Forum sponsored by Allendale May 23
Detail photos of Tender
Nigel Bennett26/03/2010 12:13:08
284 forum posts
6 photos
Tender Axlebox:
[image]
[image]
(The brown bits are a garden seat!!)
[image]
[image]
Rear Brake Beam LH)
[image]
Rear Brake Beam RH:
[image]
Buffer Detail
[image]
[image]
Nigel Bennett26/03/2010 12:14:07
284 forum posts
6 photos
Rear buffer beam:
[image]
[image]
[image]
Fireman's Side Tender Doors:
[image]
Shovelling Plate:
[image]
Tender front LH:
[image]
Tender Front RH:
[image]
Tender Front RH, lower:
[image]
Nigel Bennett26/03/2010 12:15:18
284 forum posts
6 photos
Tender upper:
[image]
View through into coal space;
[image]
Lower RH front:
[image]
Rear 3/4 view:
[image]
RH steps:
[image]
RH steps & part of loco injectors:
[image]
Terryd26/03/2010 14:34:37
1926 forum posts
179 photos
Wouldn't these be better in the 'Albums' section where most of us look for pictures?
Nigel Bennett26/03/2010 15:58:46
284 forum posts
6 photos
Looking at the "Albums" section, it seemed to me to be only photos of models. I just thought it more appropriate to put 'em here, because if you're building a Q1 this is where you'd look.
Terryd26/03/2010 16:42:40
1926 forum posts
179 photos
There are lots of different subjects for the albums if you look.  There are machines, workshops, castings etc, I don't think that the section is reserved for models.
Also from your title of the thread it is not clear that the photo's in question are of a Q1 or even of a locomotive in the case of the 'Prototype' ones.  I would have thought that a couple of albums with a note of referral in the Forums would attract more viewers.
After all these are pictures that will be of use to modellers in particular.
Best regards
Terry
Edited By Terryd on 26/03/2010 16:42:53
TRANSWAVE Converters
