Suggestions please.
Ramon Wilson28/03/2011 22:06:36
1283 forum posts
367 photos
Hi Graham,
Given that you mean with the means at your disposal ie short of a decent shadograph ......
Could you not try 'copying' said tool by laying it cutting side down on your scanner and taking an image - then enlarge image and check against Cad drawn lines at 29 inclusive
Would that be an acceptable 'simple solution' ? - I don't know - just a thought.
Regards - Ramon
Edited By Ramon Wilson on 28/03/2011 22:08:57
blowlamp28/03/2011 22:13:58
1590 forum posts
102 photos
If you have a rotary table and milling machine, you could make a simple jig from MDF or plastic etc with a couple of 29 deg slots to hold the cutter and present it to the grinding wheel in a predictable manner.
It would be easy to regrind the tool if you need to as well.
Martin.
John C28/03/2011 22:26:43
273 forum posts
95 photos
Hi Grey,
Would a sine bar and slip gauges inside (say) the parallel jaws of a milling vice work? You'd still need to sight the tool edges inside the included angle but you could maybe feel the rock in the tool.You could nip the jaws up onto parallels even if this left the tool nose unsupported.
All th ebest,
Terryd28/03/2011 22:33:43
1936 forum posts
179 photos
Hi Graham, Ramon,
Ramon's idea is similar to a suggestion I made about measuring the angle of screw threads a while ago. It actually works very well but in your case you need to place the tool 'face down' on the scanner platen. Also, the settings of your scanner need to be set to a high resolution so that you can enlarge the image without degradation. I have used this method very successfully for all sorts of applications over the years.
Terry
John Haine28/03/2011 23:05:22
4622 forum posts
273 photos
I doubt that there is any simple way of checking it that will be any more accurate than the Quorn was in making it! I must say though that Ramon's & Terry's idea with the scanner is inspired....having spent quite a long time adapting the bits of an Aldi microscope with CCD camera and a cheap Proxxon XY table into a travelling video microscope last year, I wish that I'd thought of this first!
Sam Stones29/03/2011 05:28:29
867 forum posts
323 photos
Hi Graham,
Although the optics may not be perfect, do you have access to an old slide projector? You could examine its potential as the starting point for a shadowgraph.
In my case, I'm able to turn to a couple of toolmaker friends who might possess a professional shadowgraph. Then of course, there are the technical colleges who may perhaps provide some help.
Sam
Stewart Hart29/03/2011 08:02:06
673 forum posts
357 photos
A projector can be easily rigged up using a mag light and a magnifying glass like this
[IMG]http://i431.photobucket.com/albums/qq32/sbwhart/Modmodder/IMG_2156.jpg[/IMG]
You just have to calibrate it using something of known size a set of radius gauges works fine, to get its magnification
When you know its magnification just draw up a screen for comparison.
This is the result
[IMG]http://i431.photobucket.com/albums/qq32/sbwhart/Modmodder/IMG_2155.jpg[/IMG]
Stew
PS
I can never get the insert pic thing to work
Steve Garnett29/03/2011 10:16:42
837 forum posts
27 photos
Posted by Stewart Hart on 29/03/2011 08:02:06:
I had trouble with that once too. But actually it's quite easy; use the icon with the little mountains in it, and post the URL in that.
So your two pictures:
Les Jones 129/03/2011 11:57:42
2255 forum posts
156 photos
Hi All,
Just a word of caution about the scanner idea. Last week when someone mentioned the idea for checking thread angles I thought I would try it. I tried at first using a flatbed scanner (Using 5mm threaded rod for the test.) This worked quite well. I then thought I would try a "Veho" USB microscope. This did not give the correct result for the angle. I think it must stretch the image in one direction. So I think to use the method the result should be checked by scanning a second time with the object at 90 degrees to the first scan / photograph. I used "Paintshop pro" to measure the angle. When drawing lines on top if the image the angle of the lines is displayed. I also have a very low tech suggestion but I suspect that it will not be accurate enough. Clamp the tool down on top of a sheet of paper. Hold a straight edge against the side of the tool making sure it is fully in contact with the edge then draw a line along the straight edge. Repeat for the other edge then use a large protractor to measure the angle between the lines.
Les.
John C29/03/2011 12:29:23
273 forum posts
95 photos
Hi Gray,
Further to my post above, I rigged up a mock up of the vice and sine bar. The two bars between the vice jaws are machined together to the same length to ensure the jaws are parallel and the rubber band is to keep the sine bar and the slips together. I put a key ring LED under the tool to show any gap. The 'tool' is a bit of steel I ground to 29 deg internal angle on my Worden, set using an ordinary protractor, so as you can see it would need a skim to be spot on.
The first photo shows is without flash and with the matching bars removed to show the keyring LED shining in the gap, the second shows the general idea.
Hope this helps,
( And I also hope I have got the right end of the stick!!)
Steve Garnett29/03/2011 13:04:34
837 forum posts
27 photos
Posted by Les Jones 1 on 29/03/2011 11:57:42:
Les, I'm sure you are right about the aspect ratio changing when it shouldn't. One thing you can easily do as a sanity check with the microscope is to place two steel rules at right-angles to each other and the piece you are measuring at the junction of them. If you print the result on paper, you should be able very easily to come up with a compensation value, just by measuring the same indicated distance on each and establishing the difference between them. In principle you could do this with a scanner as well, although to do it easily you'd need scales printed on acetate.
Terryd29/03/2011 13:30:38
1936 forum posts
179 photos
Hi Steve,
Do remember that printers aren't very accurate with aspect ratios, you need to calibrate them first or use a calibration print.  A relatively easy way to check is to print a regular shape (circle, square) in both landscape and portrait and check the aspect ration.
Instead of two rulers on a scanner try scanning graph paper or good quality squared paper.
Terry
Edited By Terryd on 29/03/2011 13:41:07
Steve Garnett29/03/2011 13:42:20
837 forum posts
27 photos
Posted by Terryd on 29/03/2011 13:30:38:
Terry, the whole point of this method is that the calibration is included with the scan! When you print the image you want, you are also printing the image of the rulers, or transparent calibration sheet - this way you can measure the scales and compensate directly from your final image print. With the acetate sheet method, you have a slightly worse problem, because you don't want to print it initially on a device with inherent linearity errors, so you may be better off scribing a sheet rather than printing it. OTOH, you may find that you get an acceptable image from the rules laid on the platten. I'll give it a go later and see if I can illustrate this.
Les Jones 129/03/2011 15:18:01
2255 forum posts
156 photos
Hi Steve,
I don't actually need to do any angle measurements at the moment. The idea just seemed worth trying. I also found that the image produced by the USB microscope was more difficult to line up the measuring lines on so I have discounted using it. Back to Graham's original question. Using the acme thread gauge with a suitable parallel (eg some feeler gauges.) on one side of the tool may work. A variation on the rotary table idea might also work if the tool is not too small. With the rotary table mounted on a mill and the tool clamped to it use a dial gauge to align one edge of the tool with the X or Y axis. Note the reading on the rotary table then repeat for the other edge and calculate the difference.
Les.
blowlamp29/03/2011 15:20:41
1590 forum posts
102 photos
Has anyone contacted The National Physical Laboratory yet, to see if they can help?
Martin.
Terryd29/03/2011 15:37:45
1936 forum posts
179 photos
Hi Steve,
My point was that by using only one check, which is inaccurate, The scan or the print. Surely it is better to know the inaccuracy in each component so that simple calculations will give correct answer whether just printing, scanning or both?  If you know the accuracy of your scanner any inaccuracy can be corrected in your graphics program and angular measurements etc can be made on screen in a cad program without printing.
By using graph paper to calibrate you can check the accuracy at different places on the platen.
Why use acetate? You only have to place the rulers face down on the platen and they will be scanned. Personally, I still think that I would prefer to know the accuracy of my scanner and printer rather than having to add rulers every time.
Best regards
Terry
Edited By Terryd on 29/03/2011 15:43:51
Steve Garnett29/03/2011 16:32:43
837 forum posts
27 photos
Sorry - had to go out for an hour, but I did what follows in less than five minutes (including fetching the scanner) before I went:
Posted by Terryd on 29/03/2011 15:37:45:
This method covers both in one go, and generally the linearity errors in scanners are pretty small - it's the scaling inaccuracy that can be much greater.
You are quite correct about the acetate - it's not needed. But fixing the rules at right-angles, and in a sensible alignment only took a moment with two bits of magic tape; it really wasn't a problem. What you get from this is either a large scan (which I haven't included) that would enable you to establish the aspect ratio error pretty accurately, and another one which would enable you to make a pretty accurate (well in terms of grinding) measurement directly, without any need to apply calibration corrections at all.
The small divisions are 0.5mm. And it would not be difficult to establish the relative angles here, I think. Please excuse the lump of tool steel - I inherited it, and it's untouched. No I don't know why it's like that at all - it's only there for illustrative purposes.
Geoff Theasby29/03/2011 17:21:28
613 forum posts
17 photos
As much for my own edification as to help, but could you measure the angle of each side of the tool with an angle gauge, perhaps an electronic one, against the horizontal, then you could check that each side was in agreement? You might have to turn to tool on its side to do this.
Geoff
Steve Garnett29/03/2011 17:28:50
837 forum posts
27 photos
Incidentally I checked the scaling inaccuracy on the scanned result above, and it's about 0.33%, FWIW. And you can calculate directly the angle that the first bit of grinding makes to the vertical by plotting intersecting lines (I used Serif Draw plus) very carefully on a blown-up image, measuring the difference between them and using Arctan (H difference/V difference), arrive at an answer. What you discover when you look at the above one very carefully though is that the ground line is only straight over about half of its length, so the accuracy is somewhat compromised anyway, unless you are very careful.
Edited By Steve Garnett on 29/03/2011 17:29:27
Steve Garnett29/03/2011 17:38:10
837 forum posts
27 photos
Posted by Geoff Theasby on 29/03/2011 17:21:28:
Geoff, I think that there are perhaps as many ways of doing this as you could think of! The only thing you have to be aware of with each one is where the potential errors might creep in, and how much confidence you could reasonably have in the result as a consequence.
So in my example above, I've measured the angle of the ground edge to the horizontal, and if I've got the sums and error direction correct, it's 47.26 degrees minus 0.33%. Electronic angle gauges have an inherent accuracy of about 0.1 degrees, I believe. You'd have to be very careful about physical alignment of the gauge though, because you wouldn't have much surface to work with, would you?
Rapid RC
Dreweatts
