TurboCad v 6.5 version
Setting up desktop
Barneyboy27/08/2009 21:48:14
3 forum posts
Hi can anyone enlighten me how to set up layers and entities that will be available for use in all other drawings. Help and advice welcome.
Thank you Barneyboy Glasgow.
Jim K28/08/2009 04:42:13
44 forum posts
Barneyboy
I dont have the turbocad on this computer that i use just now do you have the manual that came with turbocad? It explains everything.
I think you want to set up a template by the sounds of it so  you can use it for all drawings open a blank drawing and set up your page, from memory if you go to the top of the page there is a pull down that lets to set grid, units etc. the layers are there also. then save it as master drawing setup or something like that.
I will have a better look tonight and come back to you on it. as i am a bit vague in my explanation.
Jim
Redpiperbob28/08/2009 07:27:27
89 forum posts
41 photos
Hi Barneyboy
I use Turbocad 7
In this version you go to
OPTIONS
LAYERS
NEW
you then can name the layer and change its other properties
Hope this helps
Bob
rapid Direct
walker midge
JD Metals
