Yet another unidentified tool
PaulG05/06/2022 15:28:19
11 forum posts
5 photos
Not as esoteric as some other submissions but it has me beaten. So can anyone enlighten me? The blade is spring loaded and retractable but I don't know whether it planes, scrapes or cuts. Obviously made for a very specific purpose for which I have yet to develop a need.
ega05/06/2022 16:53:48
2567 forum posts
203 photos
It looks to be shop-made so perhaps some rather special purpose.
Bill Davies 205/06/2022 16:54:32
287 forum posts
11 photos
No idea,Paul.
It looks as though the ring is used to hold the base against something, presumably the work? The base clearly butts against the edge of something. Do you push the screw to force the blade out? Does the screw control the depth of cut?
Bill
Edited By Bill Davies 2 on 05/06/2022 16:54:56
Martin Connelly05/06/2022 16:56:15
2183 forum posts
227 photos
It would be good for removing excess glue from the edging strip on tables and worktops.
Martin C
Bizibilder05/06/2022 18:00:32
126 forum posts
7 photos
A veneer or banding trimmer?
PaulG05/06/2022 18:24:25
11 forum posts
5 photos
Bill,
I have checked with the actual owner of the tool and it seems that:
Undoing the knob allows the blade to move out, pulled by an internal tension spring. The blade can then be pushed back in against the spring tension until the protruding spigot reaches the end of the slot at which point the blade is retracted. So no use as a plane as the blade retracts as soon as it digs in. So maybe for protecting the surface.
Rapid RC
Dreweatts
