Tender materials
Dave Jones 115/09/2009 19:38:19
85 forum posts
5 photos
just a quick question.  Due to the cost of brass, I was thinking about making a tender body from steel (then painted inside and out) is there any reason why I should not do this?  (i.e. will it eventually rust)
Ian S C16/09/2009 12:27:35
7468 forum posts
230 photos
I don't know much about model locos,but maybe you could get it galvanized.
PETER AYERS19/10/2009 14:33:07
25 forum posts
    a friend of mine has a loco which is quite a few years old, it has a steel tender painted indide with bitumen paint and there is no sign of rusting. Hope yhis helps
        Petera
Laurence B20/10/2009 09:43:13
58 forum posts
I'm building the tender for a Don Young Class 2 at the moment and have used brass sheet for the tank,but I can't see any reason not to have made it in steel.It certainly would have been a lot cheaper!
A member of the club to which I belong,recently completed a Class 2,with a steel tender tank.After every running session he dries out the inside of the tank with a hair drier (I'm not sure his missus approves or even knows!) He reports no problems with rusting.
I did read somewhere of a model engineer who coated the inside of his tender tank with a resin compound used for the restoration of old and rusty petrol tanks of vintage cars and motor bikes.
IanT20/10/2009 15:04:59
2002 forum posts
212 photos
Dave,
A slightly different suggestion would be to make the tender from stainless steel. You can then use silicon to seal any riveted joints - or if you can TIG weld (or know someone who can) then even better, weld it up. I have a tender in stainless welded up as per the latter suggestion and it is a nice solid job.
Not sure where the material from my existing tender came from - but I have some very nice stainless steel 'kick plates' that came off the bottom of some office doors being replaced by a local company. They would certainly fit the bill for a 3 1/2" engine - and probably most 5" locos.
Dreweatts
Rapid RC
