NR67 | 23/06/2022 09:25:24 |
![]() 36 forum posts 10 photos | I am currently machining the cylinder head for my ET Westbury Wyvern. The build notes say to use a M10x1 thread for the spark plug and not the 3/8x24 as per the drawings. I guess thats because modern plugs are metric. I will be running on petrol so my question is are there any recommendations for the plug. I want to leave or remove enough material so the tip is in the correct position. I will want the plug in hand before I continue with that feature. Also what is the correct position for the tip. This is my first IC engine so sorry for the beginner sounding questions. |
Andy_G | 23/06/2022 09:57:36 |
![]() 184 forum posts | The NGK CM-6 plug is often used for engines of that sort of size (it is M10 x 1 thread). I used one for my little (20mm bore) hit and miss engine: They are readily available and reasonably inexpensive. In the absence of any information to the contrary, I'd aim for the end of the plug body to be ~flush with the inside of the head, provided that nothing comes too close to the electrodes in that configuration. Edited By Andy_G on 23/06/2022 10:05:01 |
Roderick Jenkins | 23/06/2022 10:08:37 |
![]() 2201 forum posts 616 photos | +1 for everything Andy says. That's what I used on my Wyvern it works ok. Rod |
JasonB | 23/06/2022 10:21:17 |
![]() Moderator 23022 forum posts 2763 photos 1 articles | Same here I use the NGK CM-6 on the larger engines. I've done engines where the plug is a long way removed from the cylinder in separate valve blocks but they still work OK |
noel shelley | 23/06/2022 10:24:38 |
1435 forum posts 23 photos | The main thing is that nothing hits, I once came across an engine that would not run ! The owner had put a long reach plug in and the gap was closed as the piston hit it ! Shorter plug ran fine ! Measure piston height and any head clearance and go from there. Plug position will dictate combustion/flame fromt.. If your near me I could lend you a 10mx1 tap. Good luck. Noel. |
NR67 | 23/06/2022 21:39:46 |
![]() 36 forum posts 10 photos | Thank you for all the excellent replies. Just what I needed to know. I left the plug entry point a bit high so I can take a bit off to get the plug position right when I get one to install. Coming from steam to IC is challenging so I may have further beginners questions when it come to timing and making a spark. Ordered the tap today. M10x1. Edited By NR67 on 23/06/2022 21:41:52 |
