How to dress a small diamond wheel
dcosta09/06/2011 15:33:21
484 forum posts
206 photos
Hello!
I have a small diamond wheel (I bought it from Arc Euro Trade) serving an Harold Hall's "Tool & cutter grinder" and would like to know what's the best way and instrument (dresser ?) to use to dress it.
Can anyone help me, please?
Dias Costa
Edited By Dias Costa on 09/06/2011 15:34:29
Stephen Benson09/06/2011 15:45:04
201 forum posts
68 photos
On Ebay you can buy a diamond wheel dresser, how ever I have been unable to work out whether it is device for dressing diamond wheels or it is a diamond tipped device for dressing normal wheels.
So I would be interested in this thread as well.
John McNamara09/06/2011 16:00:17
1311 forum posts
113 photos
Hi Stephen
You dress diamond wheels with a stone dresser
You dress stone wheels with a diamond dresser
I found some good videos here:
Cheers
Edited By John McNamara on 09/06/2011 16:01:15
Bogstandard10/06/2011 18:21:17
263 forum posts
For dressing diamond wheels you really require what is known as a brake dresser.
It really is the only correct way to get them perfectly true.
Not cheap though, a new one will cost towards a grand. I was lucky and picked a Norton one up on eblag a while back for £27, at that included one brand new and another hardly used carborundum wheels.
NJH10/06/2011 18:44:17
2314 forum posts
139 photos
Hi All
I have little knowledge of this but seem to remember that with the conventional stone wheel the (diamond) dresser's use is to remove spent abrasive particles and thus expose fresh sharp ones. With a diamond wheel there is only one lot of diamonds and the
function of the ( stone ) dresser is to remove the material accumulated from grinding that is clogging up the wheel. The stone wheel can (should?) be dressed when fitting to enure balance whereas, of course, this is not possible with the diamond wheel.
Well guys is my recollection correct?
Norman
Dusty10/06/2011 19:08:50
471 forum posts
8 photos
I understand that a piece of York stone presented to the diamond wheel will work quite well and remove the accumulated rubbish. I hasten to add that I have not tried this but a tiler who was working for me at the time used this method. I can see no reason why it should not work. Observations gentlemen?
Clive Hartland10/06/2011 19:42:20
2559 forum posts
40 photos
To expose new grit on a stone wheel you should a Star dresser which has a multi head full of spiked metal wheels. These dig into the matrix and remove the bond and exposes new grit.
Using a diamond dresser on the wheel only smooths the surface and trues its shape and in fact lessens its ability to cut.
With a diamond wheel it depends which sort, a rubber bonded type will only burn if done with a stone and the harder type of bond will have diamond grit pulled out of the matrix.
I have not yet happily dressed a diamond wheel! Preferring to let it do its work gently and slowly and not forcing a tool being sharpened.
Bogstandard10/06/2011 20:44:59
263 forum posts
The reason for the brake dresser is that as the diamond wheel starts to become true again, the brake dresser automatically reduces the friction of the stone to the wheel.
Using a lump of stone to do your dressing, I personally don't think you will get a perfectly dressed diamond wheel, as it will be relying on 'finger feel' or sight to detect when it is truly flat and square.
For those who have never seen a brake dresser, here is mine. The carb wheel is gently fed onto the diamond wheel face, and starts to spin, being driven by the diamond wheel. As it is running up, a centrifugal brake (on the other end of the spindle) starts to put a holding pressure onto the dressing wheel, so starting to gradually wear the face off the diamond wheel, and as stated above, as the diamond wheel is trued, the brake pressure reduces.
BTW, the 3 diamond wheels in the background, the two dirty ones are diamond cut off wheels, about 3/32" wide, the clean one is just a standard narrow grinding wheel. All for use on the surface grinder.
The use of diamond bonded wheels in the model engineering fraternity has only recently, in the last few years, started to be used. So really, although the wheels can be obtained reasonably cheaply, the methods of dressing haven't yet caught up with us from industry. So that means, until the dressing facilities really come down in price, or you are lucky and find a cheap one, you just might be stabbing in the dark with theories about how to dress them correctly.
Here is a second hand one at a very reasonable price
http://www.jubileemactools.com/website-pages/NORTON__No2__Brake_Dresser-p-398.html
Nicholas Farr10/06/2011 21:31:57
2257 forum posts
1099 photos
Hi,
for those who don't know or haven't seen a star dresser for stone wheels that Clive has discribed, here is a photo of one with a new set of replacement star wheels seperation discs, pin and bushes.
Regards Nick.
Edited By Nicholas Farr on 10/06/2011 21:53:52
Edited By Nicholas Farr on 10/06/2011 22:00:23
Pat11/06/2011 03:06:54
94 forum posts
Well Bogstandard has said it all dressing diamond wheels is not going to be cheap. The single diamond, multiple crushed diamond and the star wheel are all for the grit wheel dressing.
The embedded diamond wheel comes in several forms. Some use metal plating to hold the diamond grains in place. Others use resin or rubber like compounds or even diamond grit embedded in a thick brazed coating.
For the final grind I use a soft copper wheel. The wheel is coated in olive oil and a sprinkle of diamond dust added. Enough to cover a match head is about right for a 50mm wheel. The wheel is then rolled under pressure - ball race mounted on a wooden handle serves well. The aim is to impregnate the copper with a number of the grains of diamond. Being mean I wash off the surplus with white spirit and allow the white spirit to evaporate saving the diamond grains and olive oil for refreshing the surface as it needs to be done frequently. Vodka would also work and smell better!
The bumps in a diamond cut off saw are readily removed by use of a reasonably soft stone such an old brick. The trick is to press the brick into the wheel very gently but firmly and use a very high speed with plenty of water. Messy but then the coolant keeps the dust under control. Unfortunately any truing removes diamond and the wheels have only a very thin layer. If the wheel is significantly out of true I would reject it as faulty. Using light but firm pressure from a large heavy chunk of metal that has a good flat face should do all that is necessary on small wheels. It is essential that the finer grades of diamond wheel are not used to rough out or you risk making profile wheels. The edge being ground needs to be kept in motion to use the whole of the surface.
Regards - Pat
dcosta14/06/2011 13:00:41
484 forum posts
206 photos
Hello everyone.
Pat (and others) has already said the most important. However I would like to share my experience in the dressing diamond wheel.
To regularize the surface of my diamond wheel I started to try with a regular dresser, one of those that presenting a rectangular metalic surface with abrasive particles scatered over it. Almost ruined it and practically no effect on the grinding wheel, diamond ...
Then I tried on a dresser that I have almost thirty years ago that has the shape of a stick with the material into a thin metal tube. Produced a great quantity of abrasive powder and the result on the diamond grinding wheel is not noticeable ...
Finally I used a bit of a green grit wheel. This time, after producing a considerable quantity powder, some efect was also produced on the diamond grinding wheel surface. The largest bumps were removed.
It served my imediate purposes but is not a good solution.
Thanks to all who helped.
Best regards
Dias Costa
Edited By Dias Costa on 14/06/2011 13:57:15
