Forum sponsored by Allendale Nov 29
Detail photos of prototype
Nigel Bennett26/03/2010 12:05:52
272 forum posts
6 photos
I was at the NRM last weekend and banged off a few shots in case anybody is following Nick Feast's articles in ME. This is the first few; I'll keep adding to them. There's a separate thread for the tender.
Injectors & Cab Underside:
[image]
Injectors & Cab Underside2:
[image]
Lubricator Atomiser - LH directly above the Lubricator:
[image]
Eccentric Rod:
[image]
Eccentric:
[image]
Fireman's seat:
[image]
LH Frame at throatplate:
[image]
RH Frame at Throatplate:
[image]
Nigel Bennett26/03/2010 12:06:34
272 forum posts
6 photos
Part 2:
General front 3/4 - can't get much of an overall view in there at the moment, but there are enuff pictures of the whole thing around!
[image]
Front buffer beam (& cylinder drain pipes):
[image]
Piston valve covers, front LH:
[image]
Injector pipework:
[image]
Injectors:
[image]
Injectors again:
[image]
LH Lubricator:
[image]
Lubricator drive:
[image]
Nigel Bennett26/03/2010 12:07:13
272 forum posts
6 photos
Part 3: LH Sandbox:
[image]
Steam Reverser:
[image]
And again:
[image]
Sandbox:
[image]
Sandbox - Trailing LH:
[image]
Reverser - RH (?)
[image]
Loco & Tender connection:
[image]
Front Buffer Beam Detail:
[image]
Edited By Nigel Bennett on 26/03/2010 12:08:59
Nigel Bennett26/03/2010 12:10:16
272 forum posts
6 photos
Valve spindles:
[image]
Weighshaft:
[image]
Weighshaft Bearing RH:
[image]
Balance weight on main driver:
[image]
Buffer Beam:
[image]
Backhead:
[image]
Lower down:
[image]
Driver's seat:
[image]
Nigel Bennett26/03/2010 12:11:09
272 forum posts
6 photos
Backhead again:
[image]
Main Driver:
[image]
Coupling Rod Knuckle joint LH:
[image]
Rear Coupling Rod LH:
[image]
Piston valve covers:
[image]
again:
[image]
And finally (for the loco), RH horn:
[image]
nick feast26/03/2010 14:01:23
74 forum posts
6 photos
Well done Nigel, most helpful. The reverser is on the left(driver's) side by the way.
Nick Feast
TRANSWAVE Converters
