Richard Kent 1 | 03/06/2022 20:37:03 |
53 forum posts 40 photos | A post which might be of some use to Tig enthusiasts...............
Edited By Richard Kent 1 on 03/06/2022 20:38:20 |
old mart | 03/06/2022 20:52:05 |
3913 forum posts 268 photos | Make sure they are modern electrodes, not the old thiorated ones, as the dust will be radioactive. |
Andrew Johnston | 03/06/2022 21:26:00 |
![]() 6679 forum posts 701 photos | Posted by Richard Kent 1 on 03/06/2022 20:37:03:
...not engineering advice so do not UNDER ANY CIRCUMSTANCES follow what I do or say... That's the only sensible part of the original post. Andrew |
Richard Kent 1 | 03/06/2022 21:29:50 |
53 forum posts 40 photos | @Andrew Johnston - I've heard worse from better Edited By Richard Kent 1 on 03/06/2022 21:39:48 |
Baz | 03/06/2022 22:06:57 |
757 forum posts 2 photos | No discount code for wheels and electrodes as per your grinding wheel posts? |
Richard Kent 1 | 03/06/2022 22:33:06 |
53 forum posts 40 photos | @Baz - He (moderator) has a rule book and a big stick if you do that Edited By Richard Kent 1 on 03/06/2022 22:39:58 |
Mark Rand | 04/06/2022 09:48:23 |
1315 forum posts 38 photos | Big advantage is that you don't end up with a wheel on the bench grinder that's got grooves all over it. |
Joseph Noci 1 | 04/06/2022 10:04:30 |
1099 forum posts 1317 photos | Waayyy to sharp for anything more than 10amps.... |
Richard Kent 1 | 04/06/2022 10:15:57 |
53 forum posts 40 photos | Posted by Mark Rand on 04/06/2022 09:48:23:
Big advantage is that you don't end up with a wheel on the bench grinder that's got grooves all over it. You're right Mark. I used a bench grinder for years and that was exactly what happened. When using these small diamond discs ensure you set your mini-grinder speed to 20,000 rpm or above as it tends to grind more efficiently.
Disclaimer: This is not engineering advice so do not UNDER ANY CIRCUMSTANCES follow what I do or say Edited By Richard Kent 1 on 04/06/2022 10:30:23 |
Hopper | 04/06/2022 10:19:52 |
![]() 6728 forum posts 348 photos | Are those 40mm discs rated for 20,000 rpm? |
Richard Kent 1 | 04/06/2022 10:23:42 |
53 forum posts 40 photos | Joseph Noci 1 - Try sharpening at different angles and see what works best for you. I use this tip angle for welding up to 160A with a water cooled setup and the results are excellent. If you are using a non-water cooled setup then the electrode, collet and collet holder will suffer heat degradation issues. My overriding advice is to try different options and see what works best for you.
Edited By Richard Kent 1 on 04/06/2022 10:24:21 |
Richard Kent 1 | 04/06/2022 10:27:52 |
53 forum posts 40 photos | Hopper - See disclaimer below and I recommend you do your own research................ Disclaimer: This is not engineering advice so do not UNDER ANY CIRCUMSTANCES follow what I do or say
Edited By Richard Kent 1 on 04/06/2022 10:55:12 |
Hopper | 04/06/2022 12:28:45 |
![]() 6728 forum posts 348 photos | Bolle goggles and diamond wheels. Swish crowd here tonight. Edited By Hopper on 04/06/2022 12:47:29 |
Richard Kent 1 | 04/06/2022 12:53:27 |
53 forum posts 40 photos | Posted by Hopper on 04/06/2022 12:28:45:
Bolle goggles and diamond wheels. Swish crowd here tonight. Edited By Hopper on 04/06/2022 12:47:29 Proxxon Mini Grinder too! Only the best here! Don't even talk to me if you own a Dremel!
Edited By Richard Kent 1 on 04/06/2022 13:09:05 |
Mark Rand | 04/06/2022 13:54:17 |
1315 forum posts 38 photos | I use my Lidl 'Parkside' tool in preference to my dremel. Half the price and twice the quality! |
Richard Kent 1 | 04/06/2022 13:57:27 |
53 forum posts 40 photos | Posted by Mark Rand on 04/06/2022 13:54:17:
I'll have to get The Moderator in on this one!
Edited By Richard Kent 1 on 04/06/2022 13:58:37 |
Colin Heseltine | 04/06/2022 16:09:30 |
667 forum posts 230 photos | I was looking for a tungsten electrode grinder and came across what I though was a very neat one on Thingiverse.com. This one that can be printed out with a 3D printer. If you search for Tungsten Grinder/Sharpener with Dust Collection (https://www.thingiverse.com/thing:4937583). This device is used with a Dremel or similar with a threaded nose. In my case I use a Milwaukee M12 Die Grinder, but it also fits my Dremel. Pictures below show the one I printed out. There is a video attached to the Thingiverse page showing the device being made and in use). It works very well and can be connected to a vacuum. The only thing needed to purchase are the 25mm diamond wheels and some brass grub screws for the tungsten guides. As designed the device can grind 60, 45,30 and 15 degree angles and can also be used to trim the miss-shaped ended of electrodes. No more grooves in your grinding wheels.
Colin Edited By Colin Heseltine on 04/06/2022 16:11:20 |
Richard Kent 1 | 04/06/2022 16:24:41 |
53 forum posts 40 photos | Colin Heseltine - That looks great I was going to purchase something similar on ebay made from solid aluminium but I wanted something with a larger 40mm disc due to the extra lifespan better m/s rating. I also had some 40mm discs in stock. But once again, your device looks great
Edited By Richard Kent 1 on 04/06/2022 16:45:58 |
