Steve Wan | 03/05/2011 12:25:08 |
131 forum posts 3 photos | Hi guys,
Good to be back! When I was using my German-made breast drill with 2 speeds made me thinking that if I could make a table-top hand drill press with auto-feed would be exciting!
Has anyone done it? After I google for answers, I found in the 1900s there were many post drill in farms also smaller version both in shape of wood working hand drill attach to a stand or a box up mechanism with 2 speeds with a heavy flywheel hanging above it for auto-gravity feed.
Though with the electrical drill press around is more useful enough for most work. But there're times the job is too long for that, one could clamp against a table and hand drilling the job at ease...
I have the gear ration in mind after I dismantled the breast drill but no idea how the working mechanics of the auto-feeding gears, to engage or dis-engage?
Any guidelines is much appreciated.
Steve |
Richard Parsons | 03/05/2011 13:36:57 |
![]() 645 forum posts 33 photos | Steve The automatic feed on the hand driven pillar drill is fairly simple. There is a feed screw which is rotated by hand (manual feed) this pushes the drill down wards. The feed nut is part of the frame. The feed screw has a long key-way which engages with a key inside a ratchet wheel which has its teeth not on the edge but on its face. An eccentric is mounted on the main drive shaft which moves a lever back and forward. This lever carries a pawl at the other end which engages the ratchet wheel pushing round. This screws the drill head down.
Dick
Nicholas Farr | 03/05/2011 19:59:41 |
![]() 3360 forum posts 1542 photos | Hi Steve, the two pictures below show what Richard has explaned, although this is only a single speed version. The pawl is lifted and swung back when you wish to back off the drill or if you just use hand feed.
Regards Nick.
PS if you would like a few close up pictures from different angles, just let me know. Edited By Nicholas Farr on 03/05/2011 20:07:15 |
Steve Wan | 04/05/2011 02:50:36 |
131 forum posts 3 photos | Hi Richard and Nicolas
Thanks for the great help! With Richard discription and Nicolas photos I can grasp the picture. Nicolas - possible to send a few more photos with a white paper behind so that I can see the keyway, ratchet and pawl? Better at different views...sorry to bother you here.
Wanted to make this devise a long time ago. I have no problem with the handwheel and bevel gears. It's the auto feed design above it . You could post the pictures here for all to share or email me: stewan@gmail.com
Thanks a million inadvance to both of you
![]() Steve |
Nicholas Farr | 04/05/2011 12:05:23 |
![]() 3360 forum posts 1542 photos | Hi Steve, have uploaded some more photo into my Autofeed Hand Bench Drill album. Hope these give you a better idea, but feel free to ask any questions about them.
Regards Nick. Edited By Nicholas Farr on 04/05/2011 12:06:22 |
Steve Wan | 04/05/2011 12:31:53 |
131 forum posts 3 photos | Hi Nicholas
Thanks a million! This is my early Christmas gift for next project! Wanted to make one for years...I have downloaded all your useful photos, yet to study it more closely with Richard's description.
Any further questions can I email you? Or here?
Steve with delights ![]() |
Nicholas Farr | 04/05/2011 12:35:58 |
![]() 3360 forum posts 1542 photos | Hi Steve, if you do it here, others may also benifit as well. But you may PM me if you wish.
Regards Nick. |
Ian S C | 04/05/2011 13:34:11 |
![]() 7468 forum posts 230 photos | Sounds like a good project Steve, I,v got a wall mounted vertion, I,v modified it so that it is driven by a .3 hp 1450 rpm motor from a washing machine, and its been fitted with a Jacobs 34?5 chuck, the origional drills were 1/2": shank held in the spindle with a grub screw. Where do you get a drill press today with automatic feed? Mine gets quite regular work. Ian S C |
Steve Wan | 05/05/2011 03:46:07 |
131 forum posts 3 photos | Hi Ian
Thanks for the reply! I don't think I have ever seen a post /pillar drill in Singapore even during my childhood...but I had seen a leg vise in a carpenter shop. Those old and unique hand tools are disappearing with the event of electrically control hand tools. I'm still using a number of cast iron hand drill and ratchet brace for spot drilling and countersunk jobs that needs slow and powerful feed rate. Small drill bits lesser than 5mm diameter are hand sharpened by hand grinder...
Just like the hand saw mitre for picture framing is also gone now. I bought an asian made mitre copying European design, though some parts are weak. That will be my other project to beef it up to saw alumimium plates.
I got an old breast drill that's made in West-Germany. It has 2 speed control. I took them apart and examine the gearing ratio...able to get those standard gears to make another but comes to auto-feeding I'm lost. Lucky, I have guys like Richard and Nicholas to guide me this path. Will be making one smaller version for hard to drill places. I have a china-made drill press that's able to handle most jobs...
You can email me to stay intouch of those wonderful dated metal/wood working tools.
Steve |
Terryd | 05/05/2011 04:51:15 |
![]() 1936 forum posts 179 photos | Hi Steve, You may be interested in this website, I came across it some years ago and was pleased to find it still exists. Unusual in these days of the web with it's ephemeral nature. There is a very good explanation, with pictures, of the feed mechanism which you may find useful in your quest.. Enjoy Best regards Terry. Edited By Terryd on 05/05/2011 04:54:17 |
Steve Wan | 05/05/2011 07:54:56 |
131 forum posts 3 photos | Hi Terry
Thanks for the info.
Hi Nicholas
I think I see light at the end of the tunnel! The eccentric shaft is the driving force for the pawl and ratchet auto-feed and rotate the drill chuck below...one last question:
The threaded feed screw and the lower drill shaft both have key-ways for the ratchet plate above and the bevel nut below respectively. Are these 2 rod connected? There's a thrust bearings inbetween...if they're in 2 pc the driving force down is ok what about withdrawing upwards? How're they linked?
Thanks inadvance.
Steve |
Nicholas Farr | 05/05/2011 08:12:12 |
![]() 3360 forum posts 1542 photos | Hi Steve, the drill shaft and feed screw are two seperate items. The screw thread is hollow, and the drill shaft from the thrust bearing upwards is reduced down to a sliding fit inside the hollow of the screw thread, it terminates on top of the feed screw handle with the double nuts, as seen in the last photo.
Regards Nick. |
Nicholas Farr | 05/05/2011 08:43:18 |
![]() 3360 forum posts 1542 photos | Hi Terry, very interesting site you found there, thanks for sharing it with us.
Regards Nick. |
Ian S C | 05/05/2011 12:51:00 |
![]() 7468 forum posts 230 photos | I'v got a friend who has a small private museum (about 100 M from my home), he has some bench hand drill presses, next time I see him (he lives and works in Christchurch), which could be a week or two, I'll see if I can borrow one or two of them so that I can get some photos, we'll just have to wait and see. Ian S C |
Steve Wan | 06/05/2011 07:58:28 |
Hope to see any photos you have more importantly if the gears are enclosed, possible to remove the cover before you take photos?
This is the bench hand drill which I'm looking for, a smaller version of Post drill with similar principles. Though China-made this design was originated by the German in early 1900.
Please alert me if anyone out there have seen this machine on sale in hardware stores.
Wish to mail-order one. This machine is very suitable for light and hard to drill places as it could be swung around 360 deg. if the job is clamp on side of the workbench.
Steve |
Ian S C | 06/05/2011 14:59:07 |
![]() 7468 forum posts 230 photos | The machines I am thinking of come from a period between the end of the 19th century, and the 1930s, the one in your photo is modern by comparason, it looks like a useful tool. The old ones have exposed gearing, although my one has a rather crude gaurd over the gears. Ian S C |
Nicholas Farr | 06/05/2011 22:14:04 |
![]() 3360 forum posts 1542 photos | Posted by Ian S C on 06/05/2011 14:59:07: The machines I am thinking of come from a period between the end of the 19th century, and the 1930s, the one in your photo is modern by comparason, it looks like a useful tool. The old ones have exposed gearing, although my one has a rather crude gaurd over the gears. Ian S C Hi Ian, Steve picture may seem to be a modern one however, the drill in the picture below is not unlike the advert from S. Tyzack and Son Ltd., London, placed in Model Engineer & Practical Electrician July 5th 1934.
Regards Nick Edited By Nicholas Farr on 06/05/2011 22:14:24 |
Steve Wan | 07/05/2011 09:17:58 |
This machine is very handy once one understand the purpose of it, being able to swing 360 deg is the most advantage---will send you photo at work of my DIY stand.
Hi Nick
Wow! I'm so lucky to get you here! This is the machine I have in mind to build...sorry to bother you again. Ok to take photos of the gearing and auto-feeding mechanism enclosed?
I have been using a West-Germany breast drill of 2 speeds just like yours with 2 bevel and 2 normal gears. By attaching the handle to each spindle one gets a slow and fast speed rate. This part I understand fully. This bench hand drill's auto-feeding must be more compact than the earlier Post drill...will be interesting to study it.
I will post my stand and support of the breast drill I did which serves me well for almost 25 years for odd places to drill. Will be upgrading to a box type smiliar to yours for heavier drilling, seems getting one from India/China is not easy here. I can get those internal gears locally.
Also surprised that you kept the 1934 ads for so long
![]() Nick can I have your email? You could be my teacher or engineering buddy, couldn't find your email here...stewan@gmail.com
Steve |
Ian S C | 07/05/2011 15:06:39 |
![]() 7468 forum posts 230 photos | |
Steve Wan | 07/05/2011 17:05:29 |
131 forum posts 3 photos | Hi Ian and Nick
Here's my version of drill press though miles apart from yours but comes with 2 speeds. This structure is quite rigid and simple but at times needs to check the vertical axis while drilling.
Any comments here? No auto-feeding, feeding is done by applying pressure above.
Nick if I get the chance to view S. Tyzack and Son Ltd - drill press interior, am sure I could build one hopefully...I hear from you with delights!
Steve
