Collet closer identification.
vic newey06/08/2022 15:37:47
176 forum posts
84 photos
I have a collet closer and step collets that came with an old lathe but do not belong to it.
The thread is 8tpi and the locating shoulder for the spindle is 1/3/4"
The Crawford step collets have 15mm shanks, 13mm thread
Les T06/08/2022 16:18:03
13 forum posts
Looks like a Myford (or similar) thread and register on the holder that appears to match the
taper on the stepped chuck. It would need a drawbar for the split chuck. The thread for the drawbar will
depend on the collet make. Usually 0.625 mm pitch.
Hope this helps
bernard towers06/08/2022 16:22:37
687 forum posts
141 photos
not Myford as that's 12 tpi but could be Boxford
Les T06/08/2022 16:25:57
13 forum posts
Sorry, I missed the '8TPI' and 'Crawford!
Clive Foster06/08/2022 17:56:02
3172 forum posts
113 photos
Smart & Brown used I & 3/4" by 8 tpi on the spindle nose of the Model L series plain turning lathes.
Often configured as bench top capstan and second operation machines which would commonly use collet work holding.
vic newey06/08/2022 18:07:23
176 forum posts
84 photos
Thanks for the suggestions everyone, Smart & Brown sounds most likely so far. There are no markings on the collet closer which might have been of help
old mart06/08/2022 21:20:39
3886 forum posts
264 photos
Measure the thread on the end of the collet, if it is 0.902" x 24 tpi W is will be the 2804 type used on the Smart & Brown model A and some model M's and L's.
Your collet threads would seem to be much smaller, but the closer looks exactly like the model A one we have.
Edited By old mart on 06/08/2022 21:24:29
DC31k07/08/2022 07:24:36
725 forum posts
Posted by old mart on 06/08/2022 21:20:39:
Previous discussion on the collets less than two months ago:
https://www.model-engineer.co.uk/forums/postings.asp?th=180490
vic newey07/08/2022 09:21:16
176 forum posts
84 photos
Posted by DC31k on 07/08/2022 07:24:36:
It was indeed but that was for the standard 15mm collets that do fit my lathe and trying to be certain as to the thread as pointed out because of slight variations in threads. I did get a new die and found it cleaned the threads of the Boleys but only some of the Crawfords.
However the question here is completely different, it is about the collet closer dimensions and what lathe it belongs to so I can probably offer it for sale as it's useless to me
Edited By vic newey on 07/08/2022 09:21:41
Martin Connelly07/08/2022 09:31:56
2177 forum posts
226 photos
The thing about the collet closer is that it is relatively easy to make, the step collets that go with it are the part with high value. Anyone who has the step collet is also likely to have bought a closer with it or, as I did, make one to suit. I also made the collet opener for an internal stepped collet.
Martin C
old mart07/08/2022 14:01:27
3886 forum posts
264 photos
It looks like somebody had a set of the collets and made a closer with the correct angle to enable them to be used on a Smart & Brown lathe. A drawbar to suit the spindle and collet threads together with an adaptor to fit in the spindle to keep the collets centralised. The closer would not be guaranteed to keep the collets aligned on its own.
martin haysom07/08/2022 14:50:48
106 forum posts
making one of these is on my to do list. i will be watching the adds
Howard Lewis07/08/2022 22:15:09
6301 forum posts
15 photos
It looks like a Bell Chuck, often used by the clock making fraternity..
I have both internal and external varieties, which are pulled back onto a taper to either close or expand the work holder.
In my case, the closer and expander had external 26 tpi Britsih Standard Brass threads, so adaptors mhad to be made so that a 3/8 BSW drawbar would do the pulling to close / open.
Not being a clock maker, my heretical misuse for them is making / modifying / thinning washers!
Howard.
Dreweatts
Rapid RC
