Opus Proximum
Anomalies in plans
John Somers 131/10/2009 11:59:15
36 forum posts
I am curious to know if anyone else has run into what appear to be errors in the plans and build notes for Stan Bray's Opus Proximum, a verticle engine featured in The Best of Model Engineer, Volume 1, currently on sale at WH Smith.
Initial study of the article raises a query on the photo of the main bearings and crankshaft on page 29. This bears no relationship to the arrangement shown in the plans.
Having decided to build this engine 50% larger than the plans and to the metric version I next discovered the valve chest cover is shown as 15mm wide whilst the chest is 16mm wide. Surely they should be to the same width ?
Following the machining of the cylinder I then machined up  the Valve Chest and clearly the depth of the chest is out of proportion and should be reduced from the stated 12mm to something like 8mm which would provide adequate clearance for the sliding valve.
I would be interested to hear from anyone else who may be encountering difficulties.
JohnS
David Clark 131/10/2009 12:45:21
3357 forum posts
112 photos
10 articles
Hi There
The photo is incorrect.
Change any dimensions to suit your needs.
The drawings are Stan's originals from the magazienand were only tidied up, not altered.
Send me a photo when finished for Model Engineer.
regards David
JasonB01/11/2009 20:35:32
18924 forum posts
2082 photos
There is one being built here you may want to ask about any drawing errors
Or is that you???
Jason
Edited By JasonB on 01/11/2009 20:38:47
John Somers 102/11/2009 09:53:26
36 forum posts
Hi Jason
Yes it is !
Sorry if I caused any confusion.
JohnS
James Veitch04/11/2009 02:31:41
16 forum posts
Greetings,
I'm thinking of building the Opus Proximum engine.  I'm a novice so excuse any of the following that's off base.
As a first step I'm modeling the Opus P. with a 3-D modeling program.  This is proving to be a good exercise.  First it makes me read the instructions carefully.  Secondly it makes me look at the drawings carefully.  Thirdly it makes me think about how I will actually go about making the real item.
I've already found several minor points of confusion or perhaps errors in the material as presented.  That's all fair enough and not a big problem.  The act of modeling on the computer has helped catch some of these.
I'm not finished modeling yet but here is what I've found so far:
1.  The diagram titled: BASE PLATE, p. 23.
a.   There are 4 holes shown to the right side of the plate. They are arranged in a rectangle of 5 mm by 22 mm.  PHOTO 1 and the photo above PHOTO 1 show the holes are not in a rectangle.  The diagram CYLINDER BASE (p.24) shows the 4 holes in a rectangle of 12 by 19 mm.  The stated hole sizes also disagree, i.e.: 12BA to 10BA.
b. The photo of the finished item on p. 22 shows 4 additional hole are needed to mount the BASE PLATE to a wooden platform.
 2. The diagram titled: MOTION PLATE, p.23.
a.  The size and position of the rectangular hole are not specified.  Is the size of 4 X 19 mm correct?  Is the position from the top right corner as 11 mm down and 4 mm in, correct?
b.  The distance between the holes in the two tabs on the right edge of the plate are not specified.  Looking at the diagram CYLINDER p. 24 I believe the holes should be 19 mm apart.  Is that correct?
All minor stuff but may be of interest to someone, some where. I would be interested in hearing how others are getting along with this project.
John Somers 104/11/2009 06:40:32
36 forum posts
Hello James
As you are discovering there are a number of anomalies with the plans for Opus Proximus which gives rise to the question of whether it's a suitable project for anyone starting out in model engineering. However your  interest in computer modelling could make this something of a challenge and will enable you to consider correcting some of the discrepancies.
 I am assuming that you are planning to build in metric dimensions and I would suggest that you follow suit with your fasteners. Clearly there are some dimensions that are critical but the position of mounting holes can be altered provided it does not alter the position of the component or its relationship to other parts. Your 3D modeling approach will at least provide you with the opportunity of deciding on the final position of mounting holes from both practical and aesthetic points of view.
Like you I also deduced that the holes in the two tabs are 19mm apart and should match the two holes on the lugs of the motion plate and of course the cross head shown on page 28. Clearly the aim is for the cross head to slide smoothly on the two slide bars.
I have made a start on the construction of Opus P and opted for increasing the size by 50%. This will provide a more substantial model and certain parts will be easier to produce. The increased cost of materials is minimal. I am covering the build of Opus P on my website/blogStart Model Engineering and you may find this of interest.
JohnS
Circlip04/11/2009 10:18:25
1198 forum posts
IIRC Op. Prox. was one of a series of engines that had dual dimensions to appease the growing grumbles from the ranks of the "Why no metric designs"???
  Sadly, unless the design gives the EXACT numerical equivalent from WHICHEVER system is used, approximations introduce errors rapidly. 25mm is NOT 1" and neither is 1/2" 12 or 13mm.
 I wouldn't be surprised that if you worked the parts in imperial it fits and works??
   Years ago, the D/O I worked in used to have to go into the works to "Sort out" percieved Drawing errors. When you have to start at one end of a machine and check out why a bracket on an assembly 30Ft away doesn't line up, it doesn't take many "proud sixteenths" or "Shy eighths" to loose OR gain inches at the other end.
  When the workings of a mechanism are UNDERSTOOD it doesn't matter which system is used providing you design the bits using the appropriate sized materials FOR THAT SYSTEM.  Sadly, cos some of the CAD programmes mean that most can now draw straight lines and lines that intersect at right or whatever angle can be specified, it DOESN'T mean that they are DESIGNERS.
  To Illustrate, 1" - 1/8" twice = 3/4" OR 25.4 minus 3.2 Twice = 19, BUT 3/4" = 19.08. In the case of using 25mm wide material, a subtraction of 3mm per side for something like column centres matters not a s*d, but 25.4 minus 3 twice, although in the example given doesn't matter for column centres but can be disaster for valve or pitch settings.
  Unfortunately quite a few of Stans designs have been critisized by whingers (Present company excepted) and copyers who try to change things without understanding the implications.
 A colleague is at presant making an engine originally designed in imperial. Luckyly he has someone to help with the IMPORTANT sizes to maintain and the "Floaters", providing a few down the line are taken into account, CAN be solid Metric.
   Regards  Ian.
John Somers 105/11/2009 16:18:33
36 forum posts
And there was me thinking that if I came across a set of plans for a model engine that had been converted into metric I could actually build it and it would run.
Ah well, you learn something new every day. I think I will stick with my Elmer Verburg's plans and my handy imperial to metric conversion chart.
John S
John Somers 118/11/2009 07:34:12
36 forum posts
I would be interested to hear from anyone building Stan Bray's Opus Proximum. I reckon I am now about two thirds through the build and having sorted out some early problems the project is coming together nicely. You can view my progress here. I have had a few problems along the way and my blog may provide fellow builders with some food for thought.
I am building my Opus Proximum 50% up in size and several times I have felt sympathy for anyone building to the plan size. Making parts like the eccentric strap and the steam valve must call for a very steady hand and sharp vision.
My thoughts are now turning to the finish. Personally I am not too keen on the red and green engine finishes on this size of engine so I may leave mine in polished aluminium, stainless steel and brass though I might consider painting the three main horizontal plates in satin black. As these are aluminium an initial coat of etching primer is pretty much essential.
Today I shall be tackling the cross head but I am planning to machine this out of brass bar rather than silver solder three or four components together. I reckon this will give me better control of the critical final dimensions.
John S
Circlip18/11/2009 11:30:35
1198 forum posts
As an alternative to the "Normal" paint finishes John, cos you're using materials capable of showing it off to advantage, have you thought about Chemical finishes??
  Regards  Ian.
John Somers 118/11/2009 16:14:27
36 forum posts
Now there's a thought Ian. I have some blackening and antiquing chemicals bought when I had grand idea on styling a pushrod type engine on an old Rudge motorcycle engine - but that's another story ! Anyway you have given me something to think about - thanks.
John S
JasonB18/11/2009 16:49:18
18924 forum posts
2082 photos
I like the black finish, with just a few parts left in bare steel & brass. Was looking at this guys site the other day and he uses a black etching process that seems to work on alloy & brass, its the "Seamann Atztechnik link, best if you put the page url into a translator like babblefish.
Jason
John Somers 118/11/2009 19:35:49
36 forum posts
Inspirational work Jason. Seems like some further research might be worthwhile.
John S
JasonB18/11/2009 19:53:26
18924 forum posts
2082 photos
The black sems a very dense coating, hard to tell its not painted, but seems to have the advantage of a very thin layer( or disadvantage if you want to hine tool marks)
Don't know if you found your way to the rest of his models but this should take you there
Jason
John Somers 114/09/2010 16:22:12
36 forum posts
It is getting on for ten months (doesn't time fly !) since I started building Stan Brays Opus Proximum and whilst it has been a struggle I am now pleased to report that at last it is up and running. Those interested can see the step by step build log and the final outcome at
http://start-model-engineering.co.uk/2010/09/14/opus-proximum/opus-p-now-running/
John S
John Shepherd14/09/2010 18:21:26
216 forum posts
7 photos
I built the Opus when it first (I think) appeared and found several errors and wrote to the then editor of ME stating what I found hoping that it would help others.
My letter was not published but to my surprise I received a letter from Stan Bray along the lines of' who was I to question his drawings'!
Furthermore it would appear that the mistakes have not been corrected in reprints although I did not keep a record of what I found so I could not say if the errors are original or if others have crept in.
John Shepherd
John Somers 114/09/2010 19:49:27
36 forum posts
You are not the first to get your knuckles wrapped upon querying anomalies In Mr Brays drawings. I am curious to know if despite this your endeavours were successful and you finished up with a runner - anyt chance of any pics ?
John-Som
David Clark 114/09/2010 20:11:40
3357 forum posts
112 photos
10 articles
Hi There
Because the drawings and articles were done by a previous editor, they were republished without corrections.
Had I know how bad they were, I would not have used them.
regards david
John Shepherd15/09/2010 18:57:33
216 forum posts
7 photos
I am afraid to say my Opus is not a runner. I had a lot of trouble with the valve gear and I gave up as I became convinced it was not going to run well anyway.
Photo as requested - it is a  bit dirty and tarnished as I have just got it down from the loft.
 Perhaps now it is down I might have another go
at it and tidy it up.
Rick Hann04/07/2020 23:38:12
4 forum posts
Hi, I realize this an old thread, but I ran across it when looking for information on this engine. I started this little engine more than 20 years ago when I lived in Germany. I made quite a few of the parts and they languished in my unfinished projects box until the Corona Virus hit and I decided to try and complete it. Has anyone actually finished this little engine? When I got down to actually putting pieces together, I soon found out the their were several dimensional errors that required binning several parts. Not wanting to be accused of being a whinger, I would like to hear from anyone who has built this engine and could give me a heads up on problems they may have encountered. Thanks.
Rick Hann
EngineDIY
