Michael Malleson | 19/05/2009 17:30:16 |
58 forum posts 2 photos | I am building a 5"g, "Boxhill. This has inside cylinders with the steam chest between, and the question is:- is oil and water type gasket paper up to the job or must I use something more substantial such as asbestos free material 0.020" thick? The problem with the latter is that it would leave very tight machining tolerances to fit the whole assembly between the frames without risking the steam ports breaking through into the cylinders. All suggestions welcome, eg, alternative gasket material etc. etc. Thanks in anticipation. |
Circlip | 20/05/2009 15:43:34 |
1510 forum posts | Gloss on one side and rough on the other, the golden oldies always seem to last, Braan paper, the type used for packing parcels, cheap (Yorkshire trait) forgiving and reliable. Use a layer of oil to seat it.
Regards Ian.
ChrisH | 20/05/2009 21:59:36 |
1018 forum posts 30 photos | When I was in the merchant navy we used to make gaskets from chart paper - a thick and stiff paper. You had to be careful not to nick the Mate's latest charts otherwise the engine room's name would be mud!
Chart paper not easy to get ashore, but you get the idea.
Chris |
Michael Malleson | 22/05/2009 08:11:02 |
58 forum posts 2 photos | Hi Ian & Chris. Clearly a good substantial paper has been a common material for this puroose. The 2 Stuart engines I have (1960's vintage) are fitted with paper gaskets so it is obviously suitable for high pressure steam. Many thanks, Mike. |
mgj | 07/06/2009 00:03:07 |
1017 forum posts 14 photos | Circlip - thankyou. genius.
You have saved me from a fate worse than death. Assembling a 3" Little Samson with all that Foliac graphite stuff.
I'll use the .030 gasket material and Foliac to put the cylinder block on, but brown paper and oil seems pretty handy for almost everythng else.
Blue Hylomar is pretty good if used as the packet says, and not just smeared on - but messy. |
Circlip | 08/06/2009 14:14:45 |
1510 forum posts | What most forget, is that if their machining is so crappy that a "shim" won't seal it, your never going to get things to line up properly cos of variable compression in thicker "Seals". "Figure of eight" on the finest Silly Cone carbide paper (OK. Wet & Dry to anyone under forty five -ish) over glass using "Brasso" as the wetting medium.
Regards Ian.
Michael Malleson | 08/06/2009 17:41:04 |
58 forum posts 2 photos | Thanks for the latest replies, I was hoping that the latest ME would produce more info. Are there any "Boxhill" or "Metro" builders out there who have overcome this problem? Would love to here from you. Mike |
Norman Barber | 11/06/2009 11:56:31 |
![]() 14 forum posts | Hello Michael,
I am building a "Boxhill". The chassis is complete and run on air. The boiler is finished and tested and the fittings are made. I am currently making the tanks and superstructure. I always use brown paper for the gaskets on my locomotives, occasionaly with a smear of Red Hermetite if the bolt holes are very close to the edge of the gasket. I have never experienced any problems.
I have made a lot of modifications, too numerous to list here, to the Martin Evans drawings (which I assume you are using). These drawings leave something to be desired and in the case of the boiler at least one modification is required in order to satisfy the current regulations - namely the location of the lower water gauge bush.
If you are interested in "Terriers" may I suggest that you obtain a copy of the book "Stoudley and his "Terriers"" by Tom Middlemass.
Norman Barber
