For PC heatsinks
pgk pgk | 20/05/2022 14:55:00 |
2563 forum posts 293 photos | I've just take apart an all-in-one PC and cleaned all the dust and crud out of the fan and radiator and it all works fine and quiet now. The cooling fan blows air into a radiator which houses some thermal conduction bars terminating in sprung flats screwed over the main processors. Clearly there is evidence of a gap-filling compound and I’d appreciate advice on what to use there if it needs doing again - something that will gap-fill but not glue or drip... pgk |
Thor 🇳🇴 | 20/05/2022 15:00:27 |
![]() 1628 forum posts 46 photos | I assume you mean something like this, various types tested here. Thor |
pgk pgk | 20/05/2022 16:56:56 |
2563 forum posts 293 photos | Posted by Thor 🇳🇴 on 20/05/2022 15:00:27:
I assume you mean something like this, various types tested here. Thor That's the sorta thing looks like a paste rather tthan liquid for ham-fisted use... pgk |
Brian G | 20/05/2022 17:51:43 |
840 forum posts 37 photos | Posted by pgk pgk on 20/05/2022 16:56:56:
I assume you mean something like this, various types tested here. Thor That's the sorta thing looks like a paste rather tthan liquid for ham-fisted use... pgk If you are worried about ham-fisted use make sure you get a non-conductive thermal grease. The more expensive high performance "liquid metal" pastes are electrically conductive and if any gets on the pins you may say goodbye to the processor, and there is no need for them unless you are seriously overclocking. Brian G |
Stuart Smith 5 | 20/05/2022 20:58:44 |
278 forum posts 43 photos | CPC list 2 which look suitable: Stuart |
old mart | 20/05/2022 21:06:09 |
3772 forum posts 233 photos | I have used Arctic silver 5 for years, but there is some stiction when removing the heatsink, which is unavoidable. |
Martin King 2 | 20/05/2022 22:21:34 |
1005 forum posts 450 photos | Hi All, Interesting thread for me as I have had to remove a large circuit board from a woodworking lathe to have it repaired. When I undid the retaining screws and went to slide it out of the steel casing the bottom was covered in a thickish white paste. The manual said this was to aid heat conduction from the alloy heat sink to the casing. I believe there was a mention somewhere else in my research that this would be Zinc Oxide paste. Would this be correct and is it the same Zinc Oxide as the old fashioned ointment of the same name? Cheers, Martin |
Peter Greene 🇨🇦 | 20/05/2022 22:48:31 |
510 forum posts 6 photos | CPUs are normally mounted using silver conductive compound which is much less fussy about film thickness than straight silicone which is non-conductive and relies on a very thin, gap-filling application to do its job. AFAIK all the cpu manufacturers recommend/require it (silver). That doesn't mean you put it (silver) on by the spoonful though. A thin wipe all over the CPU cover is enough to give a decent thermal connection to the heatsink (better than silicone). Shorting out pins is greatly exaggerated. It's like a grease film. If you couldn't apply a thin film of that locally without getting it all over the pins you wouldn't be here. Personally, if the original heatsink connection hasn't been broken, I'd leave it alone. It's most unlikely that you'll improve it. Cleaning out the crud that gathers around the fan and heatsink though with a vacuum cleaner is well worth doing from time to time, especially if you do any intensive processing (such as video editing). If you run a background cpu temperature-checker before and after clearing out the dirt you'll certainly notice a difference.
pgk pgk | 21/05/2022 05:30:38 |
2563 forum posts 293 photos | As described above in this specific case the radiator, coolant bars and coolant pads are inseparable such that the cleaning process required the pads to be lifted. I do own a conductive epoxy but avoided using that in case of future need to repeat the cleaning.
pgk |
Michael Gilligan | 21/05/2022 06:02:53 |
![]() 20182 forum posts 1053 photos | Posted by pgk pgk on 21/05/2022 05:30:38:
[…] . It’s not immediately obvious from that short video clip, so I will just mention that those are ‘Heat Pipes’ **LINK** https://en.wikipedia.org/wiki/Heat_pipe … and with a system like that, excellence of assembly is mandatory. MichaelG. . Edited By Michael Gilligan on 21/05/2022 06:25:03 |
SillyOldDuffer | 21/05/2022 08:49:05 |
Moderator 8691 forum posts 1967 photos | Posted by Michael Gilligan on 21/05/2022 06:02:53:
[…] . It’s not immediately obvious from that short video clip, so I will just mention that those are ‘Heat Pipes’ ... Very educational this forum! Until this morning I assumed those Copper runs were just a simple metal conductor, used to transfer heat from a hot component such as a CPU across the circuit board to wherever it's mechanically convenient to mount a fan and radiator. Half right, now I know the pipe relies on latent heat and carries much more heat than a lump of Copper would. Heat-sinks have always been a mystery to me: I know heat follows rules analogous to Ohms Law, but I've no idea how to design one. Big lump of Aluminium, with lots of fins, painted black, and don't assume it's earthed is the best I can do! How big and how many fins are just as wild guess. Dave
Martin King 2 | 21/05/2022 08:51:40 |
1005 forum posts 450 photos | Any thoughts on the Zinc Oxide paste? Cheers, Martin |
Andy_G | 21/05/2022 09:30:11 |
![]() 173 forum posts | Posted by Martin King 2 on 21/05/2022 08:51:40:
Any thoughts on the Zinc Oxide paste? Cheers, Martin The original was almost certainly a silicone based 'heat sink' compound, something like this (which does contain zinc oxide). https://cpc.farnell.com/servisol/200001000-25gm/heat-sink-compound-25g-tube/dp/SAHEATSINKCOMP (Personally, I'd replace it with similar.)
