 | 11/12/2011 18:55:28 |
2255 forum posts 156 photos | Hi Harold, You are correct. The studding is an adjustable stop which I fitted for use with the four facet drill grinding jig. I am not happy with the stop as it has to stick out so much and is in the way when turning the feed handle. I am also thinking of replacing the original feed screw with one with a finer thread. Other problems with the design are that the angle to which the table can be set is limited by the back end of the plate touching the space between the jaws. another problem is although the pivot for the plate is as close to the wheel as I can get the grinder has to be raised or lowered at times by adding or removing spacers. The table only pivots on one axis whereas yours pivots on two axis. I find your two jigs very useful. The only problem I find with the drill grinding jig is that larger drills tend to rock in the V grove. I think increasing the length of the V groove will solve this problem. You may just be able to see that I moved the grub screws to the corner of the square bar to give a longer length of thread when there is a large hole through the bar for big cutters. The grinder head is also your design with the addition of a reversing switch and the hub being keyed to the shaft. By the way I am very impressed with your website. Les. |
Stub Mandrel | 11/12/2011 20:46:16 |
![]() 4315 forum posts 291 photos 1 articles | Les, When you said you has successfully uploaded a picture recently I looked at your album If you comment on a picture it starts a thread like this one. Neil |
Les Jones 1 | 29/12/2011 09:00:44 |
2255 forum posts 156 photos | I noticed that Axminster Tools have cross vices on the sale page of their website. The 3" one is £17.44 I think this would be a cheap basis for a low cost tool grinder. Les. |
Stub Mandrel | 29/12/2011 13:03:11 |
![]() 4315 forum posts 291 photos 1 articles | A cheap sorce of cast iron even if its total cr*p! Neil |
Michael Horner | 16/02/2013 17:46:30 |
222 forum posts 63 photos | Hi Les I like your ingenuity, what size grit is your wheel? I'm toying with the idea of using and old lathe, ML2 I think but there isn't a Myford on the casting so who knows. Cheers Michael |
Les Jones 1 | 16/02/2013 18:31:22 |
Hi Michael, Les. |
Michael Horner | 16/02/2013 18:57:49 |
222 forum posts 63 photos | Hi Les Thanks for that. I think they still sell on Ebay, I'll check it out. Cheers Michael
Jens Eirik Skogstad | 16/02/2013 22:15:10 |
![]() 400 forum posts 22 photos |
The poor man's tool works as well as expensive tools. With knowledge and good job, you get a wonderful result of your craft. |
IanT | 17/02/2013 10:30:24 |
1993 forum posts 212 photos | Hi Les, Any chance of a couple of more photos of your arrnagement please - one from the side and one a bit closer up of the table arrangement ? Regards, IanT |
Bazyle | 17/02/2013 11:40:25 |
![]() 6324 forum posts 222 photos | As it looks rather like a Kennet grinder perhaps the prominent angle graduation on the table for that design would be of value. |
John Stevenson | 17/02/2013 13:07:57 |
![]() Moderator 5068 forum posts 3 photos | I posted this way, way back on another forum in the 1990's just as a concept idea. It was never built or even close to it. The picture is just a posed shot of what could be achived with a minimum of "Chequebook Engineering"
The part not really visible between the vise and spin indexer is just a piece of rusty black angle iron. Obviously this needs redesigning to use a piece of non rusty bright angle iron. Edited By John Stevenson on 17/02/2013 13:09:59 |
Les Jones 1 | 17/02/2013 18:14:55 |
Hi IanT,
There are more pictures in "My Photos" Les. |
John Stevenson | 17/02/2013 18:21:30 |
![]() Moderator 5068 forum posts 3 photos | At least you built yours Les, mine was only a concept idea which ironically was shot down by many of the readers as a rubbish idea.
Should have used brass and stainless, obviously not enough bling in it to attract the unwashed. |
Stub Mandrel | 17/02/2013 20:03:32 |
![]() 4315 forum posts 291 photos 1 articles | John, You should have bolted the grinder to a bit of scaffold bar, epoxied to a bit of plywood, like I did.
The other mistake was not to cover it all with smoothrite As you can see it also makes a really fine tablemat. Neil |
IanT | 17/02/2013 22:57:51 |
1993 forum posts 212 photos | Thanks for the photos Les - very helpful. John - I might have some rusty black angle iron somewhere down the shed but I'm fairly certain that I don't have any non-rusty stuff anywhere (just about everything in my shed is rusty!) - so please put a hold on that redesign. Regards,
IanT Edited By IanT on 17/02/2013 22:58:23 |
Bill Todd | 21/03/2013 14:39:02 |
2 forum posts 4 photos | Knocked up something similer a while ago. I used a motorcycle forkleg as a slide for grinding endmill flutes
Edited By Bill Todd on 21/03/2013 14:45:17 |
