Flycutter with 2 Morse taper and M10 thread
Flycutter 2 Morse taper M10 thread
David Clark 120/01/2011 09:51:42
3357 forum posts
112 photos
10 articles
Hi There
Does anyone know where I can get a flycutter with a 2 Morse taper shank with an M10 thread for the drawbar?
All the ones I have come across have a 3/8 Whitworth thread.
Also, where can I get a length of 3/8 Whitworth studding?
regards David
Edited By David Clark 1 on 20/01/2011 09:56:47
NJH20/01/2011 10:02:42
2314 forum posts
139 photos
Hi David
Here is a ref:-
Cheers
Norman
Terryd20/01/2011 10:16:42
1936 forum posts
179 photos
Hi David,
have you thought of the straight shank flycutters available which can be used in a chuck either on the milling machine or lathe. They are quite successful and I bought my set at RDG. The 75mm square block below was a test using the cutter in the picture. table was hand fed  and the surface was even better than it looks here. This was the day before my workshop burnt down.
Terry
Edited By Terryd on 20/01/2011 10:27:06
Roger Woollett20/01/2011 10:21:27
123 forum posts
4 photos
EKP have 3/8 BSW studding in 12" lengths on their website. They also do metric and BA studding.
HasBean20/01/2011 10:27:02
141 forum posts
32 photos
Hi David,
Arrand do a range of flycutters with interchangeable shanks with a choice of drawbar threads.
Paul
KWIL20/01/2011 10:28:41
3424 forum posts
66 photos
Not dfficult to screwcut the required thread on the end of a plain drawbar.
Michael Cox 120/01/2011 10:30:57
544 forum posts
27 photos
Hi David,
I too have searched for an M2 flycutter with an M10 thread. They seem to be very rare!
I ended up making a flycutter as shown here:
I guess you were thinking of the 3/8" BSW studding in order to make a drawbar. It would be very quick to single point thread both ends of a piece of 3/8" round in order to make a drawbar.
David Clark 120/01/2011 11:57:19
3357 forum posts
112 photos
10 articles
Hi Mike
Yes, studding for a drawbar.
MyTom Senior has a metric Drawbar and the studding would enable me to use a flycutter in it.
I used the flycutter once but no drawbar, just a tap to fit it to the taper but I only did that once in an emergency. Don't want to do it on an ongoing basis.
However, I am fairly sure my KXi CNC mill is a 10mm thread and I don't really want to change the captive drawbar as the ER holders are 10mmhence the need for a 10mm threaded flycutter. At least, the ER holders fit the Tom Senior 10mm drawbar.
I do like the look of the smaller head flycutter available I think from Chronos.
Could be very useful.
regards David
Edited By David Clark 1 on 20/01/2011 11:58:23
David Clark 120/01/2011 12:03:59
3357 forum posts
112 photos
10 articles
Hi Terry
I am not keen on the parallel shank flycutters.I have heard they cause fires.
Only joking but I like the balanced head ones.
Actually, that is not a bad idea.
I am thinking along the lines of the Tormach quick change system based on a 3 Morse collet and parallel shank tool holders.
I am basing mine on a 2 Morse collet and 12 mm shanks.
A 12mm parallel shank might not be a bad idea.
regards David
Edited By David Clark 1 on 20/01/2011 12:19:01
David Clark 120/01/2011 12:12:22
3357 forum posts
112 photos
10 articles
Hi HasBean
Had a look at Arrand and while I expect they are the highest quality £41 seems a bit expensive.
regards David
David Clark 120/01/2011 12:13:49
3357 forum posts
112 photos
10 articles
Hi Mike
Link does not appear to work.
regards David
Terryd20/01/2011 12:24:55
1936 forum posts
179 photos
Hi David,
The set I bought from Chronos worked very well and the quality wasn't bad but then again don't use them too often. the size is adequate and I like HSS tooling for steel and non ferrous so they are pretty well perfect for me. But I suppose which you buy depends on the normal factors.
I just used them in a straight shank milling cutter holder as I think they have a Weldon flat but I'm not sure, it's been a while now, but they even worked well in a 3 jaw Jacobs chuck as there is no helix there is no force to pull the cutter out. (By the way, the clinching factor was the price, not an expensive mistake if you don't get on with them and easy to sell on eBay).
Terry
David Clark 120/01/2011 12:42:44
3357 forum posts
112 photos
10 articles
Hi Norman
This site is fine until I put my postcode in.
Price jumps from £5.50 to £20 + cost of goods.
Have they not heard of Royal Mail for small orders?
regards David
The Merry Miller20/01/2011 13:16:19
484 forum posts
97 photos
Dave,
You could try South Essex Fasteners (01702 615326).
I've been using them for years and their prices are astonishingly good.
I recently bought two 1 metre lengths of 3/8" whit studding, a fistful of nuts and washers and the whole lot came to about £5.
I used the studding for a drawbar on my new 2MT Posilock chuck.
I don't know what their post charges are but it's still worth checking them out.
Edited By The Merry Miller on 20/01/2011 13:19:49
Michael Cox 120/01/2011 13:48:00
544 forum posts
27 photos
Hi David,
Try this link instead:
Ian S C20/01/2011 14:13:19
7468 forum posts
230 photos
David, my large flycutter screws onto the thread on the spindle nose, no drawbar, home made. The draw bar for my collet chuck was made by cutting the heads off two bolts, and welding them together,on the top end a nut is threaded on, then another nut welded on the end. Ian S C
dcosta20/01/2011 14:32:07
496 forum posts
207 photos
Hello David.
Some time ago I bought from one of the two: Chronos or RGDTools, a set of three flycutters which has a set of four detachable shanks. Two of them were MT2 and MT3. The other two are cylindrical.
The MT2 shank had a 3/8" thread and the drawbar in my milling is 10mm.
I had the flycutter in my hands and my only solution was to use a 10mm HSS tap and redo the thread in the MT2 shank.
Couldn't analyze the resulting threads in the detail. But given the length of the section of the drawbar entering the shank I thought the resulting threads would be enough to support the efort.
I had to do the same operation in other tools I bought with threads 3/8" and I find it is a "good enough" solution.
Notes:
Depending on the hardness of the MT, You may have to use a very good set of taps. After some trying I used a set made by a Spanish company named IZAR. I was most satisfied with their taps. After that I mostly buy cutting tools made by them and distributed here in Portugal.
Yes, i found oily gunk within. So if You go this way You should take care.
My only connection with IZAR is as a satisfied customer.
This is their URL :
Best regards
Dias Costa
Edited By Dias Costa on 20/01/2011 14:34:14
Edited By Dias Costa on 20/01/2011 14:35:29
Mark Dickinson20/01/2011 19:24:29
48 forum posts
4 photos
MSC Industrial do 3/8" BSW studding. Part numberFNZ-60380E. It's just a bit more expensive than Normans link, and in typical MSC fashion you don't know the postage cost until after you confirm your order
Mark
IanT20/01/2011 19:32:34
1896 forum posts
184 photos
Hi David,
I had the same problem (e.g. my Flycutter had a 3/8 thread)- and I simply made an adaptor (3/8" > M10). It lives permanently on the end of the morse taper and Iuse the one M10 drawbar for everything.
David Clark 120/01/2011 21:32:42
3357 forum posts
112 photos
10 articles
Hi Mark
Thanks for that.
I will phone them tomorrow.
I have an account so post is free.
I need a couple of reamers anyway.
I did not see the size in the catalogue but they are on the website and I can also check they are in stock.
regards David
walker midge
JD Metals
rapid Direct
