paul rushmer | 29/05/2022 14:44:08 |
95 forum posts 17 photos |
not done it yet | 29/05/2022 15:01:28 |
6887 forum posts 20 photos | It appears to be a wood turning lathe - probably of anonymous maker. Likely home-made. Edited By not done it yet on 29/05/2022 15:02:04 |
David-Clark 1 | 29/05/2022 17:46:04 |
![]() 222 forum posts | I would have said very old clock makers turns. |
Michael Gilligan | 29/05/2022 23:20:27 |
![]() 20289 forum posts 1064 photos | A couple of points, but no identification
MichaelG. |
Nigel Graham 2 | 30/05/2022 00:00:16 |
2281 forum posts 33 photos | The base does not look as if originally made for the lathe even if on this lathe from new. It might have come from a small milling-machine. That raising block - is it a casting? It looks like a piece of angle or Z-section found for the purpose. What do the isolated nuts and bolts in the base hold? Oh, probably commercially-made parts but the headstock doesn't seem quite to match in style to the saddle and tailstock. I wonder if it came from a different source; or perhaps the same manufacturer but a different model. Intriguing and rather pretty little machine anyway, and it would be good to see it all bright and serviceable again, even if just for small items of wood-turning or brass-work by hand. It was probably driven by treadle originally, possibly the type advertised as a "foot-motor" when sold as a stock item for driving any small machine. |
Hopper | 30/05/2022 00:29:33 |
![]() 6653 forum posts 347 photos | I would guess homemade from the way the heastock has been carved out of a piece of plate. Commercial offerings were usually cast as a matter of cost saving and simplicity of manufacture. Other components on it look fabricated from bar stock too. Will make a nice piece all cleaned up. |
paul rushmer | 30/05/2022 07:24:35 |
95 forum posts 17 photos | Thanks for the thoughts so far, the head stock is a bronze casting, base is cast iron with plywood infill with mountings for motor so not origional and yes the mounting bracket is a lump of angle. Thanks Paul
vic newey | 30/05/2022 09:13:47 |
![]() 182 forum posts 84 photos | Unusual to see a flat belt pulley on such a small lathe, V belts first appeared around1917 but much earlier pulleys for round leather belts are often thought to be for V belts as they fit very well. Here someone has tried a V belt upside down? so the flat side is on the pulley but not sure how well that would work if at all |
David-Clark 1 | 30/05/2022 09:19:50 |
![]() 222 forum posts | A timing belt would probably work well. |
Hopper | 30/05/2022 09:55:52 |
![]() 6653 forum posts 347 photos | The best flat-belt replacement I have found on my Drummond M-Type is running a Poly-V belt straight on the old flat belt pulleys. I run it with the V grooved side contacting the flat pulley. Works really well. Seems to grip well enough even without the V-grooves, including for taking 100 thou deep cuts in steel. |
