Ian McVickers | 18/06/2022 20:34:40 |
225 forum posts 115 photos | So, I have decided to have a go at a PM Research No4 build. Base has been machined, bearing blocks more or less complete with additional bushes. Crankshaft and flywheel nearly finished. Next job is to drill and tap the flywheel for the grub screw then need to cut the keyway and make the key. After that I will polish up the completed parts then move on to the frame. I would have been a bit further on but this arrived a few weeks ago.
Baz | 18/06/2022 22:09:20 |
756 forum posts 2 photos | Nothing wrong with the dark side! May the force of CNC be with you |
